    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    How can I add new styles to SU on a Mac?
    14 Posts 4 Posters 1.5k Views 4 Watching
      CRSeventy
      I downloaded some styles shared by Lin. viewtopic.php?p=181498#p181498
      I want to try to use/try them and I can't seem to get them into the Styles window in my SU program.
      Kind regards,
      Chuck
        chrisjk
        Make sure they go in the correct folder:-
        Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Styles
        The Styles folder will also have sub-folders, create your own for imports if you want.
          CRSeventy
          Here Is what is looks like:
            chrisjk
            Chuck,
            I really don't know - I don't have such a menu item.
            I suspect it might be connected to some plugin you have - SketchyPhysics perhaps? If so, you might have misfiled one of the ruby scripts.
              No, plugins cannot affect existing SU windows. You should really be able to figure out I believe (I am on a PC so will not be too much of a help here).
                chrisjk
                Having had a quick look at the API docs (from a non-ruby coders viewpoint!) I agree with Gai's comment insofar as it refers to the kind of entry represented by --Runtime-- Of course, scripts can and do affect menus as far as plugin names etc are concerned.
                I suggest you post the question in the Developers forum.
                I don't think it's just a "Mac thing".
                  CRSeventy
                  Chris,
                  Thank you.
                  I have one more question. While I was trying to add these last night a "Runtime" sub menu popped up in the Styles menu. Any idea what that is or how to get rid of it?
                  Kind regards,
                  Chuck
                    CRSeventy
                    @chrisjk said:
                    Chuck,
                    I have not added any plugins.
                    Kind regards,
                    Chuck
                    • jeff hammondJ Offline
                      i managed to get the same thing to happen....
                      i did that by placing a folder named 'lin' inside another styles folder (the default styles folder)..
                      the folder that you named 'Lin Collection' should go directly into the styles folder --
                      if you have any folders inside of the ones already located inside the styles folder (color sets, default styles, sketchy edges, etc..) then the runtime thing will show up...
                        chrisjk
                        That's intriguing, I put a lin subfolder inside the Default styles folder and I get no Runtime line but just a picture of a folder in the thumbnails of styles.
                        Baffled!
                          weird.. i'm now getting the same thing as you chris..
                          i can't get runtime to show up again.
                            CRSeventy
                            What is this runtime? Do you folks think it will effect something?
                            What about deleting the whole program? Or plists?
                            Kind regards,
                            Chuck
                              CRSeventy
                              [attachment=0:iy42ai4q]<!-- ia0 -->screen 5.jpg<!-- ia0 -->[/attachment:iy42ai4q]
                              I don't have any folders in other folders. Before I knew about how to add them I was just trying to drag them into the styles menu window or double clicking on them and Style Builder would open.
                              Kind regards,
                              Chuck
                                chrisjk
                                Chuck,
                                I doubt very much that it's anything to worry about - I'd just leave it.
