    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 262.5k Views 32 Watching
    • Chris FullmerC Offline
      Could you zip up your plugins folder and send me a copy please. Please remove other plugins first too. I don't need a copy of all your othe plugins you might have. Just mine. I'd like to see how its installed, and then I'll put it in my system just like you have it and see if I get the same errors.
        rod1233
        Here's what you requested
        This folder contains the files
          rod1233
          Where are you?
          I hope you of what is new
          rod
            rod1233
            Where are you?
            rod
              rod1233
                Sorry I missed your post yesterday. Somehiw I did not see it, sorry Rod. I have the files now and I am looking at them (I deleted the .rar file from your post alre4ady, but I downloaded it first).
                  OK, it is all installed right, thanks you so much for uploading that.
                  One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
                  PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
                  • PixeroP Offline
                    Pixero
                    Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
                    It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
                    Pleeeeaaase? πŸ˜„
                      rod1233
                      hi Chris
                      Thank you for your patience.
                      But unfortunately the problem did not end
                      I barely said Volkswagen .. Strangely in the topic I have done a test it for four days and then I got this problem
                      I do not know why and Hoahal
                      In any case sent you the file again
                      Please try to help
                        rod1233
                        Emerged within the tool ( System preferencec )
                        But the need to activate the
                        I tried hard to no avail
                          Great, we're getting closer to solving it.
                          After you try to initilize it, make sure to also go to View > Toolbars > Camera Recoder
                          You must make sure the toolbar is turned on too.
                          Plus all the tools are availabe in Plugins > Chris Fullmer Tools > Camera Recorder
                          Check those things to see if that gets it working,
                            rod1233
                            Did not show the tool in the tool bar
                            But emerged in the preferences
                              ok, so the loader file is loading, and its trying to load the script, but its failing. I have a few ideas how to fix that. Your XP is having issues with the path's for some reason. BUt I think I know how to fix it. Let me see what I can do.
                                rod1233
                                I do not have Windows XP
                                I have a Windows Vista
                                  rod1233
                                  Soil you have the file on the Windows XP has been success with ease
                                  But Windows Vista is still the problem
                                    Very odd. I write these plugins on a Vista system, and use them at work on an XP system.
                                    I'll keep digging. I might have a new file for you to try in a few hours.
                                      rod1233
                                      Waiting for the new my friend
                                      All thanks to you and your efforts
                                        Sorry Rod, I've been sick and have not been doing too much.
                                        So I don't know what the problem is, but these scripts open the ruby concole while the scripts are loading, so we can see any load errors. So please overwrite the existing files with these. And copy any text that gets written to the ruby console when SketchUp is starting. Then paste that code back here.
                                          rod1233
                                          This was the result
                                            OK Rod, I think I've found a solution. Please download and overwrite this file sindei the clf_camera_recorder folder. Please oh Please tell me this works.
                                            • 5 / 7
