    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 102.2k Views 10 Watching
      D0me
      Hi Gai
      This Rotation tool took its toll on me. I just couldn't quite get the hang of it at first but after repeatedly reading your instructions and not forgetting the informative pictures you attached, I finally managed to find my way around (excuse the pun). Finding the midpoint was the hardest as SU dosent easily snap onto midpoints as easily as it snaps on to endpoints but hey, whats the fun of it if it dosent make you sweat.
      I've attached the sketch. Please check it and see if what I've done is correct.
      Ready to continue, Sir!
      Learning-Latest-Optomised_Gai.skp
      • GaieusG
        Well, looks like this is it. Well done! 👍
        (Although you seem to have rotated it in the other direction - or the same direction but by 120 degrees instead - it does not matter).
        Now we are going to use these rotated planes to slice up our model. This is going to be done with a tool called "Intersection". Just a few words bout this tool first. When you use this command, where two different objects go through each other, SU will create lines. Very important thing to remember that it will always create these lines in the editing context you are in.
        As we have groups in our model, and we are now "outside" of them, if we did this intersection outside of their editing context, these lines would also appear outside - i.e. would not become part of the geometry of anything inside the groups (in our case, the domes). So this means we have to get inside the groups' editing contexts - and since we can only do that one at a time, we will need to do this twice.
        I will only show you one example however - you will do it with the other dome the exact same way.
        First of all, we have to hide one of the domes otherwise SU will intersect the one we are working with with that one too. The fist image shows what we do NOT want and what we would get if we didn't hide the other dome (this rarely happens but you have this weird setup with two, touching domes)
        So right click on either dome (I chose the inner one) and hide it.
        Now do what you could see in the first image - edit the group - select all (if you triple click the dome group at the beginning, you will not only get into its editing context like when double clicking but all the geometry will also be selected - so you can spare two clicks), right click, intersect with model etc. This is what you should get.
        Now comes the boring part - clean up unnecessary and unwanted geometry (in several steps - without further, written comment):
        We also close the sides of our slice by using the line tool
        Some further cleanup
        And voilà - this is our first slice we ende up with. Dont worry that we have lost the rest of the dome, as you need six identical slices, we are going to copy this piece around five more times.
        Now unhide the previously hidden, inner dome from the Edit menu > Unhide > either "Last" or "All", hide the slice we have just claned up and do all the steps we did above with the innder dome. Best would be to keep the piece right under the one we have just finished.
          D0me
          Hi Gai
          Please help!
          I cant seem to get pass this point
          I have followed you instructions by right clicking the inner dome and selecting hide. That worked fine.
          I then tripple clicked on the dome that's visible and then right clicked it and selected intersect with model. I've succeeded there as well.
          I then erased the 3 bits you asked me to erase and that worked as well. After this point, I am unable to erase the inner surface of the dome. When I try to select the inner surface of the dome, I can only select bits and pieces of it (The small square like pieces created by the segments) but I cant seem to select the entire pie piece of it.
          I also wanted to know whether my sketch is correct compared to yours since I notice that at the point where you started erasing bits of the dome, your images dont have the slicing plane like mine do. Did you remove the slicing plane?
          Regards
          D0me
          Learning-Latest-Optomised_Gai-2.skp
          • GaieusG
            Okay, no problem, there is an easy fix.
            This is actually what I wanted to avoid by hiding the inner dome (as its hidden edges now intersected with the outer dome as well). No problem however - apart from the intersection lines we wanted to create, now new geometry was created - just old, softened edges hardened.
            There could have been a whole bunch of ways to avoid this - I though I found an easy one and I don't know why it didn't work for you as I cannot "Undo" your steps once you closed the model.
            Anyway,
            1. go into the group again,
            2. select all by triple clicking,
            3. right click and choose "Soften/Smooth edges.
            4. When the popup opens, make sure that "Soften coplanar" (edges) is NOT checked and move the slider a bit (just enough to "touch" it).
              Since we have rotated our slicing planes to the midpoints, we cut the facets in the middle thus creating two but perfectly coplanar ones of each. This is why we can use this trick now and soften everything else BUT what we actually need.
              When you have done this, you will be able to go on cleaning the stuff.
            If the other dome behaves the same, naughty way, deal with it similarly.
              D0me
              Hi Gai
              After my last post, I decided to take another stab at it.
              I made a backup of the file before proceeding with intersection, so I restored the backup and from the top of you instructions, I went through again step by step and voila!!! I got. Immediately after succeeding, I refreshed the page and then found your post with the solution. It's actually a good thing I saw your post later late. Gave me a chance to overcome the hurdle. I love challenges and that's the best way to learn. I learned something about SU. It is very sensitive to clicks in terms of where you click, how many times you click and so on.
              It's really overwhelming when the problem is resolved after numerous attempts.
              I've attached the latest sketch. As you can see, I've left the slicing planes. Wasn't too sure whether to delete or hide them.
              I must thank you for your patience. I am a bit of a slow learner but grasping on quite well.
              So where to next, teacher?
              Regards
              D0me
              • GaieusG
                Okay - downloading...
                  D0me
                  Thought I'd let you know that I used the instructions from your last post to resolve the promlematic file named Learning-Latest-Optomised_Gai-2.skp and I was successfull there as well.
                  • GaieusG
                    Well, we won't need them any more so you can safely delete them. Also, open your Layer dialog (Window menu) and delete the slice layer (I left it there) and delete its content, too (there are my slices)
                    Okay, good to know you got that, too.
                    Also, above my things were not visible (slicing planes and all) because I used that "Hide rest of model" function you also have now with Ctrl+H.
                    Now, first of all, we need components of these groups (We could also have started with them of course). Components are actually like groups but they have some extra features like you can set their internal axes (see below), can be exported and reloaded like separate skp files, can "glue" to faces (group too but you cannot control that), can cut holes like for openings etc. but most importantly for us now: there is one definition of a component and there can be several instances. SU only "keeps in mind" one definition so if you place a whole bunch of them, it needs to count the geometry only once and remember the place, orientation etc. the instances only. This saves file size and also, if you edit one component and make changes, all the others will reflect/inherit these changes.
                    Now right click on each group and make component. Immediately after, open your Component browser (Window menu) and go to "In model" and rename your stupidly named components to something meaningful first. Also notice (to your utmost horror) that the component thumbnails are upside down.
                    The simple reason - remember when your whole model was upside down? Groups also have axes (although we cannot control them) and this state got frozen when you made them upside down. We need to change this (and as we would change the component axes anyway for our task now, as I am sure we will flip/mirror some in the future and that happens along component axes, this is not a big problem).
                    So right click on one (I chose the inner first) and "Change axes" - hope the image instructions are enough.
                    Also, with the outer dome, change the axes similarly (it's now outside but that's not a problem)
                    And now we are going to make a "Radial array". Select both components and start like the Copy Rotate some pages above:
                    Rotating one instance of the component - but read the yellow label before finishing. What have you got?
                      D0me
                      Cool. Super Cool.
                      X5 and voila. 5 pieces instantly join to form the dome in its entirety.
                      Wow, what an accomplishment even though you walked me all the way.
                      Thanks a million
                      Can't wait to continue.
                        D0me
                        I just noticed that under Window > Components, the dome is still upside down.
                        Is that normal?
                          D0me
                          Hi Gai
                          Sorry for posting in parts, but I was using the orbit tool to look around the dome and then when I brought my dome back to what it was, the entire colouring of the dome went crazy. The dome was in an xrayed format yet I didn't select xray.
                          Sketch Attached.
                          Learning-Latest-Optomised_Gai-6.skp
                          • GaieusG
                            Is that normal?
                            Yes, unfortunately the thumbnails do not refresh. I would not call it a bug as they have never "tried" to fix it - rather a lack of feature.
                            If you want to change that, here is how (and it's a useful tool anyway).
                            1. Right click on a component either in the model space or in the component browser and "Save as..."
                            2. Remember where you save it - and open that file (now also learn that components are actually full fledges skp models - just "embedded" into your model) it will open "normally" - i.e. not upside down.
                            3. Orbit to have the best view as you wish (turn on colours again, turn off hidden geometry) and simply save.
                            4. Now go back to your original model, right click the component again and "Reload".
                              Now the thumbnail will change, too. Do it - just out of practice, if you wish.
                            • GaieusG
                              Well, the dome IS in X-ray. Press the X-ray button in your face style toolbar and it gets back to normal.
                              Also, maybe it's time to go back to Perspective mode (at least to me, it feels so much more comfortable and natural).
                              Next thing will be that "door" or something. So what are the plans? How big, what shape (maybe arched) etc.?
                                YOU can fix it - select an instance of the component, and type/paste Sketchup.active_model.selection[0].definition.refresh_thumbnail into the Ruby Console to refresh the selected component's thumbnail...
                                Alternatively, type/paste Sketchup.active_model.definitions.each{|d|d.refresh_thumbnail} into the Ruby Console to refresh all of your component's thumbnails, with no selecting required...
                                  An even cleverer way is to write a short script
                                  require 'sketchup.rb'
                                  def refreshthumbnails
                                  end#def
                                  refreshthumbnails
                                  copy/paste this code into a file called refreshthumbnails.rb in the Plugins folder - that way your component thumbnails will update whenever the model opens and typing refreshthumbnails into the Ruby Console will fix any changed or new components' thumbnails too...
                                  • GaieusG
                                    Now you've scared poor D0me away I'm afraid, TIG!
                                    But million thanks for this! 👍
                                    • mitcorbM
                                      mitcorb
                                      Just regard TIG's avatar.
                                      Just your friendly local tiger--wagging his tail and licking his lips.
                                        D0me
                                        Hi Gai
                                        Thanks for the solution.
                                        Tig: You almost scared me away but I came back for more.
                                        On a more serious note, time just has not been on my side these past few days and the little free time that I do have gets spent here.
                                        Gai: The opening is 18" in width and 9 Inches High. An arched shaped opening sounds good. The opening should be exactly halfway between 2 slices of the dome.
                                        Regards
                                        D0me
                                        • GaieusG
                                          @d0me said:
                                          ...time just has not been on my side these past few days and the little free time that I do have gets spent here.
                                          No problem, D0me, we have time. 😉
                                          Any thoughts on a wall thickness? 😒
                                          I was like half expecting this. That's why we needed to set those component axes so meticulously as when a component is now mirrored along its red axis, it won't get out of alignment. 😉
                                          Always think ahead - that's the key for SU as though modelling is quite easy, intuitive and the learning curve is not very steep, existing geometry is not very easy to modify.
                                          So let's continue...
                                          In order to easily draw the "entrance" along the regular axes, we will rotate our whole structure a little bit (note that an easier way to temporarily work with different axes could be to place the axes aligned to our structure but eventually it will be more beneficial for us to do it this way).
                                          I have temporarily grouped everything so that it's easier to rotate together. Alignment of the Rotate tool where there is so much geometry around is not easy but you already know two tricks to do it.
                                          Rotate the whole structure in a way that the seam between two sets of components lie exactly on the red (or green) axis.
                                          Now as we have learnt, whatever changes we make in one instance of a component, it will chage every other instance, too, so where we choose to make the entrance (as you wrote, "exactly halfway between 2 slices") we need to make unique. Make sure to make those two pieces unique whose seam now lies on the axis you have aligned the whole structure just now.
                                          Now I temporarily hid the two new, unique outer dome slices and made the corresponding inner slices unique, too.
                                          Okay, one more thing. If we start "carving" our entrance into the two slices, one instance needs to be mirrored otherwise both halves of the entrance would appear either on the right or left of each slice. This is when it comes handy that we have already set the component axes properly and we can easily flip the components around their red axes without them getting way out of alignment.
                                          If you turn the visibility of the component axes on (Window > Model info > Components), it is very apparent actually. Here I have already flipped one of the components and you can see that the red axis points in the opposite direction.
                                          Now unhide the outer pieces and flip either along its red, too (it does not matter which one actually but to keep track what we are doing, best is to pick the corresponding piece - in this case the right one).
                                          I think we are ready to start designing our entrance now.
                                          At this state of the model, I also attach my finished version so that you can compare whatever you end up with, with this one. I think we have lost some colouring somewhere but that does not matter - we can redo that at the end easily again.
                                          Learning--Unique-flipped.skp
                                            It's an igloo 😉
                                            • 16
                                            • 17
                                            • 3 / 17
