    [Plugin] Goldilocks
    23 Posts 12 Posters 30.3k Views 12 Watching
    • AdamBA Offline
      AdamB
      aka 'Not too much, not too little'
      One of the common problems I come across when speaking with people using texturing in any package, is how much resolution/detail is needed in textures. Is 256x256 pixels enough? 1024x1024? 4096x4096?
      Have too much texture resolution, and you slow down your system, too little and you get blurry renderings.
      The amount of resolution you need is "view dependent". If you're very close to a surface you need more detail in the textures than when you're far away.
      Goldilocks analyses your materials and model with respect to the current viewpoint and produces a bar chart showing which textures are about the right resolution (green bars), and which are too high resolution resulting in wasted space/larger filesize, or too low resolution resulting in a blurry look - both shown as red bars.
      Adam
        remus
        Cool idea and well implemented, have to run it over a few of my old models and see what it thinks 😄
        one mini crit, would it be possible to have a different colour for 'too small' and 'too big', as if all your textures are one way its extra work to try and figure out whether to enlarge or shrink the texture.
        • AdamBA Offline
          AdamB
          OK, here's an updated one with 3 color barcharts as suggested my remus. Also turns on scrolling.
          Place in your plugins folder
            remus
            Thanks, works like charm.
            • EarthMoverE Offline
              EarthMover
              Worked well for me also. Although, as it is a viewport dependent report and I typically render out 5 or 6 views for a client, I don't believe it would be practical to change the image resolutions for each render. It will help to find errant resolutions on imported models that may be slowing down my scene overall though.
              Thanks for all your hard work to make this tool!
              Content Creator at Skapeup
              • EscapeArtistE Offline
                EscapeArtist
                Excellent tool! Thanks. This will help me as a relatively new guy on getting that texture right.
                  May I suggest that you only offer one version of the plugin in the start of the thread? You'll find that people don't always scroll down to look for updates, and it can get hard to find the latest if it's hidden down in the thread.
                  (A screenshot gives you cookies points. 😉 )
                  • E Offline
                    Ecuadorian
                    Thanks for this, Adam.
                    If I am estimating correctly, "1.0" means the texture is about the right size for a 640x480 render for the current camera, right? Then for renderings that are to be printed, I must try to get my textures around the 4.0 spot.
                    -Miguel Lescano
                    • Mike LuceyM Offline
                      Mike Lucey
                      Nice ruby for max use of limited resources, thanks Adam 👍 Just curious! why the name Goldilocks?
                      • E Offline
                        Ecuadorian
                        The Goldilocks Principle comes from a children's story Goldilocks and the Three Bears in which a little girl found a house owned by three bears. Each bear owned a separate copy of many things, such as food, beds, etc. After testing each of the three, Goldilocks determined that one was always too much in one extreme (too hot, too large, etc.), one was too much in the opposite extreme (too cold, too small, etc.), and one was "just right."
                        http://en.wikipedia.org/wiki/Goldilocks_Principle
                        -Miguel Lescano
                        • FletchF Offline
                          Fletch
                          Hi Adam, OK... so I have a SU model sent to me that has about 12 images that are way oversized.
                          I can easily see the big files in Windows Explorer and resize the images manually with Pshop... but how can I easily load them back into SU? SU already has these larger material textures loaded ... it would be cool if there were a tool to quickly replace them with the newly re-sized images.
                          some sort of "Replace all textures in scene that are in this folder"
                          of course, even better would be to use Goldilocks, but then be able to select any image that is desired to be resized and resize it with that tool all without leaving SketchUp.
                          If anyone knows of a tool to reload the textures in the SU file from a file folder, please let me know.
                          Fletch
                          • Chris FullmerC Offline
                            Its built in since v7.0. You set your image editor in Window > Preferences > Applications.
                            Then right click on a face that has an image. Chose Texture > Edit Texture Image" and it will open it in your editor. Resize it, close, and SU updates it.
                            • FletchF Offline
                              Fletch
                              Hi Chris, of course, it's easy if you only have one texture that you know of, but if you have 12 images or more in a file that need to be resized, and you are not sure which they are or names even or even where they are in the scene, you may not have created the scene (large arch. office for instance)... not so fun. 😄
                              Fletch
                                Ahh, I see. 😉
                                  madhav
                                  Thanks 👍
                                    Pg09
                                    Thank you AdamB this is very useful!!
                                      Pg09
                                      Fletch (or anybody) where do i find the textures of my SU file? Is there temporary folder somewhere? I tried searching but i suck...
                                      • E Offline
                                        Ecuadorian
                                        Press B to activate SletchUp's Material editor.
                                        Select a material with Alt+Click
                                        Go to the Edit tab in the material editor and click on the striped cube with an orange arrow pointing right. This will open the material's texture in your photo editor (Photoshop, GIMP, Paint.NET, etc).
                                        If you haven't done already, you might want to first select your photo editor for SU textures in Window > Preferences > Applications.
                                        -Miguel Lescano
                                        • FletchF Offline
                                          Fletch
                                          pg09,
                                          If you are using Twilight, and export to XML and choose to export the texture images and IES files, it will export them all into the folder for you... that's how I am able to quickly find the 12 big files out of the 60 image files in the scene without one-by-one checking.
                                          Although, with Goldilocks, it's now a different process! 👍 but in my case above, I was not using Goldilocks, just wondering how to quickly import the 12 resized images and replace the big ones in the scene.
                                          Fletch
                                            Pg09
                                            thank you guys!
                                            it was more Fletch's answer i was looking for. Sometimes i have to work with SU files that are just chaotic (not even the purge ruby helps) so this is one more trick to see what's going on...
                                            And yes it would be a dream come through if this plugin not only would show the problematic textures but would also fix them per click )maybe offer 2-3 lower res options...
                                            That sounds complicated to program though but what do i know... 😄
