    [Plugin] Goldilocks
    23 Posts 12 Posters 29.4k Views 12 Watching
      remus
      Cool idea and well implemented, have to run it over a few of my old models and see what it thinks 😄
      one mini crit, would it be possible to have a different colour for 'too small' and 'too big', as if all your textures are one way its extra work to try and figure out whether to enlarge or shrink the texture.
      • AdamBA Offline
        AdamB
        OK, here's an updated one with 3 color barcharts as suggested my remus. Also turns on scrolling.
        Place in your plugins folder
          remus
          Thanks, works like charm.
          • EarthMoverE Offline
            EarthMover
            Worked well for me also. Although, as it is a viewport dependent report and I typically render out 5 or 6 views for a client, I don't believe it would be practical to change the image resolutions for each render. It will help to find errant resolutions on imported models that may be slowing down my scene overall though.
            Thanks for all your hard work to make this tool!
            Content Creator at Skapeup
            • EscapeArtistE Offline
              EscapeArtist
              Excellent tool! Thanks. This will help me as a relatively new guy on getting that texture right.
                May I suggest that you only offer one version of the plugin in the start of the thread? You'll find that people don't always scroll down to look for updates, and it can get hard to find the latest if it's hidden down in the thread.
                (A screenshot gives you cookies points. 😉 )
                • E Offline
                  Ecuadorian
                  Thanks for this, Adam.
                  If I am estimating correctly, "1.0" means the texture is about the right size for a 640x480 render for the current camera, right? Then for renderings that are to be printed, I must try to get my textures around the 4.0 spot.
                  -Miguel Lescano
                  • Mike LuceyM Offline
                    Mike Lucey
                    Nice ruby for max use of limited resources, thanks Adam 👍 Just curious! why the name Goldilocks?
                    • E Offline
                      Ecuadorian
                      The Goldilocks Principle comes from a children's story Goldilocks and the Three Bears in which a little girl found a house owned by three bears. Each bear owned a separate copy of many things, such as food, beds, etc. After testing each of the three, Goldilocks determined that one was always too much in one extreme (too hot, too large, etc.), one was too much in the opposite extreme (too cold, too small, etc.), and one was "just right."
                      Goldilocks principle - Wikipedia
                      (en.wikipedia.org)
                      -Miguel Lescano
                      • FletchF Offline
                        Fletch
                        Hi Adam, OK... so I have a SU model sent to me that has about 12 images that are way oversized.
                        I can easily see the big files in Windows Explorer and resize the images manually with Pshop... but how can I easily load them back into SU? SU already has these larger material textures loaded ... it would be cool if there were a tool to quickly replace them with the newly re-sized images.
                        some sort of "Replace all textures in scene that are in this folder"
                        of course, even better would be to use Goldilocks, but then be able to select any image that is desired to be resized and resize it with that tool all without leaving SketchUp.
                        If anyone knows of a tool to reload the textures in the SU file from a file folder, please let me know.
                        Fletch
                        • Chris FullmerC Offline
                          Its built in since v7.0. You set your image editor in Window > Preferences > Applications.
                          Then right click on a face that has an image. Chose Texture > Edit Texture Image" and it will open it in your editor. Resize it, close, and SU updates it.
                          • FletchF Offline
                            Fletch
                            Hi Chris, of course, it's easy if you only have one texture that you know of, but if you have 12 images or more in a file that need to be resized, and you are not sure which they are or names even or even where they are in the scene, you may not have created the scene (large arch. office for instance)... not so fun. 😄
                            Fletch
                              Ahh, I see. 😉
                                madhav
                                Thanks 👍
                                  Pg09
                                  Thank you AdamB this is very useful!!
                                    Pg09
                                    Fletch (or anybody) where do i find the textures of my SU file? Is there temporary folder somewhere? I tried searching but i suck...
                                    • E Offline
                                      Ecuadorian
                                      Press B to activate SletchUp's Material editor.
                                      Select a material with Alt+Click
                                      Go to the Edit tab in the material editor and click on the striped cube with an orange arrow pointing right. This will open the material's texture in your photo editor (Photoshop, GIMP, Paint.NET, etc).
                                      If you haven't done already, you might want to first select your photo editor for SU textures in Window > Preferences > Applications.
                                      -Miguel Lescano
                                      • FletchF Offline
                                        Fletch
                                        pg09,
                                        If you are using Twilight, and export to XML and choose to export the texture images and IES files, it will export them all into the folder for you... that's how I am able to quickly find the 12 big files out of the 60 image files in the scene without one-by-one checking.
                                        Although, with Goldilocks, it's now a different process! 👍 but in my case above, I was not using Goldilocks, just wondering how to quickly import the 12 resized images and replace the big ones in the scene.
                                        Fletch
                                          Pg09
                                          thank you guys!
                                          it was more Fletch's answer i was looking for. Sometimes i have to work with SU files that are just chaotic (not even the purge ruby helps) so this is one more trick to see what's going on...
                                          And yes it would be a dream come through if this plugin not only would show the problematic textures but would also fix them per click )maybe offer 2-3 lower res options...
                                          That sounds complicated to program though but what do i know... 😄
                                          • AdamBA Offline
                                            AdamB
                                            Easy enough to do but Goldilocks shows you the density for a specific viewpoint. If you change the view and zoom in closer, the texture that was too detailed before, is now OK. So probably best to just highlight potential problems.
                                            I had a model the other day from somebody which was incredibly slow - turned out 1 texture was 12000 x 10000 pixels. Just the act of Sketchup shrinking it took 1.6Gb on my Mac 😞
                                            Adam
