    Clay Rendering
    extensions
    14 Posts 5 Posters 4.4k Views 5 Watching
    • massimoM
      massimo Moderator
      Hi numb. If you want to use KT for your clay renders I suggest you to download some "extra" presets here. Look under "renders settings" towards the bottom.
      • GaieusG
        NTh - it's in PΓ©cs, my place. Of course, we could only find the foundations.
        πŸ˜„
        And indeed, have a look at those presets - BTW they (exactly or a bit modified?) are also included in the latest Twilight render, too.
        I am actually rendering like a madman parallel on Twilight and Kerkythea (this latter is for the volumetric lights now). πŸ˜‰
        • numbthumbN
          numbthumb
          Thanks for your replies, guys!
          Comfortably numb...
          • FletchF
            Fletch
            I think Massimo meant to link you to this one:
            search for the word "clay" on this page
            Fletch
            • GaieusG
              But then you also added some nicer presets in Twilight, right?
              • numbthumbN
                numbthumb
                Is it possible to use Kerkythea render presets with Twilight?
                Comfortably numb...
                • GaieusG
                  Yes (in fact, TL uses them, too) although I myself do not know how to add those (I think) xml files. Fletch would probably be happy to enlighten us. β˜€
                  • numbthumbN
                    numbthumb
                    Ah, pardon me for being an idiot once again, but how exactly a geographic location ( and solar orientation ) of a model is important for an accurate rendering? I mean, if a model is not representing an actual building with an exact location ( like in the case of that basilica), can it be randomly assigned?
                    And when I open Shadow Settings from the Window menu in SU - if both options are ticked ( Display shadows and Use sun for shading ) SU becomes unresponsive or very sluggish.
                    Is it my PC or am I doing something wrong here?
                    Comfortably numb...
                      ... model is important for an accurate rendering?
                      A basilic has not always the same orientation? πŸ˜’
                      So we can see easily that is a fake if it's not well oriented! πŸ’š
                      • GaieusG
                        That building is actually (quite) precisely geolocated. Say max a couple of metres can be the difference. You could even place it on GE πŸ˜„
                        And yes, locations should affect sunshine thus shadows.
                        You don't relly need both settings. Plus Twilight/Kerky will cast shadows anyway so you can even turn them off and only on when you want to set a nice shadow.
                        Also, in Twilight, you can hide layers but still render them. This makes sure that your model can be responsive while you render every important thing.
                        Pilou, this basilica has its apse on the west and front entrance on the east.
                        • numbthumbN
                          numbthumb
                          Oops! 😳 Sorry, guys for that lapsus calami - what I really wanted to say was an actual building with an exact location ( like in the case of that basilica ).
                          Anyway, thanks for the explanation.
                          Pilou, how can you tell if a basilic is properly oriented? πŸ˜‰
                          http://www.plantes-canette.fr/images/basilic_3.jpg
                          Comfortably numb...
