    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 85.0k Views 10 Watching
      Yes, unfortunately the thumbnails do not refresh. I would not call it a bug as they have never "tried" to fix it - rather a lack of feature.
      YOU can fix it - select an instance of the component, and type/paste Sketchup.active_model.selection[0].definition.refresh_thumbnail into the Ruby Console to refresh the selected component's thumbnail...
      Alternatively, type/paste Sketchup.active_model.definitions.each{|d|d.refresh_thumbnail} into the Ruby Console to refresh all of your component's thumbnails, with no selecting required...
      πŸ€“
        An even cleverer way is to write a short script
        require 'sketchup.rb'
        def refreshthumbnails
        end#def
        refreshthumbnails
        copy/paste this code into a file called refreshthumbnails.rb in the Plugins folder - that way your component thumbnails will update whenever the model opens and typing refreshthumbnails into the Ruby Console will fix any changed or new components' thumbnails too...
        πŸ€“
        • GaieusG
          Now you've scared poor D0me away I'm afraid, TIG!
          πŸ˜‰
          But million thanks for this! πŸ‘
          • mitcorbM
            mitcorb
            Just regard TIG's avatar.
            Just your friendly local tiger--wagging his tail and licking his lips.
              D0me
              Hi Gai
              Thanks for the solution.
              Tig: You almost scared me away but I came back for more.
              On a more serious note, time just has not been on my side these past few days and the little free time that I do have gets spent here.
              Gai: The opening is 18" in width and 9 Inches High. An arched shaped opening sounds good. The opening should be exactly halfway between 2 slices of the dome.
              Regards
              D0me
              • GaieusG
                @d0me said:
                ...time just has not been on my side these past few days and the little free time that I do have gets spent here.
                No problem, D0me, we have time. πŸ˜‰
                Any thoughts on a wall thickness? πŸ˜’
                I was like half expecting this. That's why we needed to set those component axes so meticulously as when a component is now mirrored along its red axis, it won't get out of alignment. πŸ˜‰
                Always think ahead - that's the key for SU as though modelling is quite easy, intuitive and the learning curve is not very steep, existing geometry is not very easy to modify.
                So let's continue...
                In order to easily draw the "entrance" along the regular axes, we will rotate our whole structure a little bit (note that an easier way to temporarily work with different axes could be to place the axes aligned to our structure but eventually it will be more beneficial for us to do it this way).
                I have temporarily grouped everything so that it's easier to rotate together. Alignment of the Rotate tool where there is so much geometry around is not easy but you already know two tricks to do it.
                Rotate the whole structure in a way that the seam between two sets of components lie exactly on the red (or green) axis.
                Now as we have learnt, whatever changes we make in one instance of a component, it will chage every other instance, too, so where we choose to make the entrance (as you wrote, "exactly halfway between 2 slices") we need to make unique. Make sure to make those two pieces unique whose seam now lies on the axis you have aligned the whole structure just now.
                Now I temporarily hid the two new, unique outer dome slices and made the corresponding inner slices unique, too.
                Okay, one more thing. If we start "carving" our entrance into the two slices, one instance needs to be mirrored otherwise both halves of the entrance would appear either on the right or left of each slice. This is when it comes handy that we have already set the component axes properly and we can easily flip the components around their red axes without them getting way out of alignment.
                If you turn the visibility of the component axes on (Window > Model info > Components), it is very apparent actually. Here I have already flipped one of the components and you can see that the red axis points in the opposite direction.
                Now unhide the outer pieces and flip either along its red, too (it does not matter which one actually but to keep track what we are doing, best is to pick the corresponding piece - in this case the right one).
                I think we are ready to start designing our entrance now.
                At this state of the model, I also attach my finished version so that you can compare whatever you end up with, with this one. I think we have lost some colouring somewhere but that does not matter - we can redo that at the end easily again.
                Learning--Unique-flipped.skp
                  It's an igloo πŸ˜‰
                  • GaieusG
                    Yeah - especially with the entrance inserted (I have already tried).
                    πŸ˜‰
                    Igloo for dwarves though (mind the scale!)
                    πŸ˜„
                    • chrisglasierC
                      chrisglasier
                      It's an igloo πŸ˜‰
                      For 9" high Inuit. I guess they are going to reveal the mystery in the last episode - after all it is a technical thriller.
                        D0me
                        Hi Gai
                        I'm stuck again.
                        I did the following.
                        1. I selected my entire sketch, Right Click and selected Make Group
                        2. I then managed to place my rotation tool at the origin along the blue axis and rotated the entire sketch whereby the seam seperating 2 pieces was exactly on the red axis.
                        3. I then selected the 2 pieces sharing the red axis and then right clicked it and selected make unique.
                        4. I then managed to select the top 2 pieces and hide it.
                        5. After hiding the top pieces, I selected the 2 pieces on the inner dome and right click > Make Unique.
                        6. I then turned on the visibility of the component axes.
                        I am currently stuck at this stage. It seems that my inner dome is not aligned properly for some reason.
                        I have attached the file.
                        In the interim, I have downloaded the file you attached in your last post. While assisting me in resolving this problem, I'm sure we can go ahead and continue. I can always try to resolve my sketch later.
                        Look forward to hearing from you
                        Regards
                        D0me
                        Learning-Latest-Optomised_Gai-Unique.skp
                        • GaieusG
                          Well, it seems that you either skipped the step when we aligned the component axes (see a couple of posts above) or maybe accidentally went on modelling with a version prior to that (I also have like a dozen of different versions with different stages of the model). Or maybe you played around with the reload function and incidentally reloaded an older version of the inner dome component? Who knows - in the component browser it is also upside down like before.
                          The outer dome components have the axes aligned correctly.
                          I also noticed that you hid the geometry inside the outer dome components, not the components themselves (this is of course not a problem but you need to remember this when you want to unhide it).
                          Now you can do two things
                          • Do that step (again) when we aligned the axes
                          • use my version and don't tell the teacher. πŸ˜’
                            D0me
                            Probably missed out a step somewhere along the line.
                            Anyways, once we complete this excercise, I will be doing an exam (Completely redo the dome with a totally different height and diameter). It's good that my mistakes are pointed out now. I will be sure to not make these mistakes on the recap.
                            For now, we can use your version (Pass me your version under the table while the teacher is not looking) πŸ˜‰
                            • GaieusG
                              Okay, it's at the bottom of this post:
                              http://forums.sketchucation.com/viewtopic.php?p=215353#p215353
                              πŸ˜‰
                              Now have you been thinking about the possible wall thickness of your "entrance"?
                              Well, it's not dead necessary - all depends on the shape (if it has some visible "framing" from outside maybe)
                                D0me
                                I think the wall thickness can be the same as the entire dome which is 3 Inches.
                                • GaieusG
                                  Okay, some preparation if you excuse me...
                                  I noticed that I have also screwed up my version a bit (dunno when) and we actually have three unique instances of the outer dome - instead of just the two we need. If you right click on the #1 version (that's the unique one) in the component browser and "Select instances", it will highlight three and the Entity info also says there are three of them (the left one in the picture should be the original version of the component)
                                  So select this left one, right click the "should be" one in the component browser and "Replace selected". Sorry for the extra hassle (but in case you need this for later, a good tip I hope).
                                  Now let's start our entrance by first drawing a 18" long line on the green axis with the line tool (it could be anywhere actually - it was quite arbitrary that I started it at that endpoint on the seam). You can type 18 and hit Enter as usually.
                                  Now select the line then pick the Move tool (we haven't used it yet I believe) and grab the line at its Midpoint (midpoints give this cyan inference when not grouped).
                                  Move it too the seam so that it will be exactly in the "middle" in front of our igloo.
                                  Now something important (to make things more comfortable later); select the line if it is not selected any more, go to the Edit menu and Make it a group (for some reason, when only one entity is selected, you cannot group it from the right click/context menu - same with components). We need this to let us hide the rest of the model with our Ctrl+H custom shortcut.
                                  Now double click on the group, pick the Arc tool and make sure you are using 24 segments again (type 24s and hit Enter) then make your arc on the blue axis. If you cannot have the blue axis inference because the arc wants to snap to every single endpoint in your igloo model, press Ctrl+H to hide the igloo (this is why we grouped it at the above, early stage). In this case a 9" arc will be a Half circle for which we get a nice inference tooltip.
                                  Finally, pick the PushPull tool and extrude your tunnel through the whole structure. Now it doesn't matter how long you extrude it just make sure that the whole face on the other side be in the dome.
                                  Next step will be some offsetting to make thickness and intersecting the whole thing.
                                  Back to deleting spammers in the Admin panel... πŸ˜’ πŸ‘Ώ
                                    D0me
                                    Hi Gai
                                    SU Has some super cool features especially that Push/Pull tool
                                    I think I'm on track thanks to your version of the file (Shhhhhh!!! don't let Gaieus (Teacher) hear that) πŸ˜„
                                    Where to next, Sir?
                                    • GaieusG
                                      Okay, everything seems to be fine now.
                                      Let's make the tunnel now. There are two ways and we'll also see the differences between them.
                                      To make that 3" thickness, we will first use the Offset tool
                                      When you do not select anything but hover over a face, it will autoselect all and offset all the perimeters. There are problems with this tool at certain extremities (try to offset the whole face by 3"!) and as far as I know, ThomThom is contemplating on a plugin that would do a better job.
                                      Now we will only offset the arc however so select it first, start using the tool to offset it inwards then type 3" and hit Enter.
                                      Now if we take a closer look, we'll see that the Offset tool did not make a precise job - but this is of course only due to our arc being segmented and the last segment only "theoretically" tangent to the vertical.
                                      If we set our units precision to more decimals, it will even display the inaccuracy (otherwise it would say ~3"). If you wish, we can keep this as it will nopt affect our drawing detrimentally (is that a good word here? English is not my native tongue)
                                      So instead of the Offset tool, we can draw the 3" distances from the endpoints of the outer arc...
                                      ...and draw a new arc (again, a Half circle) from these endpoints. Make sure to change the segment count to 24 again.
                                      Finally, PushPull the "difference" in.
                                      If the starting and ending faces are perfectly parallel to each other, SU will presume that we are to draw an opening (say a window in a wall with thickness) and will automatically remove the ending face.
                                      Right before it does this, you can see the two faces in the very same space but one oriented with its back face to the camera. In such cases, when SU cannot decide which coplanar face to display, you can see this "flickering" that is called "Z-fighting".
                                      In 2D applications, where x and y are the natural horizontal and vertical extents of the screen, the apps generally have some kind of a tool to bring something to the front or send it back etc. (even MS Word has this). This is called "Z-value" - the higher it is, the greater priority it gets to be displayed on top of something with a lesser value.
                                      In a 3D app like SU, there is no reason for this as (theoretically) everything in real world has some thickness and so should be in their 3D models. There are limitations however but they are out of the scope of this lesson now but I thought a few word about this Z-value and Z-fighting in Su do not hurt.
                                        D0me
                                        Hi Gai
                                        I'm on track.
                                        That info about Z Fighting is quite interesting. In fact, thats the first time I've heard such a term.
                                        You've done a phenominal job on the opening so far. I honestly did not have this type of opening in mind and you've really taken the creativity of my project to a new Level. Thanks
                                        I guess the next step is to take out the back piece of the opening that was pushed into the dome.
                                        • GaieusG
                                          Hi D0me and good morning!
                                          Yes, something like that. We have already done intersection - we are going to use that technique again.
                                          First of all, let's hide the inner dome pieces again so that they will not get intersected with the outer pieces (remember when your dome turned into a chess-board?).
                                          Now edit ONE of the outer components, select all by triple clicking on the bare geometry, right click and "Intersect... with model".
                                          If you now hide the rest of your model (Ctrl+H, remember), you get a clean view of what is needed to clean up. Start carefully deleting unwanted geometry. Note that this is a sensitive part as we don't want to delete what we need but keep in mind that there is the Undo command (Edit menu or Ctrl+Z) all the time should you make any mistake so do it bravely.
                                          As you can see, this is where we make use of components and that we have a pair of mirrored components mated. We only work with one and the other is modified automatically.
                                          We may need to redraw some pieces to close open gaps but that's already a piece of cake.
                                          Now we change components - unhide the inner pieces (Edit menu) and hide the outer ones.
                                          Do exactly the same with the inner components as you have done with the outer ones (use the "hide/unhide rest of model" - Ctrl+H - command to your needs again) Except one step - and this is extremely important! - Copy this piece I selected onto the clipboard before deleting its face then close the component, edit the tunnel (it's a group now), go to the Edit menu and "Paste in place". We need this little, curvy part later in this group. But if we get rid of it now, it will be hard to recover so therefore this extra step even before we deal with the tunnel.
                                          BTW you can assign a shortcut key to this very handy tool (Paste in place), too. I for instance have Shift+Ctrl+V (Ctrl+V is a general "Paste" shortcut in every app - just like Ctrl+C for copying or Ctrl+X for cutting)
                                          And we end up with something like this.
                                          If you do not like those gaps in the domes where we intersected with the tunnel, we can deal with them later - as well as giving a final shape to the tunnel itself.
                                          (BTW the shape of the tunnel - I guess it is not bad to keep a flat front face in case you would like to apply some sort of "door" or such...)
                                            D0me
                                            Inline and on track, Sir.
                                            I've done the cleanup as accurately as possible.
                                            The way you have it seems fine although a door sounds good. Is it difficult to add or remove the protruding end at a later stage?
                                            • 16
                                            • 17
                                            • 4 / 17
