    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
    • Dan RathbunD
      Dan Rathbun
      My previous post onSketchup::AttributeDictionarieshas been REVISED See the original post:
      http://forums.sketchucation.com/posting.php?mode=reply&f=180&t=17047#pr218516
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        AttributeDictionaries (Introduction )
        http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionaries.html
        You access this class not by performing an AttributeDictionaries.new but by grabbing a handle from an existing entity.
        ... which is refering to Sketchup::Entity.attribute_dictionaries
        http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#attribute_dictionaries
        @dan rathbun said:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=208352#p208352
        This only works for model objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
        UPDATE (2010JAN23-DanRathbun) PC ver 7.1.6860:
        REVISED (2010JAN28-DanRathbun):In, SU ver 7.1, IF the Dynamic Components extension is turned OFF, the entity.attribute_dictionariesmethod will appear to always return aSketchup::AttributeDictionariesobject for the entity, regardless of whether there are any memberSketchup::AttributeDictionary%(#4040BF)[objects.
        In addition, (if DCs are OFF,) all of the methods of the]Sketchup::AttributeDictionaryclass (except.name,) will no longer work!
        Theentity.attribute_dictionariesmethod was NOT changed in the previous release, as I thought. The method works as the API says it does, returning "nil if there are none." BUT the Dynamic Components extension must be enabled."
        There is also no way to determine how many Dictionary objects, there are within an AttributeDictionaries collection (NoMethods: .size, .length, .count, or .empty?)
        • Dan RathbunD
          Dan Rathbun
          Re: General
          @richmorin said:
          Class and method names could be turned into links
          to the appropriate API page, for ease of navigation.
          Rich, note the left Nav column. The second box labeled "Quick Reference" has exactly these Class index and Method index links.
          Re: Array class Introduction
          @richmorin said:
          Specific
          http://code.google.com/apis/sketchup/docs/ourdoc/array.html
          > The SketchUp Array class adds ...
          > SketchUp adds ...
          The correct ruby term is **extends** (as in extending a base class.) The way it is currently worded, a reader might misconstrue that the class is a custom class within the Sketchup namespace (ie, Sketchup::Array ), which is NOT the case. My version would read " Sketchup extends the standard Ruby Array class with additional methods.."
          @richmorin said:
          (same subject... Array class Introduction)
          > Specifically, it contains methods ...
          > Specifically, it adds methods ...
          The word ***add*** is better here, because it's more specific (as to the manner in which the base Array class was extended.)
          Re: AttributeDictionaries.each
          > ... all of the attributes dictionaries.
          >                attribute
          For clarity I would suggest rewording the method description as: " *The each method is used to iterate through the entire list of attribute dictionary objects*."
          Throws an exception if there are no keys.
          (1) What specific exception is thrown? KeyError or IndexError or a custom SU error class? (the API should state what it is we may need to trap with a rescue clause.)
          (2) Error conditions are not documented in a uniform manner throughout the API. Sometimes they are noted in the method description paragraph; sometimes (as in this case,) as a separate paragraph of the description section; other times in the ***Returns:*** section. Perhaps it's time to add a third ***Exceptions:*** section list, where the list labels would be exception class names and the defintion text would be the reason why the exception is raised.
          (3) Why does this method raise an exception, and the *.[]* method returns *nil* when there are no keys (or matches)? IMHO, the proper ruby way is to raise the correct exception in both cases, AND provide the *.empty?*, *.has_key?* and *.length* (or similar named) methods so scripts can use them in conditional statements when checking the Dictionary lists. Example:
           model = Sketchup.active_model
           attrdicts = model.attribute_dictionaries
           if not attrdicts.empty?
             attrdicts.each {|key,value| puts key.to_s+" is "+value.to_s }
           else
             puts "Dictionary List is Empty!"
          It just seems strange, as these are Array or Hash type classes, and they didn't inherit some of the basic funtionality, that they should have. Which brings us to...
          **(4) AttributeDictionaries.member?** is undocumented. Not that it does us any good, as it only takes an object, not a string name (returns false even for vaild dictionary names.) This means you need to know it exists in the first place, so why would we need to test it's membership? *.member?* is normally an alias for *.has_key?*, so if this method could be updated to ALSO take the dictionary string name, it would serve us well.
          Re: AttributeDictionaries Introduction
          This only works for [ruby:2bffgwcd]model[/ruby:2bffgwcd] objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
          REVISED (2010JAN28-DanRathbun) See later post (this forum):
          [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=218516#p218516:2bffgwcd]http://forums.sketchucation.com/viewtopic.php?f=180&...p218516[/url:2bffgwcd]
          [i:2bffgwcd]Re: AttributeDictionary Introduction[/i:2bffgwcd]
          An Entity or Model object can have any number of AttributeDictionaries.
          [url:2bffgwcd]http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionary.html[/url:2bffgwcd]
          This is confounding the use of the two differnet class names. (The parent should have been named [i:2bffgwcd]DictionaryList[/i:2bffgwcd], or better yet, [i:2bffgwcd]AttributeLibrary[/i:2bffgwcd]. [as in: shelf space for many dictionary volumes.]) Actually each entity can have only 1 [ruby:2bffgwcd]AttributeDictionaries[/ruby:2bffgwcd] object. The sentecnce should read "[ruby:2bffgwcd]An Entity or Model object can have any number of AttributeDictionary objects[/ruby:2bffgwcd]."
          Both AttributeDictionaries and AttributeDictionary Introductions should have an 'also see note' directing readers to Entity class methods [ruby:2bffgwcd].attribute_dictionary[/ruby:2bffgwcd] and [ruby:2bffgwcd].attribute_dictionaries[/ruby:2bffgwcd] on how to create them.
          It would have been nice to have a [ruby:2bffgwcd]new[/ruby:2bffgwcd] method for the child dictionary objects at least. We could then call something like:
          myEntity = Sketchup.active_model.selection[0]
          # this is more intuitive
          attrdict = AttributeDictionary.new("My Dictionary", myEntity)
          # this is not so
          attrdict = myEntity.attribute_dictionary("My Dictionary", true)
            Layer.page_behavior
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior
            Only lists two flags:
            LAYER_VISIBLE_BY_DEFAULT 0x0000,
            LAYER_HIDDEN_BY_DEFAULT 0x0001.
            But Layer.page_behavior= lists other constants.
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/layer.html#page_behavior=
            * LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000,
            * LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010,
            * LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020.
            Meaning the constants in the getter should be the same for the setter.
            LAYER_VISIBLE_BY_DEFAULT: 0x0000 LAYER_USES_DEFAULT_VISIBILITY_ON_NEW_PAGES: 0x0000 LAYER_HIDDEN_BY_DEFAULT: 0x0001 LAYER_IS_VISIBLE_ON_NEW_PAGES: 0x0010 LAYER_IS_HIDDEN_ON_NEW_PAGES: 0x0020
            And .page_behavior can be any bitwise combination of these.
              To create a layer which is only visible on a single page, you can set its page behavior flags to LAYER_HIDDEN_BY_DEFAULT | LAYER_IS_HIDDEN_ON_NEW_PAGES
              When I used that to set the behaviour of a layer on a model I get an error message when I save saying that something was messed up and this is the result of SU fixing it:
              Results of Validity Check.
              The behavior for CLayer (178941) is not valid - fixed
                Tools.pop_tool
                http://code.google.com/apis/sketchup/docs/ourdoc/tools.html#pop_tool
                Returns: tool
                the last pushed Tool object.
                I only get true or false.
                • Dan RathbunD
                  Dan Rathbun
                  Sketchup::ViewObserver
                  http://code.google.com/apis/sketchup/docs/ourdoc/viewobserver.html
                  (Introduction Section > Code example:)
                  # This is an example of an observer that watches tool interactions.
                  The comment line should read:" # This is an example of an observer that watches **for changes to a view**."
                    WebDialog
                    http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html
                    The Ruby WebDialog class allows you to create and interact with DHTML dialog boxes from Ruby. This is the best way to generate complex, embedded UIs inside SketchUp, but it does generally require HTML and Javascript expertise.
                    If your goal is to simply display a website to your users, consider using UI.getURL, which will show them a web page in their default browser rather than inside a dialog in SketchUp.
                    See this blog post for a detailed, step-by-step example: http://sketchupapi.blogspot.com/2008/02/sharing-data-between-sketchup-ruby-and.html
                    No such thing as UI.getURL. But there is UI.openURL
                    URL not marked up as a clickable link.
                    • Dan RathbunD
                      Dan Rathbun
                      UI::WebDialog
                      Limiting the WebDialog Size and setting :resizable=false still allows MSIE window to have a working Maximize button on the captionbar. Clicking it maximizes the dialog (which should not be so.) The 'Size' option in the SystemMenu dropdown is greyed, as it should be, 'Maximize' in the menu is also active.
                      ` opts = Hash.new
                      other options set
                      opts[:resizable] = false
                      dlg=UI::WebDialog.new( opts )
                      dlg.min_height = 100
                      dlg.max_height = 100
                      dlg.min_width = 200
                      dlg.max_width = 200
                      dlg.set_size(200,100)
                      dlg.show`
                      _
                      • Dan RathbunD
                        Dan Rathbun
                        Sketchup.load
                        http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#load
                        The Sketchup.load method does NOT expose the wrap argument, so we can specify wrap=true for rbs scripts.
                        For some unknown reason, the Google team defeated, or just didn't pass the 2nd argument (wrap) on to the aliased standard load, when they overrode it to handle rbs decrypting.
                        Please fix this!
                        _
                          View.draw_points
                          http://code.google.com/apis/sketchup/docs/ourdoc/view.html#draw_points
                          Bug in the system: http://forums.sketchucation.com/viewtopic.php?f=180&t=26404
                          • Dan RathbunD
                            Dan Rathbun
                            UI::WebDialog
                            The following methods need to be documented:
                            %(#BF0000)[last_height
                            last_height=
                            last_width
                            last_width=]
                            We are also still wishing to know what the extra Mac parameter for WebDialog.new is for, ie:
                            :mac_only_use_nswindow = boolean
                            What's the difference? ... and what's the default?
                            • Dan RathbunD
                              Dan Rathbun
                              UI::WebDialog.write_image
                              http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#write_image
                              The write_image method is used to grab a portion of the screen and save the image to the given file path.
                              Arguments: **> %(#000000)[*image_path*]%(#E0E0E0)[______]%(#000000)[The destination path of the saved image. *top_left_x*]%(#E0E0E0)[______]%(#000000)[The x coordinate of the upper left] %(#E0E0E0)[__________________]%(#000000)[corner of the region to grab. *top_left_y*]%(#E0E0E0)[______]%(#000000)[The]%(#EF4000)[**x**]%(#000000)[coordinate of the upper left] %(#E0E0E0)[__________________]%(#000000)[corner of the region to grab. *bottom_right_x*]%(#E0E0E0)[__]%(#000000)[The x coordinate of the lower right] %(#E0E0E0)[__________________]%(#000000)[corner of the region to grab. *bottom_right_y*]%(#E0E0E0)[__]%(#000000)[The]%(#EF4000)[**x**]%(#000000)[coordinate of the lower right corner] %(#E0E0E0)[__________________]%(#000000)[of the region to grab.] **
                              %(#EF4000)[(1) The y coordinate arguments should read 'y' and not 'x'.
                              (2) The coordinates are relative (in the curent implementation,) to the origin of the webdialog's client area, not the screen origin.
                              (3) The top_left_x and top_left_y arguments APPEAR to work (and also default to 0,0 of the client area.)
                              BUG: The bottom_right_x and bottom_right_y arguments SEEM to always get set to top_left_x**+clientareawidth and top_right_y+**clientareaheight. Changing (specifying) these 4th and 5th arguments SEEMS to have no effect (at least on PC.)
                              (4) So.. although omitted from the API, only the 1st argument is necessary. Simply specifying a file (of the imagetype desired,) produces an image of the WebDialog client area, by default.]
                              FUTURE:
                              (a) It is more intuitive, if the 4th and 5th arguments are just widthand heightoffsets from the top_x and top_y (respectively.)
                              (b) I would like a 6th argument origin which would need to default to 'client', with the optional setting 'screen' so we can grab an image of the entire WebDialog (including frame and captionbar, etc.)
                              • The top_x and top_y arguments should then default to the WebDialog's topleft xy screen position.* The 4th and 5th arguments should be width and height offsets, from the 2nd and 3rd arguments; and should default to the WebDialogs entire window width and height.* Coders should be able to increase the grabarea to perhaps include portions of other windows on the screen (which may be other dialogs or part of the Sketchup viewport. This may be for tutorial use or to show a result in SU, given a setting in a webdialog (such as when reporting a bug to a plugin developer.)
                                (c) Because WebDialogs, are movable, and often resizable, it would be good to have WebDialog instance methods to get the current screen position, current total size, current client size as two-element arrays, which can be used to pass arguments into write_image or any other method.
                              UPDATE: Just noticed that there are two undocumented methods that can satisfy the need for current total webdialog size. [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=230668#p230668:8pzn7g4t]See my next post...[/url:8pzn7g4t]
                              _
                              • Dan RathbunD
                                Dan Rathbun
                                API - Release Notes webpage error
                                http://code.google.com/apis/sketchup/docs/releases.html
                                The H2 Heading "What's new in SketchUp 7" is not displayed as a H2 heading.
                                The error is caused by a missing '>' (greaterthan character) on the end of the preceeding <P> element closing tag, which is now: '</P'
                                ie, snippit from current HTML source (line 378):
                                ` %(#804000)[<p class="post"> </p
                                <h2>What's new in SketchUp 7</h2>]`
                                  whoa! we can post comments to the API doc now?!? whoppie!
                                  • scottliningerS
                                    scottlininger
                                    Yes, you can finally comment directly in the API docs (scroll to the bottom of most of the pages). Hopefully this will help the community share their insights into the API.
                                    We are still working through the list of comments from this thread, so don't feel as if you must copy and paste your (excellent) feedback into the site. But you can if you want to. 😄
                                    Cheers,
                                    • Scott Lininger
                                      SketchUp Software Engineer
                                      Have you visited the Ruby API Docs?
                                      Thanks Scott.
                                      Is it better that we post new comments in the actual APi docs now?
                                      I expect I'll put down a couple of notes on some of the key issues/gotchas,
                                      • scottliningerS
                                        scottlininger
                                        New notes should be posted directly to the api site. That way folks visiting the docs can see them immediately and can vote on the most helpful ones. As soon as we close out the issues in this thread, I will remove it from the forums.
                                        • Scott Lininger
                                          Eeexcellent!
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Don't you dare! This thread was started by ThomThom.
                                            (1) It is more than just Errors to fix in the API docs.
                                            • It has ideas about making the API Docs themselves better.* It has some sample code postings.* It has some Example code (incl. one posted by you yourself Scott regarding Materials Observer,) that would be lost if the entire thread was to be deleted.* It has some suggestions for new API features (new methods, etc.) [that need to be moved to some other thread first; I think there's a hard to find API WishList somewhere.]* It has some Questions posed (some of which have never been answered,) whose answers are not really content that actually will go into the API Programmer's Reference, but are of interest.
                                              (2) The Error postings are(to"we the customers",) a record of date and time, that an error or omission was logged.
                                            • As it was supposed to work, you were given Moderator rights, on the promise that you would MARK the Error posts, when they were fixed (bold Green with date.)* This would then give "we" the idea of the responce time the GSUPT in attending to these errors. Any customer, in any business sector should expect no less. Any Company or Business should expect to be judged on the basis of their past performance. (Unless of course, if your Toyota.) 😒* I can see only a couple, of 'fixed marks' in the whole thread. YES, we understand your busy, etc., but Jim and others had offered to do the 'marking' for you. You, however, insisted that it would be easier for you to mark them yourself.* I feel the record should stand, and I don't care who marks them; but those fixed should be marked as such.
                                              (3)I understand wanting to start fresh for the next API Revision, BUT...
                                            • If there was a Revision / Issue number on the API documents page(s) we would be able to correlate the Error threads HERE (on SCF,) with the doc pages over on code.google.com
                                            • THEN whenever you push an update, we can retire a thread here and start a new one for the next Revision.
                                              (4) In order to help make this work better in the future:
                                            • We need to stop being lazy, and post ONLYErrors to the API Error threads.* Post API Suggestions to the API WishList (me guilty!) 😳 * Post API Docs Discussions to the API Comments thread Remus just started.* We need to discuss the issue of whether a feature or method behavior is or is not an error, in a separate thread (it's own or the Discussion thread,) and then only when the issue is identified as a error, post a 'action item' in the current API Error thread.* The current API Error thread's title needs to be marked [current].* Retired API Error threads should be re-labeled [closed].* (Each API Error thread start post should have a standardized list similar to the 6 bullet items above, along with the current API Docs Revision / Issue number at the top.)
                                            @ThomThom: So, of course this means this whole post should be moved to the Discussion thread. (Everything from ThomThom's "whoa!" post on down.)
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 15 / 19
