    Twilight Render is Out
    extensions
    74 Posts 28 Posters 16.0k Views 28 Watching
      Animation with progressive presets would indeed sound interesting.
        kwistenbiebel
        Hi Gaieus,
        the progressive presets are in place. It is just that I can't change parameters.
        An issue I am running into:
        I am trying to render an animation, but each frame is rendered with the same (initial) view.
        After each frame, the SU screen seems to go to the next frame (I see it moving), but the rendered view remains always the same?
        [EDIT]: apparently the camera tab needs to be set to <Current View> in order to pick up the cam movement. Yeah!
          That's exactly the issue I ran into (I thought I was going nuts already) and Chris finally told me the same solution.
          ๐Ÿ˜„
          • E Offline
            Ecuadorian
            @kwistenbiebel said:
            And a little question while I am here: Is it possible to acces the render settings .xml file ?
            The render settings .xml files are saved here:
            C:\Program Files\Google\Google SketchUp 7\Plugins\Twilight\RenderSettings
            Also, if I want to use unbiased animation (path tracing progressive), can I assign a maximum render time per frame? the default of 100 or 500 passes seems overkill for some scenes.
            To change the number of passes in unbiased animation presets, just look for this line near the beginning of the .xml file you want to edit and change the value:
            <Parameter Name="Max Iterations" Type="Integer" Value="500"/>
            -Miguel Lescano
              kwistenbiebel
              Thanks Miguel.
              I tried animation using a medium Photon Map setting and it is quite fast.
              • F Offline
                Fletch
                ...I just tried the Twilight demo and I must say: fabulous User Interface!!!!
                I wasn't expecting such a nice workflow. It is simple yet elaborate.
                Some great thinking behind it.
                Could the Twilight developers make a similar UI for Vray,Fry and Maxwell please? ๐Ÿ˜„
                Hi Kwistenbiebel,
                ๐Ÿ˜„ This is a high compliment, indeed, we are pleased that you can appreciate it.
                This project has more than a year of very hard work/labor of love from a few guys from Kerkythea.
                We designed it with architectural designers using SketchUp in mind so that ANYONE, newbie to rendering, or advanced users like ourselves to be able to get out of it what we each want... that is, Twilight Render is as shallow or (almost as) deep of a program as you want it to be...
                Please use it in good health.
                Render Happy,
                Fletch
                Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                • EdsonE Offline
                  Edson
                  fletch and kim,
                  do you have any idea as to when a twilight mac version will be available?
                  edson mahfuz, architect| porto alegre โ€ข brasil
                  http://www.mahfuz.arq.br
                  • FrederikF Offline
                    Frederik
                    The best answer I can give you is the following...
                    @chris said:
                    Porting the code to Mac is turning out to be more difficult than expected. 99.9% of the code is cross platform, yet there are so many little difference when building software on a Mac that the term "cross platform" is just a mean little joke. However, it is being actively pursued. But I can't give any dates because it's all new territory for me. ๐Ÿ˜ณ
                    I can add that Chris is working hard on it...
                    Cheers
                    Kim Frederik
                    • EdsonE Offline
                      Edson
                      thanks, kim.
                      • U Offline
                        urs0815
                        ... the mac release for x-mas.... would be the right present ๐ŸŽ‰
                          remus
                          February was the last i heard ๐Ÿ˜‰
                          • pugz1983P Offline
                            pugz1983
                            On the Twilight site I saw it's possible to export a scene as xml. Does this mean I can assign materials in Sketchup and then render in Kerky? Are the materialsettings put in with Twilight stored when exported to xml?
                            Greetz from the Netherlands
                            • N Offline
                              notareal
                              yes, with registered version.
                                d12dozr
                                ...and lots more info here: http://twilightrender.com/phpBB3/index.php
                                http://goo.gl/f7ooYh
                                  Well, with the registered version, you can export scenes to Kerky.
                                  BUT even with the free version, after setting your materials, you can save the skp file and all the settings will be saved (except for Kerky library settings most probably - as those libraries will vary from computer to computer).
                                  So just have a look at this model:
                                  http://sketchup.google.com/3dwarehouse/details?mid=d1cd245ad45b78978631792c30e19543&prevstart=0
                                  download and render it without setting anything.
                                  • SektaS Offline
                                    Sekta
                                    Twilight render looks very interesting ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ . Does anyone know if it has the capability to render a section / Perspective Section? I would find this very handy like most if it does. ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                                    Stan
                                      Hi Sekta,
                                      Currently this is the method:
                                      http://www.twilightrender.com/phpBB3/viewtopic.php?f=12&t=419
                                      but there are plans to render real cuts (without erasing geometry) as you can read here:
                                      http://twilightrender.com/phpBB3/viewtopic.php?p=9242#p9242
                                      Twilight will render section cuts in a future release.
                                      • SektaS Offline
                                        Sekta
                                        Gai,
                                        Thanks for the response. The fact that Twilight will be able to render sections in future has me sold on it. Kerky has been a great free companion though. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                        Stan
                                        • 4 / 4
