    [Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
    109 Posts 23 Posters 92.2k Views 23 Watching
    • X
      xrok1
      • Chris FullmerC
        @thomthom said:
        The Core doesn't have any GUI - nor does it 'do' anything which the end user can see.
        Check the modules for what they can do. So far I think it's just StreetGen available.
        Yeah, its a pretty killer app we've built so far! 🤣
          remus
            It's he thought that counts, ... right?
            • T
              tug
              HI thom.-
              Now it works perfectly. I found some incoveniences if you have instaled several plugins more at the same time: MODULOR, 1001bit and lightup you can't use CityGen, Sketchup crashed. Please review this post and check it. I'd tried for four days diferents combinations of configurations, and after all I'd put these plugins in another sketchup's instalation.
              Good jod and wait for news for this nice application.
              Jann
                That's odd. Not sure why any of those would affect anything. Essentially make any difference between 0.4.x and 0.5.x.
                Does any combination of these plugins crash - or is it with all of them?
                Personally I have 1001bit and Modulor - both of which works fine on my system.
                • T
                  tug
                  I seem it's a combination of these plugins, I don't know why, but I'd been all the weekend try con find the right combination and after all i opted to install Modulor in Skecthup 6 and now all works. I mean it's lightup which is the main problem, couse is just when is reading the protection or key from this plugin when sktchup crashed after install citygen.
                  maybe there must be developed some application to purge and depure all the plugins to be installed at the same time.
                  best regards
                  jann
                    hm... LightUp is the only app I don't have. I could try to install the trial - but I'm short of time this whole week. Maybe give Adam a prod and see what he says.
                      Jim
                      as of the 19-sep update, are you still using the google code repo? I noticed there were no updates when I tried to pull after the announcement.
                        This is from the repo. I just made an easy public download that was more up to date.
                        • F
                          Foun10Head-X
                          Bookmark...
                          Had a tough time trying to put the program in it.
                          So, I'd look forward to updates.
                          • fionmacoolF
                            fionmacool
                            Hi- This is an interesting project. Unfortunately I wasn't able to get all the files from both Core and Streetgen in the correct heirarchy in the plugins folder so I keep getting error messages. Is this a Mac problem? 👊
                            Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                              Depends on how you extracted it. Macs tend to create an extra folder when extreating - the files you need would be inside the first one.
                              (note - this depend on how you extracted it.)
                                Where can we find this plug "Modulor" ?
                                  http://www.modelur.com/
                                    THX 😄
                                    It's not exactly the same name 😆
                                      no ... but it's hard to juggle them eoueoue's... 😉
                                        Does it possible with your plug to generate "streets" with no round Corners?
                                        Set Angle Threshold to 180 degrees (or more).
                                        PS Are you interested by a little French translation of your Plug's UI?
                                        In the future, yes. But as it is now - this plugin is experimental and many things will change. (When I get around to work on it again.)
                                          here 0.01 as corner radius (Why not 0 possible)
                                          90° as Angle threshold
                                            Not possible to average for have an angle more straight?
                                            Because after there are some glitch when you make some functions with it
                                            vitraux_pour_Serge.skp
                                            • 4 / 6
