    Float toolbar on creation?
    45 Posts 7 Posters 3.6k Views 7 Watching
      @tig said:
      The entry ToolbarsUser-Summary > Bars gives the total number of 'user toolbars' so you can construct a loop to go through to find each one with NN ...
      Sketchup.read_default('ToolbarsUser-Summary', 'Bars', nil)
      This just returns 1 for me. The registry value is 49.
        It should return that value BUT I don't even get 1 - I get nil ???
          I wonder if Sketchup.read_default prevents access to SU's own registry values. Might have to use the Win32 API - or have anyone been able to access any of the other SU registry values?
          I can only get S ketchup.read_default to return correct values for what Sketchup.write_default has created. 😕 thought this could be an easy cross platform method for SU settings... 😞
            Doing some tests:
            require 'C;/Ruby/lib/ruby/1.8/win32/registry.rb'
            module TT_Test
              def self.toolbars
                toolbars = []
                begin
                  path_summary = 'Software\\Google\\SketchUp7\\ToolbarsUser-Summary'
                  Win32;;Registry;;HKEY_CURRENT_USER.open(path_summary) { |reg|
                    bars = reg.read_i('Bars')
                    (0..bars-1).each { |i|
                      section = "ToolbarsUser-Bar#{i}"
                      begin
                        path_toolbar = "Software\\Google\\SketchUp7\\#{section}"
                        Win32;;Registry;;HKEY_CURRENT_USER.open(path_toolbar) { |r|
                          r.each { |subkey, type, data|
                            if type == Win32;;Registry;;REG_SZ && subkey == 'BarName'
                              toolbars << data
                              break
                      rescue
                        next
                  return toolbars
                rescue
                  return nil
              end # def
            Gets an array of Ruby Toolbars. Work on PC - but requires registry.rb. Will look into calling the Win32 API directly so it only requires Win32API.
            (I'm not sure how to deal with requirements of standard ruby libraries. include the registry.rb with my plugin and load only if it isn't defined? require 'C:\ruby\lib\ruby\1.8\win32\registry.rb' if defined?(Win32::Registry).nil?)
            How do you read settings on OSX? Where are these settings stored?
              The Mac has 'plist' files like an 'ini' file == the registry...
                Does OSX have an API to read it, or do you just open it and parse it yourself?
                  I am Macless. I don't know about plist API readers ...
                  Here is a 'plist' set someone gave me for info - it is 'readable' - just about...MacPlistArchive.zip
                  Here's another useful link http://developer.apple.com/documentation/MacOSX/Conceptual/BPRuntimeConfig/Articles/ConfigFiles.html
                  • C
                    chrisjk
                    There are plist editors available that make the task much simpler by parsing it for you and showing what can be changed etc. eg http://www.macupdate.com/info.php/id/14363
                      I'll check that out. I got an old Mac mini to test on.
                        hmm... the Info.plist file in the Sketchup application package does not contain the same info we see in the Windows registry...
                          Jim
                          I can't seem to get a handle on the Large Tool Set to hide it, any ideas?
                          i.e. these don't work:
                          UI.set_toolbar_visible("Large Tool Set", false) UI.set_toolbar_visible("LargeToolSet", false)
                            Yea - it's untouchable.
                            UI.toolbar_names
                            ["Standard", "Principle", "Camera", "Drawing", "Edit", "Construction", "Walk", "DisplayMode", "StandardViews", "Section", "Google", "GettingStarted", "VCB"]
                            That's the only ones we can get. And this is on PC. On Mac it's two completely different names.
                              I've managed to get a list of Ruby created toolbars on PC.
                              But on Mac I got some problems.
                              I found a plist at /Users/<user>/Library/Preferences/
                              One com.google.sketchupfree.plist and one com.google.sketchupfree7.plist
                              What I'm not sure how to is:
                              1. find the current user so I know the path to the plist
                              2. the name of the plist - which I think is related to the application id. http://developer.apple.com/mac/library/documentation/MacOSX/Conceptual/BPRuntimeConfig/Articles/UserPreferences.html#//apple_ref/doc/uid/20002092 Need a way to get the application’s bundle identifier for the Sketchup version the script is running in.
                              3. the toolbar names I get from these files doesn't seem to be 100% complete. think they might only appear if they've been shown at some point.
                              • C
                                chrisjk
                                I suspect the com.google.sketchupfree7.plist refers to a later install and that you can delete the other (maybe from a SU6 install?) without problems - just rename it temporarily and try .
                                I only have com.google.sketchuppro7.plist; com.google.sketchuppro7.LSSharedFileList.plist; com.google.LayOut.plist; com.google.LayOut.LSSharedFileList.plist; com.google.style_builder.plist
                                All clearly related to my SU 7 pro installation
                                • wind-borneW
                                  wind-borne
                                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                                  %(#BF80BF)[SU 8 pro
                                    Yes - I have SU6 and SU7 installed.
                                    The thing is - I need a way to determine the filename of the preference file for the Sketchup version the script is running under.
                                    From this link: http://developer.apple.com/mac/library/documentation/MacOSX/Conceptual/BPRuntimeConfig/Articles/UserPreferences.html#//apple_ref/doc/uid/20002092
                                    The name of each file in Library/Preferences is comprised of the application’s bundle identifier followed by the .plist extension. For example, the bundle identifier for the TextEdit application is com.apple.TextEdit so its preferences file name is com.apple.TextEdit.plist.
                                    But I have no idea of how to obtain the bundle identifier...
                                      Found the username in the ENV array. Still need to get the bundle ID.
                                        Ok - made some progress. Got code working on both Windows and OSX 10.4 (SU7.1). Other systems and versions untested.
                                        Note that there are still issues. This code needs to be tested more.
                                        • On Windows it require registry.rb and Win32API from a normal ruby installation. Not sure how to bundle this - in terms of license and general practicability.
                                        • On OSX it appears that toolbar names only appears in the plist if it has previously been shown at some point. If it hasn't then there isn't any trace of it. Looking for other source for the names.
                                        • I'm not familiar with how to get OSX data - so it's a bit of hacky brute force approach. Might be a better method to get the data. Certainly needs testing.
                                        Work In Progress
                                          The Win version will list old toolbar names - toolbars that are no longer present, but still got remains in the registry.
                                          Was thinking of running a loop testing against UI.toolbar - but it will create a new toolbar if given the name of a non-existent toolbar. Acts like UI::Toolbar.new.
                                            For Windows - I'm wondering if it'd be an option to use the Win32 API to read the menu items from the Toolbar menu...
                                            • 1 / 3
