    Scale tool
    3 Posts 2 Posters 305 Views 2 Watching
    • F Offline
      fhenaux
      Would any one know of a tool that can scale up or down with having to calculate the percentage to get it to the measurement you want?
      Many thanks
      Fred
      • TIGT Online
        Use the built-in SUp Scale Tool but instead of a number you need to type in the dimension withunits appended...
        For example you have a box 1600mm wide and want it to be 600mm wide you could do it the hard way and say to yourself 600mm/1600mm=0.375 so I'll scale in the width by that..... BUT if you just typed in 600mm it is made 600mm wide - irrespective of it's previous width...
        [note you must have the mmto tell SUp it's in a length otherwise plain 600 will make it 600 times wider ❗ ]
        Hope that helps πŸ€“
        • F Offline
          fhenaux
          Thank you very much Tig.
          Great help.
