    [Plugin] Create 3d mesh from construction points... ver 1.3.
    14 Posts 6 Posters 20.1k Views 6 Watching
      j_forrester
      Is there a way of creating hard/sharp connections between adjacent points and then use a smoothing tag?
        kirill2008
        You mean to make a kind of NURBS surface or so?
        I think it's too sophisticated for me 😕 but surely it's possible to carry out though 😉
        BTW can anyone post a sample ruby code shows how to make subclass of SU Point3d class?
        • RunnerPackR Offline
          RunnerPack
          class NewPoint < Geom;;Point3d
          def method_name (param)
          #...etc.
          #...etc.
          If you just want to add a new method to the existing class, it's as easy as:
          class Geom;;Point3d
          def new_method_name (param)
          #...etc.
          Isn't Ruby great? 👍
          HTH,
          Amos
          You might have noticed... I'm a bit of a ferpectionist.
          • mitcorbM Offline
            mitcorb
            Thanks, kirill:
            By the way, you now have two threads for this plugin, version 1.0 and version 1.1
            mitcorb
              kirill2008
              mitcorb
              OK, I see 😕 . I'll update the script version within initial thread instead of posting new one next time.
                kirill2008
                @runnerpack said:
                Isn't Ruby great? 👍
                I agree! As for me, I'm going to hang Matsumoto's portrait at home. Yukihiro is my hero. The only problem is to find his high resolution photo.
                As a newbie to ruby, I must say I'm surprised a lot (almost shocked) that almost everything I code works (more or less).
                Thank's for sample code.
                Regards.
                  kirill2008
                  It is also possible to use "Draw horizontal contours..." command to draw contours of almost everything including SU components. It is only necessary to explode component, then make a group from exploded faces, then choose "Plugins>>Draw horizontal contours...".
                  [flash=425,344:2gt5jdh3]http://www.youtube.com/v/cRj2waPU6yk&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:2gt5jdh3]
                  • MALAISEM Offline
                    MALAISE
                    You 're welcome Kirill, each time I read your post, you give us new features using your Plugin.
                    Merci beaucoup ( thanks a lot )
                    MALAISE
                    • W Offline
                      wwwyoose
                      I have try on my mac Create 3d mesh from construction points... ver 1.3.
                      but it dont work what do I wrong.
                      It stop after first step see this picture
                      It looks verry good plugin to have what I see,
                      best Achim
                        kirill2008
                        @wwwyoose said:
                        best Achim
                        Most probably you did everything right, but the script did not process the points cloud for any reason. But I need a bit more information to find out what's the problem. So try to open ruby console window (Main Menu>>Window>>Ruby Console) then try to create 3d mesh again. Error code has to appear within ruby console window. Please copy this message and send it to me (you may send a private message or post error code here, or whatever you like), it may help to find the error within the script and fix it.
                        Note, that the current version can not process non-terrain point clouds correctly. Pnts2mesh.rb can create only terrain-like surfaces yet (only one z value for each xy). I'm thinking about free form points cloud processing, but it is not implemented yet.
                        • W Offline
                          wwwyoose
                          This is what the ruby consol did
                          Error: #<NoMethodError: undefined method *' for Point3d(197.735, -80.2246, 141.993):Geom::Point3d> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/pnts2mesh.rb:339:in create_init_mesh'
                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/pnts2mesh.rb:501:in `make_relief_mesh'
                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/pnts2mesh.rb:599
                          Best Achim
                            kirill2008
                            I decided to make 'pnts2mesh.rb' a part of 'LSS Toolbar'. This project is still under construction, but here you can take a look at how modernized version of 'pnts2mesh.rb' will finally work (skip to 5:30 for 'pnts2mesh.rb' revival demonstration).
                            [flash=560,315:rgpkvorn]http://www.youtube.com/v/8nbMaKKNkm8?version=3&amp;hl=ru_RU[/flash:rgpkvorn]
                            For now 'pre-alpha' version of 'LSS Toolbar' is available. Unfortunately it won't work on mac again... I need to find out how to adapt web-dialogs for 'Safari'. It'll take some time...
                            lss_toolbar_2_0_pre_alpha_5.zip
