    Uniq! not working ?
    18 Posts 7 Posters 1.9k Views 7 Watching
      remus
      Fredo, it gives me a syntax error when i try that, bear in mind faces is an array (and i dont think += is defined for arrays.)
      • mitcorbM Offline
        mitcorb
        Excuse me for stepping in here.
        Out of curiosity, are there a lot of terms like "uniq" in the ruby language? Couldn't this get confusing? Or can you use interchangeably "unique"?
          remus
          I dont think you can use "unique" interchangeably but its not too confusing really, if anything i find the differences help you remember the methods.
          • mitcorbM Offline
            mitcorb
            Thanks, Remus.
            Again, please excuse the intrusion.
              SUp's own .make_unique method only applies to groups and instances of component definitions.
              Its .unique_name methods applies to definitions and layers name creation.
              Ruby's own .uniq method returns an array (etc) of unique items ('cloned'), missing out duplicates,,,
              array1=[1,1,2,3]; array2=array1.uniq >>> array2 returns [1,2,3] but array1 still returns [1,1,2,3]
              whereas using .uniq! changes the original array to a unique one...
              array1=[1,1,2,3]; array1.uniq! >>> array1 now returns [1,2,3]
              All very useful in there own ways...
              • Dan RathbunD Offline
                Dan Rathbun
                @remus said:
                ...to try and create an array of the faces connected to a face...
                EdgeUse.partners
                http://code.google.com/apis/sketchup/docs/ourdoc/edgeuse.html#partners
                The partners method is used to retrieve all of the partner edge uses. This method allows you to find all Faces that use an edge.
                EDIT: Never-mind. I think the flatten! array means by ThomThom is much simpler. Compact code, let ruby do the hard work.
                I'm not here much anymore.
                  Dan Rathbun
                  Many of the method names came from Unix and Perl, so they are familiar to people with that background. Well there are some 'shortened nicknames', such as: assoc, eql, attr, dup, eval, stat, sync, const, undef,... etc. sprinkled throughout ruby modules, but No not a majority. A very small minority in fact. But you get used to them.
                  You could (if you felt more comfortable,) create singleton methods that provide an alias.
                  arr = [1,2,1,3,4]
                  def arr.unique!
                    self.uniq!
                  arr.unique!
                   >> [1,2,3,4]
                  arr2=[5,6,7,5]
                  arr2.unique!
                   >> Error; #<NoMethodError; undefined method `unique!' for [5, 6, 7, 5];Array>
                  So it only works for the single instance 'arr'.
                  This avoids globally changing Base classes, which most people get upset about.
                  • fredo6F Offline
                    @remus said:
                    Fredo, it gives me a syntax error when i try that, bear in mind faces is an array (and I dont think += is defined for arrays.)
                    It must be something else (do you have a precise description of the error).
                    + is defined for Arrays (it's equivalent to concat), so += is meaningful (I use it frequently).
                      I get a syntax error as well:
                      [1,2,3] += [4,5]
                      Error; #<SyntaxError; (eval);894; compile error
                      (eval);894; syntax error
                      [1,2,3] += [4,5]
                      (eval);894
                      Is it not that you have some code that has added this as extra functionality?
                        hm... when I defined the variables face and faces - and ran the code - it worked....
                        face.edges.each { |e| faces += e.faces }
                        now I'm confused
                        • fredo6F Offline
                          Tom,
                          It only works on variables, because you actually modify the contnet of the left-side array (and I guess [3,5] is considered as a constant).
                          I tried in the console:
                          a = [1,2]
                          [1, 2]
                          b = [3, 4]
                          [3, 4]
                          a += b
                          [1, 2, 3, 4]
                          [1,2] += b
                          Error; #<SyntaxError; (eval);130; compile error
                          (eval);130; syntax error
                          [1,2] += b
                          (eval);130
                          Fred
                            remus
                            Working now 😳 Must have missed something last time i tried it.
