    Script to Delete Hidden Objects?
    17 Posts 7 Posters 2.2k Views 7 Watching
    • C
      chrisjk
      Um..... No 😳
      • Mike LuceyM
        Mike Lucey
        Tim, Let us know how you get on with TIG's solution. Thanks TIG 👍
          remus
          Wont that wreak havoc if youve got any hidden lines?
            @remus said:
            Won't that wreak havoc if you've got any hidden lines?
            YES - that's why I heavily caveated it - HE wants to do it, so on his head be it... 👊
            • C
              cjthompson
              Why not make it select all hidden entities? That way, he can see what is hidden, and then just press the delete key.
                Some might be inside instances and erasing across entities-sets might bugsplat ❓
                • Chris FullmerC
                  Would it be better to just move all geometry to layer 0 first, then delete all other layers.
                  Then there should not be this conflict, yeah?
                  • Tim DanaherT
                    Tim Danaher
                    Mike --
                    Will do... (if this file ever gets exploded).
                    Seriously, though, what an arseache.
                    Before I ran bomb.rb, I Unhid All, so there would be NO hidden geometry, but I'm stll getting these 'Your recent operation has caused geometry to become merged with hidden geometry'. How, if there's no hidden geometry?
                    And what's more, I'm also getting 'Your recent operation has caused geometry to become merged with geometry on a hidden layer'.
                    Now, here's a clue: I DON'T USE LAYERS. The only layer that there can be in my model is Layer 0, which is visible by default. I don't think the problem is with bomb.rb, it's some change made to the app itself.
                    Oh, and I only got TIG's script after I started the current Explode All operation (at 2 o'clock yesterday arvo).
                    Right. It's just finished.
                    This is what I got from the Ruby console:
                    erase_if_hidden
                    Error: #<NameError: undefined local variable or method `erase_if_hidden' for main:Object>
                    (eval)
                    edit: Oh, and this from the Load Error window:
                    ^Error Loading File erase_if_hidden.rb
                    /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/erase_if_hidden.rb:1: parse error, unexpected tCONSTANT, expecting kEND
                    def erase_if_hidden()
                    Sketchup.active_model.entities.to_a.each{|e|e.erase! if e.valid? and e.hidden?}
                    Sketchup.active_model.definitions.each{|d|d.entities.to_a.each{|e|e.erase! if e.valid? and e.hidden?}}
                    end#def
                    Cheers,
                    Tim
                    http://vizarch.blogspot.com
                      The file must be made with a plain-text editor [like Notepad.exe - don't know what that is on a Mac] NOT a word-processor ! I suspect hidden characters - here's the thing ready made erase_if_hidden.rb
                      • Tim DanaherT
                        Tim Danaher
                        Cheers, TIG --
                        I d/l'ed your file and put it in the plugins folder, and I'm happy to report it does exactly what it says on the tin!!!
                        Cheers,
                        Tim
