    [SOLVED]Vray hi res problem urgent.
    renderpluginsextensions
    9 Posts 2 Posters 6.3k Views 2 Watching
      pav_3j
      hoping someone can help, i need this render for tomorrow.
      i'm trying to do a high res render 9000x6750 in Vray, but it doesn't work.
      i have tried to render it using vrimg, but the render cancels itself after the light cache.
      any ideas what i'm doing wrong? i desperately need it for tomorrow.
      cheers
      Pav
      [EDIT] now solved, tuens out the name you give the file, can't be the same as one already in the file, obviously.
      i'm such an idiot.
      Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        Cancels?
        Error messages? SU crashes?
        Is there things you can cut back on? Reduce amount of displacement?
        What's your setup? IR+LC or DMC+LC? What are your IR/DMC and LC settings?
          pav_3j
          [VFBCore::SetRegion] Error writing render region to raw image file.
          [RIFile::WTRegion] Error writing channel buffer.
          [RIFile::WT3Float] No file stream
          Threads completed
          Clearing global light manager.
          Clearing direct light manager.
          Clearing ray server.
          Clearing geometry.
          Clearing camera image sampler.
          Clearing camera sampler.
          Clearing QMC sampler.
          Clearing path sampler.
          Clearing color mapper.
          Render cancelled
          that's what i get, there is no displacement, and eveything unnecessay is turned off on the layers pallete.
          i'm running QMC+LC, it's on my mate computer not mine as i am a vray noob.
          pav
            that's very odd error. never seen that before.
            "no file stream"? hmm
            You have enough space? You have permission to write to the location where you save the file?
              pav_3j
              plenty of both, i tried first rendering not using vrimg, but it doesn't seem to work over 4000 pixles.
              hmm, thank you for your help by the way, very impressed with you speed!
              Pav
                I'm sorry, but your error has me stomped. 😞
                  pav_3j
                  ah well, is there any other way of rendering a 9000pixel image in Vray? he he
                  Pav
                    pav_3j
                    solved it thomthom, check my first post for reason.
                    cheers for the help anywho, i feel kinda silly for asking now...
                    Pav
                      Glad to hear it worked out. πŸ‘
