    Model this - a simple cube
    72 Posts 30 Posters 9.5k Views 30 Watching
      "Aha! Easy!" I thought...
      "In 2D you draw two triangles to get a square - so surely two pyramids make a cube."
      • charly2008C Offline
        charly2008
        With ZBrush I tried to find the ideal shape, then import Obj into Sketchup. Treated with Subdivide and Smooth. But already looks almost perfect.
          charly2008
          And so I have a cube in my head.
          • boofredlayB Offline
            boofredlay
            And so goes the complexity of the cube...
            http://www.lolpix.com/_pics/Funny_Pictures_185/Funny_Pictures_1857.jpg
              rev3rse
              • daleD Offline
                dale
                Well... If were going to talk cubist....
                  charly2008
                  Cube Tutorial
                  -Do such a contour in Sketchup and print it out.
                  -Cut out the outline and fold a cube.
                  -Take a picture of the cube.
                  -Import the photo into Sketchup.
                    charly2008
                    I propose that we set up a new forum for Cubists. We need the cube necessarily to develop. It is still a long way to the perfect cube. I call it the squaring of the cube. Might be worthy of the Nobel Prize.
                    • soloS Offline
                      I dunno, that name is too square, you need to think outside the box.
                        museummaker
                        Took me awhile but I think I got it so it looks square from every side.
                        I thought SU was supposed to be easy to use? 😆 cube.skp
                          charly2008
                          I've found it at last, the earth is not a sphere but a cube. I will outline the evidence tomorrow.
                          Have a good night
                          • david_hD Offline
                            david_h
                            I found that if I modeled this correctly, I would get a perfect square. Late Password Host Allen Ludden -- the most perfect square I know. 🤣
                              rev3rse
                              Another attempt, in "Escher style"
                              A cube thought
                                Aerilius
                                We should propose to Google to update the elevation maps so that it fits better into this packaging:
                                http://sketchup.google.com/3dwarehouse/download?mid=20b4efaf430fa8b18be14e22ce0bc010&rtyp=lt&ctyp=other&ts=1243057686000
                                Initiative for efficient packaging!
                                Cube for president!
                                (ok, bush had already his cube)
                                • E Offline
                                  Ecuadorian
                                  They say a cube is just an infinite number of squares stacked together.
                                  -Miguel Lescano
                                  • N Offline
                                    nomeradona
                                    this is interesting.. can you please specify the step by step procedure you use... you gai..really makes my day today. 👊
                                      See about half way through this video clip how to make a cube and transform it... http://forums.sketchucation.com/viewtopic.php?p=208103#p208103BallsCube.png
                                        Aerilius
                                        Oh! Then I did it wrong? I stacked lots of triangles...
                                        because I thought 3-d
                                        Can you help me?
                                          Rubik's Cube made easy here
                                          [flash=400,345:yqbf21xu]http://www.metacafe.com/fplayer/1222538/rubiks_cube_magic_trick.swf[/flash:yqbf21xu]
                                            charly2008
                                            How many parts A and how many parts B are necessary to build this solid cube?
                                            Cube1.skp
                                            • 3 / 4
