    SU2LUX Exporter for Sketchup 0.1-dev
    extensions
    8 Posts 7 Posters 2.9k Views 7 Watching
      dedmin
      (www.luxrender.net)
      • N Offline
        notareal
        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
        • jolranJ Offline
          jolran
          YIPPIE!!!!!!!!!!!!!!
          With GPU rendering under investigation this is interesting!
            pichuneke
            The new version exports textures!
            (www.luxrender.net)
            Testing my first render now!
            Forgive my spanglish...
              Khai
              more than GPU... the plan it seems is to combine CPU / GPU and Network Sharing into 1 seamless render option...
              that will fly....
              • soloS Offline
                that will fly....
                This 'Hybrid' model seems to be the next wave of render solution, Thea is also going this way, about time our GPU's got some action.
                • AdamBA Offline
                  AdamB
                  @solo said:
                  that will fly....
                  But its a complex trade-off. Because CPUs have much better flow control that GPUs so its easier to avoid doing work altogether.
                  For example LightUp is mostly CPU-based and performs around 1,000,000 samples / sec on the CPU side. Now you could imagine getting something going on the GPU that might be faster (and we plan to) but its very difficult to avoid doing work on GPUs. GPUs are built to execute a set of instructions in straight-line fashion - and they're spectacular at that - but sometimes working-smart can actually beat it.
                  I guess the pithy strap line is "The fastest ray is the one you never fire".
                    pichuneke
                    My "first" render (not exactly, as I have been reading Luxrender forums and I took the idea there.
                    640.jpg)
                    And I made this experiment for fun (colors are decreased in the rendered result, so is not accurate):
