Just playing (erzatz)
I think it's good, the render is also good, I like the caustics.
I would however soften the rim of the glass, maybe round corner or bevel as it looks like it could cut lips.
Thank you Solo.
Yes, you are right. I will modify it with round corners.It's the first time I'm playing with caustics. The glass has been created with default values. I will try to modify some parameters to test different renders.
Luis, that is just awesome
yes mate nice modeling and render, specially the ice-inside version... I like it
Thank you Majid
Oh yeah, the rounded lip on glass and the Ice render is fantastic.
Thanks solo for your advice, the render looks better now...and the most important, my lips are now safe...
Majid:
I'll try to make a mold seam as you did in your Mug render ( http://forums.sketchucation.com/viewtopic.php?f=81&t=24408&st=0&sk=t&sd=a ). -
seeing forward to see more nice renders , keep good rendering
Hi guys, just some thoughts here.
I think you both did an awesome job as far as modelling is concern.
IMHO, Maj models would have a slight edge in terms of realism.
I love the way he did the "curve edge" for the water.
Probably you can in-cooperate those in your new model. -
Good day dspace,
Thanks for your comments.
I also did a curve edge...but we can't see it because it is too microscopic -
Sorry for my bad english, I'm trying to learn it.
salut,
very realistic
it's impressive.
il faut que j'essais sur un vitrail.
merci.
