    Menu.add_item algorithm problem
    11 Posts 3 Posters 892 Views 3 Watching
      Pauline01
      Hello,
      I don't find a solution, see in my code after "#####menu of the friend list to delete them", i have explain the problem.
      It's an algorithm problem.
      Thx.
      require 'sketchup.rb'
      def delete_friend(NameFriend)
       UI.messagebox (NameFriend)
      #Menu
      if (not file_loaded?("zListFriend_config2.rb"))
          UI.add_context_menu_handler do |menu|
            if (Sketchup.active_model.selection.length == 1)
      	    menu.add_separator
      	    if ((Sketchup.active_model.selection[0].get_attribute("MyDico", "Name")) != nil)
      			  i=0
      			  a="x"
      			  while (a != "" )
      		             NameFriends="NameFriends"+i.to_s
      	                     a=Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s
      				  if( a !="")
      #####My problem; i don't arrive to pass the good name in the function "delete_friend", when i click on sketchup.
      ###i want to pass the name corresponding example; if i have the menu "Delete a Friend (Jim), i want to pass Jim in the function delete_friend.
                                       menu.add_item("Delete a Friend(" + NameF=Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s + ")") { delete_friend(NameF)}
      ###NameF is the good name on the menu title but don't pass the good name in my function
      				  i += 1
        file_loaded("zListFriend_config2.rb")
      • TIGT Online
        Menu items get made as SUp launches, you can add menu items with code as you continue to use it BUT you cannot remove or modify existing items - therefore you need to have a general 'Delete friend..' item that opens a dialog populated with the required name(s) etc...
          Pauline01
          We can use the extension gtk2? i don't test for the moment.
            But that's a context menu. It gets created every time - so you can make menu items with different titles.
              Pauline, you want NameF to contain a user friendly name - but instead you're getting something else? What value is it NameF is getting?
              Also; "NameF" - in Ruby, variables start with lower case letters, and constants starts with upper case. "NameF" is a constant as you start with an upper case, while you use it as a variable.
              Another note:
              At some point you typed: a=Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s
              and after that point you don't need to refer to Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s as that has been refereed to by your variable a.
              Example:
              can simply be:
              menu.add_item("Delete a Friend(" + a + ")") { a }
              You see? You already have a variable a referring to Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s, so you don't need to create the variable NameF that also refer to the same thing.
              • TIGT Online
                I apologize - I quickly scanned the code and didn't realize it was a context-menu, which as thomthom points out is capable of changes to suit the current circumstances and is NOT fixed...
                I don't think it is a menu issue... you have used capital letters to start your def's array and variable names - this is not allowed in Ruby for local variables - they must start with a lowercase letter e.g. nameFriend NOT NameFriend...
                This is a better version..
                def delete_friend(nameFriend)
                UI.messagebox (nameFriend)
                #Menu
                       menu.add_separator
                           i=0
                           a="x"
                           while (a != "" )
                                   nameFriends="NameFriends"+i.to_s
                                        a=Sketchup.active_model.selection[0].get_attribute("MyDico", nameFriends).to_s
                              if( a !="")
                                                 menu.add_item("Delete a Friend(" + nameF=Sketchup.active_model.selection[0].get_attribute("MyDico", nameFriends).to_s + ")") { delete_friend(nameF)}
                ###nameF is the good name on the menu title but don't pass the good name in my function
                              i += 1
                EDIT: thomthom beat me to it !!!!!!!!!! 👊 with a better analysis too... 💚
                  Pauline01
                  ok thx, i test your solution. I don't know what I'll do without you...really...😄
                  NameF contained Just a person, and this person have a lot of friends (NameFriend)
                  I created a function that associates an object to other objects. Each object is a person.
                  So a person(NameF) conatained friends ("NameFriend"+i.to_s)
                  Exemple: Jim (NameF) contained too Adrian(NameFriend1),Jaine(NameFriend2),Sylvain(NameFriend3)
                  My menu is a list to delete a friend. I want to pass the NameFriend corresponding in the function "delete_friend" to know what a friend I delete.
                  And in my menu, when i click on my menu, NameFriend is not the good variable, because:
                  When i click on my menu NameF i have always the last NameF where i is max. So...it's good for the last friend but no for other.
                  An other question? I do not know if I'm clear...
                    1.) Change all your variables to start with a lower case.
                    2.) menu.add_item("Delete a Friend(" + NameF=Sketchup.active_model.selection[0].get_attribute("MyDico", NameFriends).to_s + ")") { delete_friend(NameF)}
                    Does the menu say "Delete a Friend (Jim)"?
                    3.) You method delete_friend(): what is the content of the argument you pass to it? Have you tried to output the argument to the console?
                    Like
                    def delete_friend(name)
                      puts name
                      # Rest of your code...
                      Pauline01
                      menu.add_item("Delete a Friend(" + namef=Sketchup.active_model.selection[0].get_attribute("MyDico", namefriends).to_s + ")") { delete_friend(namefriends)}
                      I want to pass the attribute corresponding, after in my function:
                      puts name
                      a=Sketchup.active_model.selection[0].set_attribute("MyDico",name,nil)
                      the problem, if i have for my object the attributes: name="Pauline"; namefriends1="Jim"; namefriends2="John" ect ect namefriends+i="a name" (pauline it's a person and Jim, john ect ect are friends, if i want delete a friend of the list i must say "namefriends corresponding to the friend is nil".)
                      in skectchup i have my menu with a list of: Delete a friend(Jim)
                      Delete a friend(john)
                      Delete a friend(anna)
                      when i click on one menu the namefriends is always anna because it's namefriends+i.to_s and so namefriends3 for all menu...
                        Pauline01
                        up
                          Pauline: I split off the last posts Dan and I made. It turned into a separate discussion.
