    Plugin windowizer for the mac
    6 Posts 2 Posters 2.0k Views 2 Watching
      susangohd
      How do I successfully install the plugin windowizer into my Mac computer? I have sketchup pro and my operating system is OS X. I have downloaded it from smustard.com into the proper location on my harddrive but it doesn't show up when I open sketchup. Any ideas?
      Susan Gohd
      susangohd[at]gmail[dot]com
        Are there 4 'windowizer*' files in the Plugins folder?
        If so... try to select a face and right-click = context-menu - that might have Windowizer near the end of the list ?
        πŸ˜•
          susangohd
          πŸ˜•
          Thanks for the suggestion--unfortunately still unsuccessful. I have in my harddrive in the plugins folder, a subfolder called "windowizer30bs" and in that folder I have the following rb scripts-- arraysum.rb, EntsGetAtt.rb, getMaterials.rb, offset.rb, readme.txt, windowizer.rb. When I open sketchup, nothing shows in the plugins drop down and when I right click on a face I don't get the options you mentioned in your reply. Any other ideas?
          Susan
            OK πŸ’­
            You must put all of the 5 .rb [Ruby] script files directly into the Plugins folder - there is another file [Readme.txt] that can stay in its folder - it just has some instructions in it and doesn't 'load'.
            My earlier advice related to the paid v4 not the free v3 hence the difference in the file count...
            Any scripts you get should normally go directly into the Plugins folder - sometimes a Ruby loads subsidiary some files from a sub-folder [but these will usually come zipped into sub-folders already] - AND in the Windowizer case all of the .rb files simply go into the Plugins folder...
            When SUp runs it loads any .rb files in the Plugins folder - those in sub-folders are not loaded unless a script in the Plugins folder does so deliberately...
            Once you have moved your Windowizer and the other related files into Plugins, and restart SUp you will get a new Plugins Menu item, and probably a context-menu [when a face is selected?]...
            πŸ€“
              susangohd
              @tig said:
              OK πŸ’­
              πŸ€“
              Thank you soooooo much.--I moved the .rb flles out of their folder as you stated and finally success at last!!!!! Should I upgrade to v4?
                Version 3 is still pretty good - v4 has to be paid for [though not that much $], but then it does have some advantages and a nice web-dialog interface etc - I suggest that you try v3 first to understand what it does and then think if v4 has advantages you need/want...
                The 'Smustard' site has some more info on v4... πŸ˜‰
