    How can I add new styles to SU on a Mac?
    14 Posts 4 Posters 1.9k Views 4 Watching
    • C
      chrisjk
      Chuck,
      I really don't know - I don't have such a menu item.
      I suspect it might be connected to some plugin you have - SketchyPhysics perhaps? If so, you might have misfiled one of the ruby scripts.
      • GaieusG
        No, plugins cannot affect existing SU windows. You should really be able to figure out I believe (I am on a PC so will not be too much of a help here).
        • C
          chrisjk
          Having had a quick look at the API docs (from a non-ruby coders viewpoint!) I agree with Gai's comment insofar as it refers to the kind of entry represented by --Runtime-- Of course, scripts can and do affect menus as far as plugin names etc are concerned.
          I suggest you post the question in the Developers forum.
          I don't think it's just a "Mac thing".
          • C
            CRSeventy
            @chrisjk said:
            Make sure they go in the correct folder:-
            Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Styles
            The Styles folder will also have sub-folders, create your own for imports if you want.
            Chris,
            Thank you.
            I have one more question. While I was trying to add these last night a "Runtime" sub menu popped up in the Styles menu. Any idea what that is or how to get rid of it?
            Kind regards,
            Chuck
            • C
              CRSeventy
              @chrisjk said:
              Chuck,
              I have not added any plugins.
              Kind regards,
              Chuck
              • jeff hammondJ
                i managed to get the same thing to happen....
                i did that by placing a folder named 'lin' inside another styles folder (the default styles folder)..
                the folder that you named 'Lin Collection' should go directly into the styles folder --
                if you have any folders inside of the ones already located inside the styles folder (color sets, default styles, sketchy edges, etc..) then the runtime thing will show up...
                • C
                  chrisjk
                  That's intriguing, I put a lin subfolder inside the Default styles folder and I get no Runtime line but just a picture of a folder in the thumbnails of styles.
                  Baffled!
                  • jeff hammondJ
                    weird.. i'm now getting the same thing as you chris..
                    i can't get runtime to show up again.
                    • C
                      CRSeventy
                      What is this runtime? Do you folks think it will effect something?
                      What about deleting the whole program? Or plists?
                      Kind regards,
                      Chuck
                      • C
                        CRSeventy
                        [attachment=0:iy42ai4q]<!-- ia0 -->screen 5.jpg<!-- ia0 -->[/attachment:iy42ai4q]
                        I don't have any folders in other folders. Before I knew about how to add them I was just trying to drag them into the styles menu window or double clicking on them and Style Builder would open.
                        Kind regards,
                        Chuck
                        • C
                          chrisjk
                          Chuck,
                          I doubt very much that it's anything to worry about - I'd just leave it.
                          With your input, this post could be even better šŸ’—
