    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 383.6k Views 71 Watching
      If you extract [NOT drag/drop] the contents of this zip you should get three .rb files, which are the script itself, the deBabelizer script and the toolbar maker script. Also there should be a folder [TIGtools] containing the lingvo files and pngs for the buttons and an htm donation link, with a folder of its images too.
      The three rb files go into Plugins folder and the TIGtools folder goes into Plugins folder too. The script looks for the pngs to form the toolbar icons in there - so apparently you have messed up the folders as it's not finding them...
      If you extract a zip file any decent zip-application will keep the file/folder structure - you can either extract the contents directly into the Plugins folder where everything will be in the right place OR into a tempoarry folder on your desktop - and then move its contents to the Plugins folder later...
      Since some of the TIGtools folder's contents and also the other add-on .rb files might already exist answer Yes to overwrite them with these new versions...
      NOTE: Depending on your 'administrator' rights with Vista etc you might be getting incremented copied of files/folders - please look in Plugins and check - you should have one .rb for each of the EEby... scripts you've insatlled, one #extrusionToolbar.rb script to make the toolbar, one deBabelizer.rb to translate languages and one TIGtools folder which itself will contain several .lingvo [translation] files and .png images for the toolbar buttons, and also the htm donation link file and a folder of that file's images...
      If you have any duplicate folders combine their contents all into the original one and then erase the empty ones, and also any '..Copy..' .rb files you might find too.
      If this IS happening then it's probably best to extract zips to a temporary folder on your desktop and then move everything [keeping the same folder structure] into Plugins, overwriting any existing stuff...
      Hope this helps...
        @driven said:
        hi TIG,
        what is 'extrude by sweep' mentioned in the ruby text?
        'ExtrudeEdgesBySweep' was a proto-tool that's now abandoned [I had hoped for results different from EEbyR but the new algorithms produced inconsistent results that were almost identical anyway, so I gave up on it] - all references to it should have been removed - they is now, and will be omitted in any updates... Sorry for the confusion...
          driven
          no apology needed, most people don't read the rubies, and I just thought it was maybe yet another super-duper 'secret' tool that I'd missed and that it was maybe why I get a blank tool button.like this
          However, now knowing that it's not and still not having the ability to use any of the EE tools from the plugin menu, I've been trying a few things to get that functionality back and I can't.
          Basically
          1: I have a 'spare' Button that does nothing if there is any single EE tool installed (so, I'll get 2,3 or 4 buttons, never one)
          2: Plugin Menu function does not work with one or all EE tools installed (they are there) with or without #extrusionToolbar.rb.
          I don't think it's a 'Mac' thing, your scripts never give me those sort of issues, and it's not an install issue either, although Mac's do Copy/Paste + Drag/Drop differently to PC's, I know that and have a fairly bullet proof procedure I use all the time.
            @driven said:
            no apology needed, most people don't read the rubies, and I just thought it was maybe yet another super-duper 'secret' tool that I'd missed and that it was maybe why I get a blank tool button.[attachment=0:3504o1ud]<!-- ia0 -->BlankButton.jpg<!-- ia0 -->[/attachment:3504o1ud]
            Basically
            When you hover over the blank button what tooltip or VCB message do you get ?
            In the Plugins Menu do you have duplicate EEby.. entries ?
            I suspect you have two copies of something around somewhere... Are all your plugins in the a same folder ??
              How many tools must have now the Extrude Bar tools?
              • Bob JamesB Offline
                Bob James
                I get the two icons on the right (EEbR and EEbV), but what are the next two?
                  You can have 1, 2, 3 or 4 buttons, depending on which Plugins you have downloaded - which can be any of these - EEbyEdges, EEbyLathe, EEbyRails and EEbyVector... [EE=ExtrudeEdges - saves typing... damn I did it anyway 😒 ]
                  You also need #extrusionToolbar.rb which makes the toolbar when it loads [if any one of these other rb files is in the Plugins folder] - the other rubies then load and make a Plugins>Menu item and a 'Extrusion Tools' Toolbar button for themselves [if it finds the toolbar has been made beforehand] - if a button .png is missing [e.g. perhaps you have put it in the wrong place] you get a blank button but the tooltip and VCB texts should still work etc...
                    driven
                    No tooltip message, but it does toggle grey [on/off], effects nothing
                    No duplicates, even took out lath.rb, just in case
                    All my plugins are in same folder
                    #extrusionToolbar.rb is at top of list
                      I know Fredo has had problems with files being copied into duplicate Plugins folders in different places ? Any cahce of this ?
                      Any other Mac users getting similar problems with these tools ?
                      Any Mac users getting NO problems with these tools ?
                      Help appreciated... 😕
                        driven
                        and this one
                        TIGtools combined
                          @driven said:
                          and this one
                          That's right...
                          But what is the exact full path to your Mac's Plugins folder ? As I said some users seem to end up with 2...
                            Bob James
                            Is there a new version of #extrusionToolbar.rb that shows the fourth icon?
                            Mine is dated 1/19/2010.
                            I have:
                            extrudeEdgesByVector.rb
                            extrudeEdgesByRails.rb
                            extrudeEdgesByEdges.rb
                            extrudeEdgesByLathe.rb
                              I have:
                              #extrusionToolbar.rb was last modified on that date and is still at v1.0 - it's a very simple file that checks for any of these four main rubies and if any are found it makes the toolbar.
                              The main rubies then load in alphanumric order and make their menu item and check for the toolbar, and if that's found they add their button to it.
                              If they can't find the png images you'll get the blank button...
                              Either the Mac has a different way of making 'empty' toolbars and adds a blank button from #extrusionToolbar.rb even before the others get made - which explains why it's first in the list, or something else is adrift...
                              Other users' feedback is needed... There are hundreds of you ☀
                                driven
                                I have a shortcut folder shown in the earlier image, but it is an alias for this path
                                looking at script changes , I wondered if this may be a problem for mac's it's not how you use to do it?
                                cmd=UI::Command.new(textstring){extrudeEdgesByRails()}
                                UI.menu("Plugins").add_item(textstring){cmd}
                                cmd.status_bar_text=textstring+instructions
                                if $extrusionToolbar
                                  cmd.tooltip=textstring
                                  cmd.small_icon="TIGtools/extrudeEdgesByRails16x16.png"
                                  cmd.large_icon="TIGtools/extrudeEdgesByRails24x24.png"
                                  $extrusionToolbar.add_item(cmd)
                                end#if
                                  end#if
                                  This method makes a $global variable pointing at the toolbar - that way a pre-existing toolbar can get extra buttons added as a ruby loads... Works fine on a PC - I'm wondering if Macs are so different...
                                  We need to hear from Mac users - if it's only happening to you then... if it's happening to all of them then... 😢
                                    driven
                                    Other users' feedback is needed... There are hundreds of you :enlight:
                                    #extrusionToolbar.rb only gave one(1)tool image with EEbyR_V2.1 so this is only sinceV2.2 and the other updated EEtools
                                    and YEAH- where are the other Mac users.....
                                      cmoreink
                                      Hi TIG, much respect for your contribution to to this awesome community.
                                      QUESTION: for this plugin to work correctly I need to instal v1.0 (where the tool bar is), after that instal v2.2 of each (rail, vector, lathe and edges), is that right?
                                      thanks
                                      my portfolio
                                      • mitcorbM Offline
                                        mitcorb
                                        TIG:
                                        I have updated the Extrude Suite and activated the Toolbar Icons, which seem to work fine. I think it has already been mentioned once here that the selections in the Plugins drop down do not work if the icons are installed. I can confirm that on my home machine in SU6, for your information.
                                          thanks
                                          There's no particualr order of installing them. They load in alphanumerical order anyway...
                                          You do need the #extrusionToolbat.rb to make the toolbars.
                                          This loads first [because it starts with #] and if there's any other EEby... ruby in the Plugins folder then it makes a Extrusion Tools toolbar.
                                          If you have any of the four EEby.. rubies in the Plugins folder then they'll load, and if there's a toolbar made [i.e. you have #extrusionToolbat.rb and it's loaded etc] the EEby.. it adds a button for itself...
                                          It should also make a Plugins Menu item for itself - however, there's been some reports of problems with this - a fix if needed is on its way... 🤓
                                            driven
                                            Morning TIG,
                                            UPDATE on the Mac extra button...
                                            I just did a complete brand new instal of SU7.1 + SU (standard issue) rubies on my wife MacBook (she left it at home, not me),
                                            I then downloaded into and unzipped all 4 EEby folder into the SU /Plugins/Examples folder, then copy/pasted 1 x #ex...;1 x deB...;1 x TIGGtools and 1 of each EEby...
                                            I then opened the other /Plugins/Example/EEby.../TIGtools folders one at a time and copy/pasted the contents into /Plugins/TIGtools and said yes replace duplicates
                                            I then trashed the zips and folders in Examples and fired up SU for the first time ever on that machine
                                            The upshot is I only have the four[4] correct buttons, hooray, however the plugin menu functionality is still missing.
                                            So the extra button must be a clash on my setup, so I'll remove DrivingDimensions and Kirril's rubies (as I've had global setting problems related to them before) and see if that sort's out my extra button issue.
                                            BTW... there all fantastic tools and I'm only trying to be helpful, so tell me if it's not.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 19
                                            • 20
                                            • 12 / 20
