    SU7 box.rb doesn't work as in SU6
    11 Posts 3 Posters 824 Views 3 Watching
      anar
      I've just jumped from SU6 to SU7.1.
      I just figured out that the box.rb script (Draw/Box) doesn't work as expected (like in SU6).
      It should ask for the box dimensions but doesn't.
      It also turns the scene into X-Ray mode which is not expected.
      Is it the same for you ?
      Does anyone know why it doesn't act anymore like in SU6 ?
      The two box.rb scripts (SU6 and SU7) are looking similar...
      Strange...
        What does the Ruby Console say when you try to run it ?
        Is it parametric, is parametric.rb loading etc ?
          anar
          Hi TIG,
          having a look at the ruby console window is the first thing I've done but it says nothing at all...
          Have you tried it by yourself and does it do the same for you ?
          Thanks for your reply.
          Very much appreciated !
            Works fine for me...
            I thought it might be a language_handler thing for you ? Perhaps not...
            Try renaming it box.txt and restart SUp - it won't load.
            Now in the Ruby Console type load"box.txt" to load it.
            Any errors ?
            Now run it from the last item in the Draw Menu 'Box' - any errors ?
            Any box ?
              anar
              As for the language_handler I don't think so because I only use English both for SU and all the plugins that I add.
              I've tried what you suggest :
              • rename with .txt extension
              • launch SU7 : it doesn't like it because in examples.rb it can't find box.rb anymore
              • tried to load the txt as you suggested (added "Examples/" to the path)
              • Ruby console says : true
              • Clicked on Draw/Box and everything is OK
              Now can you explain that ?
              Why wasn't it working right the first time with the Box.rb instead of .txt ?
              And what should I do next ?
              Can I rename it back to .rb or must I allways load the .txt by hand instead ?
              It's weird, isn't it ?
              Anyway I would have never though of doing that !
              Thank you TIG !!!
                Something is loading out of order so that it fails ?
                If you must have a 'box' tool rename a copy xbox.rb and put it into Plugins/
                Disable Examples.
                You should get Box under Draw still?
                I think it's $exStrings that's setting too late ?
                Type $exStrings in the console to see what's in it...
                Alternatively just use this 'DE-$exStrings'd' version...box.rb
                  Remove xbox.rb - add my box.rb - should work ?
                    anar
                    TIG,
                    done what you suggested :
                    • copied "Examples/box.rb" into "Plugins/xbox.rb"
                    • disabled Examples in SU (Preferences/Extensions) which can only take place after SU restart
                    • closed and restarted SU
                    • click on "Draw/Box" but it does the same as in my first post : draws a box without asking for dimensions and turns SU in X-Ray mode
                    • typed "$exStrings" in Ruby console and here is the result (I don't know what to understand) :
                    $exStrings
                    #<LanguageHandler:0x5be77f8 @strings={"Select first end"=>"Select first end", "Point at Center"=>"Point at Center", "Box"=>"Box", "Create Box"=>"Create Box", "Material"=>"Material", "Adds examples of tools created in Ruby to the SketchUp interface. The example tools are Draw->Box, Plugins->Cost and Camera->Animations."=>"Adds examples of tools created in Ruby to the SketchUp interface. The example tools are Draw->Box, Plugins->Cost and Camera->Animations.", "Select By Material"=>"Select By Material", "Select By Layer"=>"Select By Layer", "Select second end"=>"Select second end", "Box Dimensions"=>"Box Dimensions", "Cost"=>"Cost", "Total Cost Estimate"=>"Total Cost Estimate", "Stop Spinning"=>"Stop Spinning", "Spin View"=>"Spin View", "Animations"=>"Animations", "Default"=>"Default", "Assign Estimate to Material"=>"Assign Estimate to Material", "Cost Estimate"=>"Cost Estimate", "Ruby Script Examples"=>"Ruby Script Examples", "Layer"=>"Layer", "Width"=>"Width", "Compute Estimate"=>"Compute Estimate", "Assign Estimate to Faces"=>"Assign Estimate to Faces", "Hide Rest"=>"Hide Rest", "Depth"=>"Depth", "Height"=>"Height", "Cost By Material"=>"Cost By Material", "Create Cylinder"=>"Create Cylinder", "Could not find Material named"=>"Could not find Material named", "Cost per sq. foot"=>"Cost per sq. foot", "FPS"=>"FPS"}>
                    • used the alternative "box.rb" that you provided : I've put it in "Plugins/Examples" and enabled Examples again. Click on "Draw/Box" and it works find !
                    I did have a look at your box.rb to check the differences with the original one.
                    I can see the line you updated but as I've never done any Ruby it's hard for me to understand...
                    My very best regards for your kind help !
                      anar
                      Sorry TIG.
                      I updated my post while you where answering...
                      Look at the last point of my previous post to see what I've done.
                      Works fine now !
                      Thank you very much !
                        anar
                        Well I've been a little too fast to anounce that it works fine...
                        I've closed SU and started it again.
                        And again I have the problem !
                        I've tried to put your alternative box.rb directly in "Plugins" instead of "Plugins/Examples" but it still doesn't work !
                        The only way I can have it to work is by loading it myself by either :
                        • load it using the Ruby console
                        • load it via "as_pluginloader.rb"
                        • load it via "Windows/Preferences/Extensions/Ruby script examples"
                        Box.rb is usefull for creating a box in only one click instead of having to draw a rectangle and extrude it.
                        It's going to miss me if I don't have it !
                        And it's a pain in the a## if I must load it each time I start SU !
                        Honestly I don't understand what's wrong with my SU as you told me it was OK for you...
                        Am I the only one with this wierd problem ?
                        • F Offline
                          frankc3250
                          I too have a mac and I am having the exact same problem and get the same results after upgrading from 6 to 7.1 I did all the work arounds list in this post and got the same results as Anar
