    Plug In - Copy to Path troubles
    9 Posts 4 Posters 678 Views 4 Watching
      arcaterra
      Everytime I scale a component down, and then try use Copy to Path > Copy to Spacing, what get's copied is the component at its original insertion size, and the scaled down version remains untouched. Is there something I am doing wrong?
        the copy to path doesn't take into account the scale. Scale Definition before you Copy to Path.
        (I'm moving his to the Developer section)
          ... so, Scale the contents [i.e. during an Edit of an Instance] of a 'made_unique' version of that Component before using that with Copy to Path - then it'll work as wanted...
            If you edit the content of the component you'll affect all other instances. What if you have instances of different scvale?
            If you Right-Click and choose Scale Definition then it won't affect the rest of your component - it just redefines the default size.
              That's why I suggested using make_unique on a version so that the original is unchanged by any Scaling you do to that...
              • nikusknxN Offline
                nikusknx
                Is it possible to do the "right-click scale definition" with Sketchup api?
                  Take the scale of the instance, scale the definition by this scale - then scale the instances by the inverse scaling transformation.
                  • nikusknxN Offline
                    nikusknx
                    Ok its seems to work but the position of instances are not good : I do this to scale the instances by the inverse scaling transformation :
                          definition.entities.transform_entities(t,self.entities.to_a)
                          inv = t.inverse
                          definition.instances.each do |instance|
                             instance.transform! inv
                    Any idea?
                    • nikusknxN Offline
                      nikusknx
                      Ok I get the good position with a translate:
                      definition.instances.each do |instance| originBefore = instance.transformation.origin instance.transform! inv tr = instance.transformation vectorTranslate = originBefore - instance.transformation.origin translate = Geom::Transformation.translation(vectorTranslate) instance.transform!(translate) end
                      but when the axes changes (y axes become z axis for exemple) the scale are not good and switch...
                      I try to get the model.edit_transform , manualy I can get it but with the API it's always the same problem : I can't do the right click Component edit...
                      Any Idea to get the local axes?
