    Old escena
    19 Posts 10 Posters 1.7k Views 10 Watching
      rcossoli
      Hello everyone.
      This is an old scene that Majid went up to the forum so that everyone could render it to your liking, some years ago.
      I recently found it and went back to make an image.
      http://img145.imageshack.us/img145/6366/prueba10copia.jpg
      Greatings
      C&C Are wellcome...
      THREEDIMENSIONSWEB dot COM
        Great render. Which engine?
          rcossoli
          Is vray 1.5 and photoshop cs3 πŸ˜„
            Speaker
            Nice render but whats up with the wall on the left? It looks very weird. Seems that thereflection has comletly merged with the backgroud πŸ˜•
            http://www.youtube.com/user/latvietis1234
            • artysmediaA Offline
              artysmedia
              Very good render! πŸ‘ πŸ‘ πŸ‘
              Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
              Blog: Artysmedia
              • majidM Offline
                majid
                it is not my scene 😎 πŸ˜†...nice that you've njoyed it... left glass wall beside the stairs need less opacity in my sight..... very nice render mate indeed πŸ‘ ,I was missing my friend paintings too πŸ˜‰ (both belong to him)
                also let me put the link to model/discussion: http://forums.sketchucation.com/viewtopic.php?f=80&t=17207&st=0&sk=t&sd=a&start=15
                  rcossoli
                  Thank you all for your comments, I'll make it again this image to correct all those mistakes, greetings
                    D-space
                    Nice render Rcos!
                    Definetly you've been progressing really well with the renderings.
                    Just thought adding couple of lights to the lamps might be interesting and probably after that you can share some setting tips as well. πŸ˜„
                    http://blibestmentalt.no/54981
                    • EarthMoverE Offline
                      EarthMover
                      Wow, quite an amazing render. The shadows and the color bleeding are perfect. Color looks like LInear Workflow with gamma correction. In some respects, it's better than a photo!! πŸ‘ πŸ‘
                      Content Creator at Skapeup
                        rcossoli
                        thank you all for the comments and D-space and EarthMover.
                        Here I leave the settings you use for this interior, I hope you find it useful.
                        Visopt:
                        http://www.megaupload.com/?d=3Y841KJ0
                          pibuz
                          Hi all! Hope I don't steal the thunder of the great image rcossoli has rendered: I had a look at Mahjid's model and, given the beauty of the scene, I decided to give it a try with Indigo Renderer. It is only a wip but I'd be glad if you guys could point me in the right directions..
                          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                            rcossoli
                            very good picture, maybe we have to fix a little the tone of the lighting in photoshop, so that there is so lit areas and other somewhat obscure, but very good job, congratulations
                              pibuz
                              I think you will be happy about the progresses I did - WITHOUT knowing your opinions - last night. I worked a little on the glass material on the left (which I still don't like a lot), I adjusted some materials and tried the lighting with HDR only (maybe not the right choice, but one has got to try). This is the result after 9hours of calculations and a little postpro.
                              http://img2.pict.com/f4/13/71/2798519/0/300/pshopped.jpg
                                rcossoli
                                exellent the glass in the left, congrats...
                                save it renders in the gallery of work I like and I see on the web
                                • olisheaO Offline
                                  olishea
                                  wow i missed these!! hdri lighting looks very natural yet intense πŸ‘ . but it can leave resultant image a little noisy from time to time (higher quality hdri don't do this.....as much)
                                  did you use hdri AND sunlight for the first image? cos the lighting looks very good for just sunlight!
                                  stunning work! πŸ˜„
                                  oli
                                    pibuz
                                    Hi Oli! thank you for your reply: I'm always curious when you post a new work of yours, they're really excellent, very inspiring.
                                    My images are only two, actually: the first one of this topic, which I suppose to be lit by sun/sky only btw, is Rcossoli's. The second and the third images in this topic are mine: the last image is only HDR (indigo is astonishing sensible concerning EXR maps!), the previous was sun/sky only, since sun/sky+environment mapping are still not supported by Indigo Renderer. They're working on it, though..
                                    • olisheaO Offline
                                      olishea
                                      thanks for the reply and info πŸ‘
                                      keep up the great work
                                      oli
                                        dspace
                                        Hi pibuz, I think you did a awesome job with unbiased render.
                                        What render preset would you choose? MLT, PT, BPT..etc?
                                        And how much samples would you shoot to achieve such quality? πŸ˜„
                                          pibuz
                                          thanks again Oli!
                                          Dspace: I don't recall the spp value at the moment. It rendered something like a night and half-a-day, maybe reaching something about 1000s/px. But I could easily be wrong.
