    'Maximum Texture Size' is a joke!
    16 Posts 9 Posters 4.4k Views 9 Watching
      kwistenbiebel
      Annoyance!
      I imported an image of a plan in SU, and use 'Maximum Texture Size' to get it crisp in SU.
      All is well, until I export the model as an image or try to link to the SU file in Layout.
      Textures go back to their freaking lo-res bluriness.
      ... Or does anyone here has a suggestion? 😎 😉
      Thanks in advance
      • tbdT Offline
        tbd
        Error 404 (Not Found)!!1
        (sketchup.google.com)
        "uses the maximum texture size supported by your graphics card. Note: This option only affects textures and images on the screen (not export or print quality)."
        can you post a screenshot to see the low res bluriness ?
        http://plugins.ro
          Rendering apps should be able to "see" the original texture resolution for instance.
          What if you import the original image to LO instead? If you explode your SU model in there, you should be able to "paint" a face with it (or not? I haven't tried yet - wait a sec...)
          Edit - no, that's not the way. You can simply edit it as an image only after you explode.
            remus
            Looks like it might be a bug...
            edit: doh, didnt read tavis quote.
              kwistenbiebel
              I haven't found a way to overcome this.
              Google, please fix this.
              For me it is a reason to throw Layout out of the workflow.
              Just at the moment that Layout is becoming interesting enough to use in an architectural practice.... 😞
                kwistenbiebel
                Thank you Tavi for the link.
                Here some screenshots:
                first one is a SU screen with 'maximum texture size' enabled.
                http://i140.photobucket.com/albums/r3/kwistenbiebel1/crisp.jpg
                Second one is the lousy export Sketchup does as an image. Result is the same when linking in Layout 😢
                http://i140.photobucket.com/albums/r3/kwistenbiebel1/not-so-crisp1-.jpg
                ...So what is the use of being able to view images/textures in High res, but not being able to use them in output?
                Where is SU 7.2?
                  Sure do - at least according to what TBD quoted.
                  Wonder if the older SU versions also do this?
                    kwistenbiebel
                    I might be mistaken, but I had the impression that the 'maximum texture size' was only introduced in the latest SU version (7) ...
                    A much needed one in my opinion though, at least in my case.
                    • Alan FraserA Offline
                      Alan Fraser
                      I think it was introduced into the GUI in V7…although, previously, if you asked them nicely, they would point you towards a registry file that rewrote the MaxGLSize entry in HKEY_CURRENT_USER / Software / Google / SketchUp(version) / Textures
                      3D Figures
                        kwistenbiebel
                        Could this issue be solved by the use of ruby?
                        An image exporter that keeps the high res?
                        I guess it could not work for the Layout issue.
                        [Off Topic: Does Layout support Ruby extensions? and if not: would it be useful?]
                          Theoretically - but it'd be a crazy amount of work. Recreating a whole rendering system. In practise: no.
                          No.
                          Would have been nice. Has been requested.
                            chrisjk
                            On my Mac, using a copy of your image - just dragged off the page in Firefox - I see very little difference between the SU image and image sent to Layout from SU. There is a very minor degradation but nothing to complain about and nothing like as bad as your example. I am not using max texture size - have you tried without?
                              remus
                              Chris, that'll be because the image posted was a low res version so it wont be affected by SU downsizing it. If you try again with something much larger (3000x3000 should do it) you should see the issue.
                                chrisjk
                                Remus,
                                Yes, indeed you are quite right - just tried it with a big photo and it is as you say.
                                  Lersince1991
                                  Is there any fix for this yet? really annoying and makes the images rubbish!
                                    Derek Edison
                                    I don't think so. I tried to export images from a model with a draped ortho in it two months ago and they still looked horrible. The Windows clipboard did a better job than SU's exporter.
