    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 348.5k Views 71 Watching
      @driven said:
      looking at script changes , I wondered if this may be a problem for mac's it's not how you use to do it?
      cmd=UI::Command.new(textstring){extrudeEdgesByRails()}
      UI.menu("Plugins").add_item(textstring){cmd}
      cmd.status_bar_text=textstring+instructions
      if $extrusionToolbar
      cmd.tooltip=textstring
      cmd.small_icon="TIGtools/extrudeEdgesByRails16x16.png"
      cmd.large_icon="TIGtools/extrudeEdgesByRails24x24.png"
      $extrusionToolbar.add_item(cmd)
      end#if
      This method makes a $global variable pointing at the toolbar - that way a pre-existing toolbar can get extra buttons added as a ruby loads... Works fine on a PC - I'm wondering if Macs are so different...
      We need to hear from Mac users - if it's only happening to you then... if it's happening to all of them then... ๐Ÿ˜ข
        driven
        @tig said:
        Either the Mac has a different way of making 'empty' toolbars and adds a blank button from #extrusionToolbar.rb even before the others get made - which explains why it's first in the list, or something else is adrift...
        Other users' feedback is needed... There are hundreds of you :enlight:
        #extrusionToolbar.rb only gave one(1)tool image with EEbyR_V2.1 so this is only sinceV2.2 and the other updated EEtools
        and YEAH- where are the other Mac users.....
          cmoreink
          Hi TIG, much respect for your contribution to to this awesome community.
          QUESTION: for this plugin to work correctly I need to instal v1.0 (where the tool bar is), after that instal v2.2 of each (rail, vector, lathe and edges), is that right?
          thanks
          my portfolio
          • mitcorbM Offline
            mitcorb
            TIG:
            I have updated the Extrude Suite and activated the Toolbar Icons, which seem to work fine. I think it has already been mentioned once here that the selections in the Plugins drop down do not work if the icons are installed. I can confirm that on my home machine in SU6, for your information.
              thanks
              There's no particualr order of installing them. They load in alphanumerical order anyway...
              You do need the #extrusionToolbat.rb to make the toolbars.
              This loads first [because it starts with #] and if there's any other EEby... ruby in the Plugins folder then it makes a Extrusion Tools toolbar.
              If you have any of the four EEby.. rubies in the Plugins folder then they'll load, and if there's a toolbar made [i.e. you have #extrusionToolbat.rb and it's loaded etc] the EEby.. it adds a button for itself...
              It should also make a Plugins Menu item for itself - however, there's been some reports of problems with this - a fix if needed is on its way... ๐Ÿค“
                driven
                Morning TIG,
                UPDATE on the Mac extra button...
                I just did a complete brand new instal of SU7.1 + SU (standard issue) rubies on my wife MacBook (she left it at home, not me),
                I then downloaded into and unzipped all 4 EEby folder into the SU /Plugins/Examples folder, then copy/pasted 1 x #ex...;1 x deB...;1 x TIGGtools and 1 of each EEby...
                I then opened the other /Plugins/Example/EEby.../TIGtools folders one at a time and copy/pasted the contents into /Plugins/TIGtools and said yes replace duplicates
                I then trashed the zips and folders in Examples and fired up SU for the first time ever on that machine
                The upshot is I only have the four[4] correct buttons, hooray, however the plugin menu functionality is still missing.
                So the extra button must be a clash on my setup, so I'll remove DrivingDimensions and Kirril's rubies (as I've had global setting problems related to them before) and see if that sort's out my extra button issue.
                BTW... there all fantastic tools and I'm only trying to be helpful, so tell me if it's not.
                  driven
                  No, you are most helpful !
                  I think you are not getting anything in the Plugins Menu on a Mac
                  On my PC I am getting the Plugins Menu items BUT they do nothing - and give no errors !
                  Looking at a fix soonest...
                    driven
                    I see them, even on my now naked (ruby-less),but they don't work
                    I stripped out everything on my Mac, copied the entire (intact, clean, fresh, working with 4 Buttons) SU Plugins folder over my network from the wife's MacBook and I still get the fifth button, I may as well do a fresh instal of SU before I really need to get in with some work...
                      Here's v2.3 - a typo preventing the Plugins Menu item from working has been corrected. ๐Ÿ˜ณ
                      http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                        driven
                        @tig said:
                        Here's v2.3 - a typo preventing the Plugins Menu item from working has been corrected. :oops:
                        hi, after fresh instal of SU7, + v2.3, I have Plugin Drop-Down Menu functionality on EEbyR only, is the same typo in the others?
                        still got my extra Button, you'll just have to do an extra tool for it...
                        cheers john
                          @driven said:
                          hi, after fresh install of SU7, + v2.3, I have Plugin Drop-Down Menu functionality on EEbyR only, is the same typo in the others?
                          cheers john
                          You need to re-download any/all EEby.. tools - they all had the same typo for each ๐Ÿ˜ณ [the wonders of a last minute copy/paste !]
                          They are all fixed now ๐Ÿ˜„
                            driven
                            double success, only four buttons, Plugin Menu working and everything else back in...success...jpg
                            • boofredlayB Offline
                              boofredlay
                              I installed v2.3 but still only see the single EEbR button toolbar.
                              SU7, PC XP.
                                Have you downloaded all of the separate EEby.. rubies [..Edges,..Lathe,..Rails and ..Vector] from the other threads ?
                                You must have those in the Plugins folder too for their buttons to get made...
                                Also remember that their various lingvo and png files etc that come with each ruby need to go in the TIGtools folder in Plugins... ๐Ÿ’ญ
                                  boofredlay
                                  Ah, I understand. I have not downloaded the others. Thanks.
                                  • JClementsJ Offline
                                    JClements
                                    TIG:
                                    Any chance you could ZIP all of the related scripts which use your toolbar, together in one file?
                                      cmoreink
                                      Thank you TIG ๐Ÿ˜‰
                                      my portfolio
                                        driven
                                        Hi TIG,
                                        the fifth button comes and goes depending on the last saved state,
                                        if I turn Extrusion Toolbar off before quitting SU when I turn it back on it stays as 4 buttons for that session, any number of drawings.
                                        if I don't turn it off before quitting SU it reappears with a 5th button.
                                        not a big deal, but really hard to figure out when working on hi-poly drawings that I turn on and off all the time to let SU have a rest.
                                        Only just now found some time to put my finger on a pattern and test the theory.
                                        that's why it went away with the fresh instal and stayed away until I shut down for dinner, reappeared when I turned back on and has been subconsciously driving me nuts for the last 4 hours, even though it's not effecting anything else...
                                        It may just be my machine, so if any other Mac user with all 4 installed wants to quit SU with it (the toolbar) open and see if they get an extra button on restart, and let me know, I'd be grateful.
                                          Take a look here ๐Ÿ˜‰
                                            cmoreink
                                            Hi TIG, good news and bad news:
                                            good news: downloaded EEbE, EEbV and EEbL all work great and as you can see at screen shots I also have a nice toolbar with all icons
                                            bad news: downloaded EEbR and it does not work ๐Ÿ‘ฟ
                                            please look at the screen shots and tell me if I'm doing something wrong (I hope it's me) or is there a conflict?
                                            So I drew my 1st curve (not welded, not a group, it has 12 segments and it's as a one), I drew my 2nd and 3rd, click EEbR, selected 1st curve (profile, melding), selected 2nd curve (1st rail), selected 3rd curve (2nd rail), selected melding curve (1st curve, profile) and I got nothing. Only few "crosses) at each segment... what to do?
                                            [EDIT]
                                            so I decided to give one more try by selecting EEbR from Plugins menu instead of clicking on icon. When I click on Plugins menu and select EEbR from a pulldown menu I get nothing, I mean nothing, 0, it does not ask at the bottom of the screen to select the Profile Curve, etc. so I believe that there is a conflict somewhere...
                                            after drawing 3 curves I click on EEbR icon and select my 1st curve (profile, melding)
                                            2nd curve (1st rail) selected
                                            3rd curve (2nd rail) selected
                                            1st curve (melding, profile) selected with final outcome, crosses at each segment
                                            my portfolio
                                            • 19
                                            • 20
                                            • 1 / 20
