    Cannot import CAD files to SU
    21 Posts 4 Posters 2.2k Views 4 Watching
    • AnssiA
      Anssi
      Looking at your computer specs, and the file size, I would assume that the file will take quite a time to import. You said that the import goes to 99% and "stays there". How long have you let it stay? An import like that can take even hours. You might try starting the import and going to lunch, or sleep.
      Thomthom's suggestion for cleaning the file is good too. In addition, remove in advance everything that SU cannot import, like text, dimensions and such. They just increase the file size and make the import process longer.
      Anssi
      • jim smithJ
        jim smith
        madder,
        A few thoughts on importing the .dwg that have worked for me;
        Do what TT and Anssi recommended.
        Make sure you have purged everything in the autocad drawing before importing.
        If the drawing parts can be divided say there are four elevations or a plan that could be easily cut and re-assembled, import each part separately.
        If it is one large plan, see if you can clean up the obvious things you won't need for the render like room, door and window identifications, centerlines, detail bubbles etc. Lighten the load as much as posssible, purge and you might squeeze through the 99% barrier.
        Good luck and Happy New Year.
        "Out of clutter find simplicity,
        from discord find harmony,
        In the middle of difficulty lies opportunity"
        Albert Einstein
        • AnssiA
          Anssi
          I have a sort of hunch that while importing, when SU gets to the 99% mark, the actual work is only just beginning - the import file has just been read into memory, and SU starts to build the actual model objects. Also, the process seems to me significantly slower if the DWG has a lot of blocks.
          Anssi
            madder
            Guys you're suggestions are coming thick and fast so thanks for that.I got to work on the copy and paste before reading about purge.
            SO what I did was selected all and copied, opened a new dwg, pasted, saved and now I'm trying to import to SU. I have noticed that the new DWG is almost twice as big as the previous one? That seems strange. But, right now, as before, it's waiting at 99%!
            Previously I had left the thing for a couple of hours while at 99%. I suppose I could leave it overnight?
            But before I do that should I go back, copy, paste and purge before saving and trying the import?
            Thanks guys
              Same file version? Did you purge?
                madder
                Originally, I didn't purge. But I have now gone back and purged. SO now the file is 5.1MB is size compared to 7.39mb previously. That is an improvement. It's been on the 99% now for about 30 minutes, but I'll leave it for a few hours and see what happens. Thanks again!
                  wonder what causes this. I've imported much larger DWG files before - so I don't believe it's the file size. Must be something with the content.
                    madder
                    Well, I left it importing overnight, and even left it more when I awoke. It's been 10 hours and 30 minutes, it's still at 99% and my windows task manager says my CPU is using 100% power. If it hasn't worked after 10 hours, I doubt it's going to, so I've stopped it.
                    Any more suggestions will be appreciated but I do feel defeated. Thanks for all you help guys, I have learnt a few things. 😞
                      Any change you can upload the DWG anywhere so we can look at it?
                        madder
                        Maybe I could upload it as a jpg or PSD? Using tinypic? Would that help?
                          I was more interested in investigating the content of the DWG for clues to what might make SU choke.
                            madder
                            ooops, I'm thinking it's too big for the forum, maybe I should scale it down and reload it?
                            EDIT: I've now resized it!
                              madder
                              I'm not sure if there's a way to upload a DWG to the internet? Do you know of a way to do it? I suppose I could email it? Failing that I'm not sure how? I am guessing it's down to the amount of circles and curves used in the dwg?
                              Here is a bmp image of it:
                              http://i45.tinypic.com/o7obhg.jpg
                              • AnssiA
                                Anssi
                                The image does not tell me much, but I have one question to make:
                                What did you model this with? Are the "walls" and other such things done with AutoCad Architecture (or its predecessor, Architectural Desktop)?
                                SketchUp cannot import the special "AEC" objects created by these "vertical" applications, so you would have to use the "Export to AutoCad" function in that application to export the model to a new file with the special objects translated into standard AutoCad 3D surfaces.
                                Anssi
                                  madder
                                  Anssi
                                  Truthfully, it was probably created between both. I have AutoCAD Architecture at home among others which I use, and in college it's architectural desktop
