    Problem: texture dont show
    7 Posts 4 Posters 345 Views 4 Watching
      ParaN
      I`m using kerkythea to render my sketchup files, but none of my texture is showing in kerkythea.
        Hi Thomas,
        Kerkythea, right?
        If so, make sure that non of the texture file names nor the path on your computer (say where you save the SU model or the Kerkythea xml file) contain any "international" character. Only English letters are allowed.
        So something like this would be okay:
        D:\Csaba_SketchUp\RomaiBazilika\Components
        but this would not:
        D:\Csaba_SketchUp\R**ó**maiBazilika\Components
          ParaN
          hehe, jupp..
          Not working, the path has international letter and symbols (such as _,**)..
          The thing is; im working with a model of a store (im an interior architect), and all the texture in the room is showing but not on the walls..?
          btw..
          Is there a better+free rendering program?
          • tridemT Offline
            tridem
            A better than KT + free?... and then? 😆
            You should read some thread in KT forum, you'll find a lot of similar cases , but it seems you've a reversed face problem, better you could post some image in order someone helps you.
            cheers
            • TIGT Online
              Make sure your Style has its back_faces in a really noticeable color compared to the front color - e.g. Magenta versus Off-White.
              View the Model in Monochrome.
              Select 'backward' faces [ i.e. wrong color Magenta! ] and use Reverse Faces to flip them to suit [right-click menu or make a shortcut].
              You can also try the Orient option with a 'good' face selected and then any other connected Faces should flip to match it...
                ParaN
                This solved the problem..
                Thx
                  When we are at it, Tomasz (otherwise developer of the su2kt plugin therefore well aware of such problems) have a brilliant plugin to quickly reverse back faces:
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=13380
