    Different timezone per scene?
    32 Posts 6 Posters 2.2k Views 6 Watching
      Will have to dig out one of the older projects when I get back at the office. Think I'd even set up a template with the common dates,shadow settings and scenes so I could just import any project.
        Jim
        I had a request to animate the North Angle between scenes. This may be related since these similar attributes are stored in the ShadowInfo. I checked V6 and it remembers the North Angle between Scenes, where as the latest 7.1 does not.
        Then I noticed a Page has it's own ShadowInfo (as well as the Model,) but setting the NorthAngle attribute for the page does not work either.
        • soloS Offline
          Looks like the needs of Google earth have dictated SU progress, this was possible before, have never needed it but do remember having shadows set up for different locations for different scenes before (version 5 I think)
            I'm sure it worked as late as SU6, as that's the SU version I started using.
            • Chris FullmerC Offline
              Locking down the north angle and model location (including time zones apparently) on a per model basis (instead of a per-scene basis) was implemented in 7.0. I'm pretty sure it had to do with some desireable Google Earth workflows, and simplifying things on their end for G.E interaction.
              I would guess they had to keep the placeholders in the scene info for old model compatability. But I think SU 7 ignores it. Maybe there is a possible workaround using a scenes observer Thom? Write a little Web Dialog that lets the user input angle and location and such and then store it in the scene info or wherever it gets stored (or wherever you want to put it). Then change the model location each time the user updates a scene. Well, i'm sure its more complex than my quick, shallow outline. But it might be possible if the scene observers are working well enough?
              • DavidBoulderD Offline
                DavidBoulder
                Here is my current setup for showing shadows from different locations. Mainly want to do this to make North facing elevation look better.
                For most project I generally break the project into a few major components that I can export to external files to save versions of the project.
                • Building
                • Site
                • Landscaping (trees site furniture etc)
                For one project in particular I saved all of these together as a master component. There was someone else working on a presentation, and I just had them swap out the master component when the needed it. Also the file had lots of high res photo matches and I was emailing across the country. So rather than re-sending the big file with the scenes, I sent the stripped down component without any scene info.
                This same thing can apply to have the same model shown from different locations or orientations; The trick is I used a separate SU file for each one, and then just imported the master component. Every time I updated the model, I would then update the component instance.
                David Goldwasser
                OpenStudio Developer
                National Renewable Energy Laboratory
                  I am currently using two extra scenes for my sun study of two different dates. I import the main model into each of the other models which is set up to their own time/date/timezone.
                  Works. But it still bothers me that this change was made in regard to maintaining old models/projects.
                    Jim
                    I can get a nice animation of the NorthAngle when clicking Scenes (using my plug-in,) but it doesn't work when playing the animation, nor does it export as video. 😠
                      Jim
                      So are we saying per-Scene Shadow Info is obsolete, and this is not a bug?
                        No, scenes do have different settings for shadow - time and darkness lightness etc. but it appear that the timezone property for scenes are ignored. This is not mentioned in the manual at all.
                        I reported it as a but - still awaiting reply. (SU-0623)
                          Actually - I'm not really sure. It's all confusing what's been changed.
                            I said it above, but maybe got skipped over, I think those values are there for legacy support. I think that is probably where SU 6 kept them, and read them. But SU 7 does not, and its on purpose.
                              hm... well, shadow info, time/date lightness, darkness on/off is set per page. But timezone is now dead except when it belongs to Model.
                                Which fits perfectly with my theory that they removed anything that might appear to change the location of a model from the scenes. The model still holds info there, but SU does not read it. It only reads location info from the model object. And time zone could be considered a location info.
                                  This is where I disagree.
                                  It'd be interesting to see what Google replies to my bug report though.
                                  Probably be worth asking them to clarify the changes into the manual as well.
                                    And yet - you can have different North direction per scene... πŸ˜’
                                      I think SU models still hold that information for legacy support, but I don't think it is being read or acknowledged anywhere in 7.0+, is it?
                                        You can set up scenes with different north angles in SU7.0/1 - no problem. Good thing for when you set up illustrations where you want to control the shadow to give the best description of the geometry - which will vary from scene to scene depending on the camera.
                                        So I don't see why one can't set different timezone per scene.
                                          That is odd. I would guess that ability was only left for the shadow illustration reason. All in all though, it does seem rather frustrating.
                                            yea - if you can set north angle for illustrational purposes, you should be able to set the timezone. Of the two - timezone doesn't affect the model location.
                                            • 2 / 2
