    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
      AttributeDictionaries.to_a.length works.
        ComponentInstance.explode
        http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#explode
        Code example is irrelevant - doesn't show the use of .explode.
          RenderingOptions
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/renderingoptions.html
          FogColor
          # FogDensity
          FogEnd
          FogStart
          # FogType
          FogUseBkColor
          Bold entries returns nil.
          The RenderingOptions I get when I iterate the collection is:
          BackgroundColor
          BandColor
          ConstructionColor
          DepthQueWidth
          DisplayColorByLayer
          DisplayDims
          DisplayFog
          DisplayInstanceAxes
          DisplaySketchAxes
          DisplayText
          DisplayWatermarks
          DrawDepthQue
          DrawGround
          DrawHidden
          DrawHorizon
          DrawLineEnds
          DrawProfilesOnly
          DrawSilhouettes
          DrawUnderground
          EdgeColorMode
          EdgeDisplayMode
          EdgeType
          ExtendLines
          FaceBackColor
          FaceColorMode
          FaceFrontColor
          FogColor
          FogEndDist
          FogStartDist
          FogUseBkColor
          ForegroundColor
          GroundColor
          GroundTransparency
          HideConstructionGeometry
          HighlightColor
          HorizonColor
          InactiveHidden
          InstanceHidden
          JitterEdges
          LineEndWidth
          LineExtension
          LockedColor
          MaterialTransparency
          ModelTransparency
          RenderMode
          SectionActiveColor
          SectionCutWidth
          SectionDefaultCutColor
          SectionInactiveColor
          ShowViewName
          SilhouetteWidth
          SkyColor
          Texture
          TransparencySort
          If the differences is due to changes between SU version I hope the docs will say when they where removed instead of removing them from the manual. Good to know the history.
          • chrisglasierC
            chrisglasier
            Probably picked up before but I just noticed it. So just in case ...
            Drawingelement.visible=SketchUp 6.0+
            The visible= method is used to set the visible status for an element. This method performs an opposite function to the hidden= method.
            Arguments:
            visibility true if you want to hide the element, false if not
            Returns:
            status true if the element has been hidden, false if the element has not been hidden.
            • Dan RathbunD
              Dan Rathbun
              My previous post onSketchup::AttributeDictionarieshas been REVISED See the original post:
              http://forums.sketchucation.com/posting.php?mode=reply&f=180&t=17047#pr218516
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                AttributeDictionaries (Introduction )
                http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionaries.html
                You access this class not by performing an AttributeDictionaries.new but by grabbing a handle from an existing entity.
                ... which is refering to Sketchup::Entity.attribute_dictionaries
                http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#attribute_dictionaries
                @dan rathbun said:
                http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=208352#p208352
                This only works for model objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                UPDATE (2010JAN23-DanRathbun) PC ver 7.1.6860:
                REVISED (2010JAN28-DanRathbun):In, SU ver 7.1, IF the Dynamic Components extension is turned OFF, the entity.attribute_dictionariesmethod will appear to always return aSketchup::AttributeDictionariesobject for the entity, regardless of whether there are any memberSketchup::AttributeDictionary%(#4040BF)[objects.
                In addition, (if DCs are OFF,) all of the methods of the]Sketchup::AttributeDictionaryclass (except.name,) will no longer work!
                Theentity.attribute_dictionariesmethod was NOT changed in the previous release, as I thought. The method works as the API says it does, returning "nil if there are none." BUT the Dynamic Components extension must be enabled."
                There is also no way to determine how many Dictionary objects, there are within an AttributeDictionaries collection (NoMethods: .size, .length, .count, or .empty?)
                • Dan RathbunD
                  Dan Rathbun
                  Re: General
                  @richmorin said:
                  Class and method names could be turned into links
                  to the appropriate API page, for ease of navigation.
                  Rich, note the left Nav column. The second box labeled "Quick Reference" has exactly these Class index and Method index links.
                  Re: Array class Introduction
                  @richmorin said:
                  Specific
                  http://code.google.com/apis/sketchup/docs/ourdoc/array.html
                  > The SketchUp Array class adds ...
                  > SketchUp adds ...
                  The correct ruby term is **extends** (as in extending a base class.) The way it is currently worded, a reader might misconstrue that the class is a custom class within the Sketchup namespace (ie, Sketchup::Array ), which is NOT the case. My version would read " Sketchup extends the standard Ruby Array class with additional methods.."
                  @richmorin said:
                  (same subject... Array class Introduction)
                  > Specifically, it contains methods ...
                  > Specifically, it adds methods ...
                  The word ***add*** is better here, because it's more specific (as to the manner in which the base Array class was extended.)
                  Re: AttributeDictionaries.each
                  > ... all of the attributes dictionaries.
                  >                attribute
                  For clarity I would suggest rewording the method description as: " *The each method is used to iterate through the entire list of attribute dictionary objects*."
                  Throws an exception if there are no keys.
                  (1) What specific exception is thrown? KeyError or IndexError or a custom SU error class? (the API should state what it is we may need to trap with a rescue clause.)
                  (2) Error conditions are not documented in a uniform manner throughout the API. Sometimes they are noted in the method description paragraph; sometimes (as in this case,) as a separate paragraph of the description section; other times in the ***Returns:*** section. Perhaps it's time to add a third ***Exceptions:*** section list, where the list labels would be exception class names and the defintion text would be the reason why the exception is raised.
                  (3) Why does this method raise an exception, and the *.[]* method returns *nil* when there are no keys (or matches)? IMHO, the proper ruby way is to raise the correct exception in both cases, AND provide the *.empty?*, *.has_key?* and *.length* (or similar named) methods so scripts can use them in conditional statements when checking the Dictionary lists. Example:
                   model = Sketchup.active_model
                   attrdicts = model.attribute_dictionaries
                   if not attrdicts.empty?
                     attrdicts.each {|key,value| puts key.to_s+" is "+value.to_s }
                   else
                     puts "Dictionary List is Empty!"
                  It just seems strange, as these are Array or Hash type classes, and they didn't inherit some of the basic funtionality, that they should have. Which brings us to...
                  **(4) AttributeDictionaries.member?** is undocumented. Not that it does us any good, as it only takes an object, not a string name (returns false even for vaild dictionary names.) This means you need to know it exists in the first place, so why would we need to test it's membership? *.member?* is normally an alias for *.has_key?*, so if this method could be updated to ALSO take the dictionary string name, it would serve us well.
                  Re: AttributeDictionaries Introduction
                  This only works for [ruby:2bffgwcd]model[/ruby:2bffgwcd] objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                  REVISED (2010JAN28-DanRathbun) See later post (this forum):
                  [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=218516#p218516:2bffgwcd]http://forums.sketchucation.com/viewtopic.php?f=180&...p218516[/url:2bffgwcd]
                  [i:2bffgwcd]Re: AttributeDictionary Introduction[/i:2bffgwcd]
                  An Entity or Model object can have any number of AttributeDictionaries.
                  [url:2bffgwcd]http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionary.html[/url:2bffgwcd]
                  This is confounding the use of the two differnet class names. (The parent should have been named [i:2bffgwcd]DictionaryList[/i:2bffgwcd], or better yet, [i:2bffgwcd]AttributeLibrary[/i:2bffgwcd]. [as in: shelf space for many dictionary volumes.]) Actually each entity can have only 1 [ruby:2bffgwcd]AttributeDictionaries[/ruby:2bffgwcd] object. The sentecnce should read "[ruby:2bffgwcd]An Entity or Model object can have any number of AttributeDictionary objects[/ruby:2bffgwcd]."
                  Both AttributeDictionaries and AttributeDictionary Introductions should have an 'also see note' directing readers to Entity class methods [ruby:2bffgwcd].attribute_dictionary[/ruby:2bffgwcd] and [ruby:2bffgwcd].attribute_dictionaries[/ruby:2bffgwcd] on how to create them.
                  It would have been nice to have a [ruby:2bffgwcd]new[/ruby:2bffgwcd] method for the child dictionary objects at least. We could then call something like:
                  myEntity = Sketchup.active_model.selection[0]
                  # this is more intuitive
                  attrdict = AttributeDictionary.new("My Dictionary", myEntity)
                  # this is not so
                  attrdict = myEntity.attribute_dictionary("My Dictionary", true)
                    Layer.page_behavior
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
                    Only lists two flags:
                    LAYER_VISIBLE_BY_DEFAULT 0x0000,
                    LAYER_HIDDEN_BY_DEFAULT 0x0001.
                    But Layer.page_behavior= lists other constants.
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior=
                    * LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000,
                    * LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010,
                    * LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020.
                    Meaning the constants in the getter should be the same for the setter.
                    LAYER_VISIBLE_BY_DEFAULT: 0x0000 LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000 LAYER_HIDDEN_BY_DEFAULT: 0x0001 LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010 LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020
                    And .page_behavior can be any bitwise combination of these.
                      To create a layer which is only visible on a single page, you can set its page behavior flags to LAYER_HIDDEN_BY_DEFAULT | LAYER_IS_HIDDEN_ON_NEW_PAGES
                      When I used that to set the behaviour of a layer on a model I get an error message when I save saying that something was messed up and this is the result of SU fixing it:
                      Results of Validity Check.
                      The behavior for CLayer (178941) is not valid - fixed
                        Tools.pop_tool
                        http://code.google.com/apis/sketchup/docs/ourdoc/tools.html#pop_tool
                        Returns: tool
                        the last pushed Tool object.
                        I only get true or false.
                        • Dan RathbunD
                          Dan Rathbun
                          Sketchup::ViewObserver
                          http://code.google.com/apis/sketchup/docs/ourdoc/viewobserver.html
                          (Introduction Section > Code example:)
                          # This is an example of an observer that watches tool interactions.
                          The comment line should read:" # This is an example of an observer that watches **for changes to a view**."
                            WebDialog
                            http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html
                            The Ruby WebDialog class allows you to create and interact with DHTML dialog boxes from Ruby. This is the best way to generate complex, embedded UIs inside SketchUp, but it does generally require HTML and Javascript expertise.
                            If your goal is to simply display a website to your users, consider using UI.getURL, which will show them a web page in their default browser rather than inside a dialog in SketchUp.
                            See this blog post for a detailed, step-by-step example: http://sketchupapi.blogspot.com/2008/02/sharing-data-between-sketchup-ruby-and.html
                            No such thing as UI.getURL. But there is UI.openURL
                            URL not marked up as a clickable link.
                            • Dan RathbunD
                              Dan Rathbun
                              UI::WebDialog
                              Limiting the WebDialog Size and setting :resizable=false still allows MSIE window to have a working Maximize button on the captionbar. Clicking it maximizes the dialog (which should not be so.) The 'Size' option in the SystemMenu dropdown is greyed, as it should be, 'Maximize' in the menu is also active.
                              ` opts = Hash.new
                              other options set
                              opts[:resizable] = false
                              dlg=UI::WebDialog.new( opts )
                              dlg.min_height = 100
                              dlg.max_height = 100
                              dlg.min_width = 200
                              dlg.max_width = 200
                              dlg.set_size(200,100)
                              dlg.show`
                              _
                              • Dan RathbunD
                                Dan Rathbun
                                Sketchup.load
                                http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#load
                                The Sketchup.load method does NOT expose the wrap argument, so we can specify wrap=true for rbs scripts.
                                For some unknown reason, the Google team defeated, or just didn't pass the 2nd argument (wrap) on to the aliased standard load, when they overrode it to handle rbs decrypting.
                                Please fix this!
                                _
                                  View.draw_points
                                  http://code.google.com/apis/sketchup/docs/ourdoc/view.html#draw_points
                                  Bug in the system: http://forums.sketchucation.com/viewtopic.php?f=180&t=26404
                                  • Dan RathbunD
                                    Dan Rathbun
                                    UI::WebDialog
                                    The following methods need to be documented:
                                    %(#BF0000)[last_height
                                    last_height=
                                    last_width
                                    last_width=]
                                    We are also still wishing to know what the extra Mac parameter for WebDialog.new is for, ie:
                                    :mac_only_use_nswindow = boolean
                                    What's the difference? ... and what's the default?
                                    • Dan RathbunD
                                      Dan Rathbun
                                      UI::WebDialog.write_image
                                      http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#write_image
                                      The write_image method is used to grab a portion of the screen and save the image to the given file path.
                                      Arguments: **> %(#000000)[*image_path*]%(#E0E0E0)[______]%(#000000)[The destination path of the saved image. *top_left_x*]%(#E0E0E0)[______]%(#000000)[The x coordinate of the upper left] %(#E0E0E0)[__________________]%(#000000)[corner of the region to grab. *top_left_y*]%(#E0E0E0)[______]%(#000000)[The]%(#EF4000)[**x**]%(#000000)[coordinate of the upper left] %(#E0E0E0)[__________________]%(#000000)[corner of the region to grab. *bottom_right_x*]%(#E0E0E0)[__]%(#000000)[The x coordinate of the lower right] %(#E0E0E0)[__________________]%(#000000)[corner of the region to grab. *bottom_right_y*]%(#E0E0E0)[__]%(#000000)[The]%(#EF4000)[**x**]%(#000000)[coordinate of the lower right corner] %(#E0E0E0)[__________________]%(#000000)[of the region to grab.] **
                                      %(#EF4000)[(1) The y coordinate arguments should read 'y' and not 'x'.
                                      (2) The coordinates are relative (in the curent implementation,) to the origin of the webdialog's client area, not the screen origin.
                                      (3) The top_left_x and top_left_y arguments APPEAR to work (and also default to 0,0 of the client area.)
                                      BUG: The bottom_right_x and bottom_right_y arguments SEEM to always get set to top_left_x**+clientareawidth and top_right_y+**clientareaheight. Changing (specifying) these 4th and 5th arguments SEEMS to have no effect (at least on PC.)
                                      (4) So.. although omitted from the API, only the 1st argument is necessary. Simply specifying a file (of the imagetype desired,) produces an image of the WebDialog client area, by default.]
                                      FUTURE:
                                      (a) It is more intuitive, if the 4th and 5th arguments are just widthand heightoffsets from the top_x and top_y (respectively.)
                                      (b) I would like a 6th argument origin which would need to default to 'client', with the optional setting 'screen' so we can grab an image of the entire WebDialog (including frame and captionbar, etc.)
                                      • The top_x and top_y arguments should then default to the WebDialog's topleft xy screen position.* The 4th and 5th arguments should be width and height offsets, from the 2nd and 3rd arguments; and should default to the WebDialogs entire window width and height.* Coders should be able to increase the grabarea to perhaps include portions of other windows on the screen (which may be other dialogs or part of the Sketchup viewport. This may be for tutorial use or to show a result in SU, given a setting in a webdialog (such as when reporting a bug to a plugin developer.)
                                        (c) Because WebDialogs, are movable, and often resizable, it would be good to have WebDialog instance methods to get the current screen position, current total size, current client size as two-element arrays, which can be used to pass arguments into write_image or any other method.
                                      UPDATE: Just noticed that there are two undocumented methods that can satisfy the need for current total webdialog size. [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=230668#p230668:8pzn7g4t]See my next post...[/url:8pzn7g4t]
                                      _
                                      • Dan RathbunD
                                        Dan Rathbun
                                        API - Release Notes webpage error
                                        http://code.google.com/apis/sketchup/docs/releases.html
                                        The H2 Heading "What's new in SketchUp 7" is not displayed as a H2 heading.
                                        The error is caused by a missing '>' (greaterthan character) on the end of the preceeding <P> element closing tag, which is now: '</P'
                                        ie, snippit from current HTML source (line 378):
                                        ` %(#804000)[<p class="post"> </p
                                        <h2>What's new in SketchUp 7</h2>]`
                                          whoa! we can post comments to the API doc now?!? whoppie!
                                          • scottliningerS
                                            scottlininger
                                            Yes, you can finally comment directly in the API docs (scroll to the bottom of most of the pages). Hopefully this will help the community share their insights into the API.
                                            We are still working through the list of comments from this thread, so don't feel as if you must copy and paste your (excellent) feedback into the site. But you can if you want to. 😄
                                            Cheers,
                                            • Scott Lininger
                                              SketchUp Software Engineer
                                              Have you visited the Ruby API Docs?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 15 / 19
