    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 230.7k Views 76 Watching
      romain210
      thanks a lot
        cupko
        Thanks for this!!
          theark
          Fantastic!! Many thanks
            t_gia197
            Great. So useful
            Thanks alot
            • mitcorbM Offline
              mitcorb
              this post deleted and re posted at Extrude Edges by Rails
              • mitcorbM Offline
                mitcorb
                This post resubmitted at Extrude Edges by Rails
                  This post deleted and re posted at Extrude Edges by Rails
                    This is v2.0 - it's now been deBabelized, with a combined Extrusion Tools Toolbar added and miscellaneous glitches tweaked...
                    http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                      Here's v2.1
                      A typo meant that the lingvo files didn't translate properly [an ES user spotted it...]
                        Here's v2.2
                        Lingvo files updated. FR=Pilou, ES=Defisto.
                          Here's v2.3 - a typo preventing the plugins menu item working has been corrected. 😳
                            DIEGO-RODRIGUEZ
                            tig. query
                            edges by edges, may function similar to edges by rail?
                            • Add option Smooth
                            • Remove requirement of Groups of Edges/Curves. used alone edges
                            is it possible?
                              @diego-rodriguez said:
                              tig. query
                              • Add option Smooth
                              is it possible?
                              It is possible, but I have left it as it was originally made for now - it was the first in the set...
                                Here's v2.4 - updated FR lingvo file.
                                  desizn104
                                  Thank you very much descriptive detail.
                                  • jason_marantoJ Offline
                                    jason_maranto
                                    Took me a bit to warm up to the plugin -- text descriptions of visual proceedures don't work so well for me 😕
                                    But now that I made the effort to figure it out I must say this is one very cool plugin set -- I'll have to get used to it but it may very well become part of my regular modeling tool-set... but it's definitely on my short list of plugins that need a Paypal donation made to support its development.
                                    Thank-you.
                                    Best,
                                    Jason.
                                      Thank-you.
                                      Best,
                                      Jason.
                                      Thanks...
                                      There are also several skp examples and even a movie tutorial or two on the forum too... 💭
                                        skrblik
                                        Haloo guys ,i have problem, why can¨t use for rails lines, only curves ?
                                        thx
                                          thx
                                          You've probably published this in the wrong place ! 😒
                                          EEbyEdges does actually take any edges or curves etc within the two selected groups... but offers no controls over the form otherwise.
                                          I think you mean EEbyRails ❓
                                          This tool takes a Profile, a Rail1, a Rail2 [which can be the Rail1 again] and a MeldingProfile [which can be the Profile again].
                                          These each need to be Curves*** - a curve is a collection of edges - these can be as an arc or bezier or ANY collection of connected, unbranched edges that you join using the weld.rb script [see the Smustard site for a free download - it's an invaluable tool with many uses].
                                          The reason you them being joined into a curve is that how else would the tool know when you finished picking one set of edges for the profile and wanted to start picking those for the rails ? It is very simple to have straight lines welded into a 'curve' if you want straight shapes as profiles or rails - there are even ways of making a single line into a one segment curve - I actually published a tutorial on this recently in the very tool's thread...
                                          So, with most of the EEby.. tools you CAN'T use a plain line [edge] for a profile/rail... BUT it's easy to convert one into a 'curve' before using the tool anyway - use weld... ***SUp calls 'polylines' 'curves which can be confusing as they needed be curved at all !!!
                                            AJMarch
                                            Hi, TIG. I am new to the forum, and came across these plugins while doing a little research on a project i am starting. I was wondering do your plug-ins work for Mac? Thanks for the help
                                            • 7 / 10
