    Hiding Outliner Window
    24 Posts 6 Posters 4.2k Views 6 Watching
      @jim said:
      I think the UI means the toolbars, menus, and dialogs - everything but the drawing area.
      And if the Outliner is updating during a script with the 2nd argument true, then I would consider that a bug.
      I manage to get it to work most of the time in v7 - with true the Outliner doesn't refresh till a commit - but it also stops the main window refreshing... so if you want to pause inside your script and see what you've drawn so far you need to commit then re-start an operation - resulting in possible multiple undo's later on - the transparency arguments seem too confusing too, as nesting start/commits seems flaky... If you miss a bit of code where there is intensive group creation then the Outliner can still crash SUp.
      The roll-up script works OK on PC v6 and 7.
      It IS best if the Outliner is closed when running intensive scripts - BUT users will be users...
        I believe they are broken... 😞
          Jim
          Nesting start/commits has always been a no-no. I don't think the transparent nor the prev_trans arguments are related to nesting.
            haven't tried to nest them. But making one commit transparent to the previous one - impossible...
              Jim
              The only way I know to pause a script is to use timers. I believe that is what Fredo does in plug-ins such as Round Corner which can be interrupted during long operations. You can call view.refresh (v 7.1+) to force a refresh of the view.
                You 'pause' a script so you can see the geometry so far by having start/commit operations that follow each other - unfortunately that means an undo for each operation... What we need is some way of group all of these into a 'nesting' operation that can be undone in one step ?
                  That's what the third and fourth argument in .start_operation is meant for. If only they where working... 😞
                    Jim
                    This is not a requirement for updating the view. There are other ways to do it.
                    I have not tried it in awhile, but I seem to remember a messagebox will pause the program and the view will be updated. Or maybe calling view.refresh followed by sleep(2) might work. I mean, if your goal is to pause the program just to see it's progress.
                    • fredo6F
                      You don't need the extra arguments and can do all geometry within a single Start - Commit operation.
                      Just give back control to the Tool by encapsulating the geometry construction in timers.
                        I have not tried it in a while, but I seem to remember a messagebox will pause the program and the view will be updated. Or maybe calling view.refresh followed by sleep(2) might work. I mean, if your goal is to pause the program just to see it's progress.
                        A messagebox will cause a window to redraw IF the start_operation argument is false - but if it's true the window's contents are unchanged until the commit arrives.
                        view.refresh should work with the operation BUT it IS limited to very recent SUp versions, so cannot be backwardly compatible. To such make a script v6 compatible would mean convoluted version checking...
                        view.invalidate waits for the commit.
                        πŸ€“
                        • Dan RathbunD
                          Dan Rathbun
                          At the end of the operation, does SU update the UI automatically?
                          or, is it a good idea (just to be sure) to call:
                          UI.refresh_inspectors # force complete UI update
                          http://code.google.com/apis/sketchup/docs/releases.html
                          I'm not here much anymore.
                            In my experience SU seem to update the viewport after commit_operation.
                            But if an error occurs before your [ruby]commit_operation[/ruby - then the viewport won't update until you pan/orbin/draw.
                            • F
                              filcole
                              Hi Tig (and all others),
                              Thanks for the responses, fixed my problem wonderfully. Kudos.
                              I did try using start_operation() with the second parameter set to true, but the Outliner window is still redrawn when each dynamic component is redraw using $dc_observers.get_latest_class.redraw_with_undo(compInst).
                              • 2 / 2
