    Menu.add_item algorithm problem
    11 Posts 3 Posters 1.2k Views 3 Watching
      Menu items get made as SUp launches, you can add menu items with code as you continue to use it BUT you cannot remove or modify existing items - therefore you need to have a general 'Delete friend..' item that opens a dialog populated with the required name(s) etc...
      • P
        Pauline01
        We can use the extension gtk2? i don't test for the moment.
          But that's a context menu. It gets created every time - so you can make menu items with different titles.
            Pauline, you want NameF to contain a user friendly name - but instead you're getting something else? What value is it NameF is getting?
            Also; "NameF" - in Ruby, variables start with lower case letters, and constants starts with upper case. "NameF" is a constant as you start with an upper case, while you use it as a variable.
            Another note:
            At some point you typed: a=Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s
            and after that point you don't need to refer to Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s as that has been refereed to by your variable a.
            Example:
            menu.add_item("Delete a Friend(" + NameF=Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s + ")") { delete_friend(NameF)}
            can simply be:
            menu.add_item("Delete a Friend(" + a + ")") { a }
            You see? You already have a variable a referring to Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s, so you don't need to create the variable NameF that also refer to the same thing.
              I apologize - I quickly scanned the code and didn't realize it was a context-menu, which as thomthom points out is capable of changes to suit the current circumstances and is NOT fixed...
              I don't think it is a menu issue... you have used capital letters to start your def's array and variable names - this is not allowed in Ruby for local variables - they must start with a lowercase letter e.g. nameFriend NOT NameFriend...
              This is a better version..
              require 'sketchup.rb'
              def delete_friend(nameFriend)
              UI.messagebox (nameFriend)
              #Menu
              if (not file_loaded?("zListFriend_config2.rb"))
                  UI.add_context_menu_handler do |menu|
                    if (Sketchup.active_model.selection.length == 1)
                     menu.add_separator
                     if ((Sketchup.active_model.selection[0].get_attribute("MyDico", "Name")) != nil)
                         i=0
                         a="x"
                         while (a != "" )
                                 nameFriends="NameFriends"+i.to_s
                                      a=Sketchup.active_model.selection[0].get_attribute("MyDico", nameFriends).to_s
                            if( a !="")
              #####menu of the friend list to delete them
              #####My problem; i don't arrive to pass the good name in the function "delete_friend", when i click on sketchup.
              ###i want to pass the name corresponding example; if i have the menu "Delete a Friend (Jim), i want to pass Jim in the function delete_friend.
                                               menu.add_item("Delete a Friend(" + nameF=Sketchup.active_model.selection[0].get_attribute("MyDico", nameFriends).to_s + ")") { delete_friend(nameF)}
              ###nameF is the good name on the menu title but don't pass the good name in my function
                            i += 1
                file_loaded("zListFriend_config2.rb")
              EDIT: thomthom beat me to it !!!!!!!!!! 👊 with a better analysis too... 💚
              • P
                Pauline01
                ok thx, i test your solution. I don't know what I'll do without you...really...😄
                NameF contained Just a person, and this person have a lot of friends (NameFriend)
                I created a function that associates an object to other objects. Each object is a person.
                So a person(NameF) conatained friends ("NameFriend"+i.to_s)
                Exemple: Jim (NameF) contained too Adrian(NameFriend1),Jaine(NameFriend2),Sylvain(NameFriend3)
                My menu is a list to delete a friend. I want to pass the NameFriend corresponding in the function "delete_friend" to know what a friend I delete.
                And in my menu, when i click on my menu, NameFriend is not the good variable, because:
                NameFriends="NameFriends"+i.to_s
                When i click on my menu NameF i have always the last NameF where i is max. So...it's good for the last friend but no for other.
                An other question? I do not know if I'm clear...
                  1.) Change all your variables to start with a lower case.
                  2.) menu.add_item("Delete a Friend(" + NameF=Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s + ")") { delete_friend(NameF)}
                  Does the menu say "Delete a Friend (Jim)"?
                  3.) You method delete_friend(): what is the content of the argument you pass to it? Have you tried to output the argument to the console?
                  Like
                  def delete_friend(name)
                    puts name
                    # Rest of your code...
                  • P
                    Pauline01
                    menu.add_item("Delete a Friend(" + namef=Sketchup.active_model.selection[0].get_attribute("MyDico", namefriends).to_s + ")") { delete_friend(namefriends)}
                    I want to pass the attribute corresponding, after in my function:
                    puts name
                    a=Sketchup.active_model.selection[0].set_attribute("MyDico",name,nil)
                    the problem, if i have for my object the attributes: name="Pauline"; namefriends1="Jim"; namefriends2="John" ect ect namefriends+i="a name" (pauline it's a person and Jim, john ect ect are friends, if i want delete a friend of the list i must say "namefriends corresponding to the friend is nil".)
                    in skectchup i have my menu with a list of: Delete a friend(Jim)
                    Delete a friend(john)
                    Delete a friend(anna)
                    when i click on one menu the namefriends is always anna because it's namefriends+i.to_s and so namefriends3 for all menu...
                    • P
                      Pauline01
                      up
                        Pauline: I split off the last posts Dan and I made. It turned into a separate discussion.
