    Need Sketchup Script, Can Someone Help?
    4 Posts 4 Posters 345 Views 4 Watching
      J_Wurs
      I am a framing contractor. I draw the models of our houses into Sketchup, and essentially virtually build the house. I place every piece of wood and hardware in the drawing. The wood and steel members that I use are components. I make copies of the components when I do the drafting to speed up my drafting process. I then group sections of walls into groups, and make cultists and material orders off of those grouped walls.
      I then have to manually assign a piece number for every piece of wood. For example in Wall 20, I number the Studs 1-10. So the piece number is W20S1,W20S2, ect.
      As far as the labeling goes the wall number is always first. Followed by:
      P - Plate
      B - Beam
      S - Studs
      BL - Block
      H - Hardware
      Then the number of the paticular item.
      I need a plug-in/Ruby Script that will make all the components unique. Then I want to be able to automatically, or manually but easily, number the pieces. Then when i generate the report on the wall i will be able to see all the piece numbers and their respective length
        remus
        Sounds do-able. Why dont you send jim or perhaps Chris Fullmer a PM and see what they think? Both very knowledgeable in matters concerning ruby ๐Ÿ‘
          Stock maker plugins?
            Search for CutList and ComponentReporter++
            What you want is quite doable, needs some thought on the actual naming, reporting etc...
            I suggest you post in the Plugins Forum [here] with a '[Request]' prefix - you're likely to get a better response...
