    Just playing (erzatz)
    17 Posts 8 Posters 1.4k Views 8 Watching
      Luis Esteves
      Hi everybody,
      Majid gave me some ideas...I tried to build a realistic glass, but it was difficult. The glass designed and rendered by Majid is amazing. It is very realistic ! My render is not so bad (I hope 💚 ), but not perfect. I'm still trying to improve it...
      Here is my render.
      What do you think ?
      • soloS Offline
        I think it's good, the render is also good, I like the caustics.
        I would however soften the rim of the glass, maybe round corner or bevel as it looks like it could cut lips.
          Luis Esteves
          Thank you Solo.
          Yes, you are right. I will modify it with round corners.
          It's the first time I'm playing with caustics. The glass has been created with default values. I will try to modify some parameters to test different renders.
            Luis Esteves
            Here's a new render with a round corner on the rim of the glass.
              Luis Esteves
              The same with some ice.
                d12dozr
                Luis, that is just awesome 👍 👍
                http://goo.gl/f7ooYh
                • majidM Offline
                  majid
                  yes mate 😄 nice modeling and render, specially the ice-inside version... I like it 👍
                    Luis Esteves
                    Thank you Majid 😉
                    • soloS Offline
                      Oh yeah, the rounded lip on glass and the Ice render is fantastic.
                      • charly2008C Offline
                        charly2008
                        Hi Luis,
                        your Rendering is really fantastic. It looks so very realistic. Maybe I can do that too someday. The attached image is from a beginner.
                        Kerkythea, Photon map Quick
                        • majidM Offline
                          majid
                          as Solo declared on my topic, adding more details will improve the final result. here is a view of my model
                          mug scene wire frame
                            Luis Esteves
                            Thanks solo for your advice, the render looks better now...and the most important, my lips are now safe... 💚
                            Majid:
                            I'll try to make a mold seam as you did in your Mug render ( http://forums.sketchucation.com/viewtopic.php?f=81&t=24408&st=0&sk=t&sd=a).
                            • majidM Offline
                              majid
                              seeing forward to see more nice renders 😄 , keep good rendering 👍
                                dspace
                                Hi guys, just some thoughts here.
                                I think you both did an awesome job as far as modelling is concern.
                                IMHO, Maj models would have a slight edge in terms of realism.
                                I love the way he did the "curve edge" for the water.
                                Probably you can in-cooperate those in your new model. 😉
                                  Luis Esteves
                                  Good day dspace,
                                  Thanks for your comments.
                                  I also did a curve edge...but we can't see it because it is too microscopic 💚
                                    dspace
                                    Sorry for my bad english, I'm trying to learn it. 💚
                                      meak
                                      salut,
                                      very realistic
                                      it's impressive.
                                      il faut que j'essais sur un vitrail.
                                      merci.
