    [Plugin] triangulateFaces.rb v1.2 20101120
    97 Posts 21 Posters 110.6k Views 21 Watching
      Holes and sheared textures seems fine.
      But, when I distort them, so the texture doesn't fit to a parallelogram, then it fails.
      And that's excatly the conversation I've been having with Whaat a couple of days ago. That in order to sample textures which are distorted you need four points. Which leads to the question of PolygonMeshes: what do you do then, because if you just sample the UV from each point in the polygon you only get tree samples.
      I wonder if PolygonMesh.uv_at(u,v) can be used though. The manual is not clear on this method. The description and example don't add up.
        See what you mean - I had a distorted front face that failed...
        if you have 4 ubs's how do we check ? πŸ˜•
          I have some thoughts... πŸ’­
          The original face's mesh has a number of points - 3 or more.
          A texture usually has 3 uvs 'points'.
          A distorted texture has 4 uvs 'points'.
          How do these uvs 'points' relate to the mesh points ? If you give them the equivalent 'index' then they'll work until index=3...
          A face made from the mesh always has 3 points, these relate to the mesh points in sets of 3 - but how do these tie back to the texture uvs 'points' ? The fourth one index=3 fails ???
          How do we make an array to place the material that has this fourth pair of a 3D point and a uvs 'point' ? It must reflect the 'extra point' somehow ??
          I shall sleep on it and see if the little-grey-cells come up with anything... ➑
            For my UV plugins I have used the UVHelper to sample the points. What I did then was sample four points of the face's place - completely ignoring the face's vertices.
            Maybe, for each face that's turned into a PolygonMesh, sample four points of the front and back. Then once converted into PolygonMesh, apply the sampled UV points to each of the polygon faces. That should work. All the created polygon faces are still on the old face's plane.
              More ideas... let me sleep... zzzzzzzzzzzzz x πŸ’­
                def triangulateFace(face)
                ### if already a triangle leave alone...
                 if face.vertices[3]
                  mesh=face.mesh(3)
                  ents=face.parent.entities
                  mat=face.material
                  bac=face.back_material
                  p0=face.vertices[0].position
                  p1=face.vertices[1].position
                  p2=face.vertices[2].position
                  p3=face.vertices[3].position
                  ### get uvs
                  tw=Sketchup.create_texture_writer
                  uv_helperF=face.get_UVHelper(true,false,tw)
                  uv_helperB=face.get_UVHelper(false,true,tw)
                  uf0=uv_helperF.get_front_UVQ(p0)
                  uf1=uv_helperF.get_front_UVQ(p1)
                  uf2=uv_helperF.get_front_UVQ(p2)
                  uf3=uv_helperF.get_front_UVQ(p3)
                  ub0=uv_helperB.get_back_UVQ(p0)
                  ub1=uv_helperB.get_back_UVQ(p1)
                  ub2=uv_helperB.get_back_UVQ(p2)
                  ub3=uv_helperB.get_back_UVQ(p3)
                  grp=ents.add_group
                  grp.entities.add_faces_from_mesh(mesh)
                  grp.entities.each{|e|
                    if e.class==Sketchup;;Edge
                      e.smooth=false
                      e.soft=false
                    elsif e.class==Sketchup;;Face
                      if mat
                        e.position_material(mat,[p0,uf0, p1,uf1, p2,uf2, p3,uf3], true)
                      end#if
                      if bac
                        e.position_material(bac,[p0,ub0, p1,ub1, p2,ub2, p3,ub3], false)
                      end#if
                    end#if
                  face.erase!
                  grp.explode
                 end#if
                end#def
                Seems to me that this should work... but it doesn't - Thomthom, any ideas πŸ˜•
                  if face.vertices[3]
                    mesh=face.mesh(3)
                    mat=face.material
                  	# (TT)
                  	# Instead sampling vertices we sample points of the face's plane.
                  	# This is because we need four points, and some times a face only has tree vertices.
                  	# And we also get the wrong result if any of the first four vertices are co-linear.
                  	samples = []
                  	samples << face.vertices[0].position			 # 0,0 | Origin
                  	samples << samples[0].offset(face.normal.axes.x) # 1,0 | Offset Origin in X
                  	samples << samples[0].offset(face.normal.axes.y) # 0,1 | Offset Origin in Y
                  	samples << samples[1].offset(face.normal.axes.y) # 1,1 | Offset X in Y
                    ### get uvs
                  	# (TT)
                  	uv_helper=face.get_UVHelper(true,true,tw) # (TT) Only need one UV Helper
                  	xyz = []
                  	uv_f = []
                  	uv_b = []
                  	samples.each { |position|
                  		# XYZ 3D coordinates
                  		xyz << position
                  		# UV 2D coordinates
                  		# Front
                  		uvq = uv_helper.get_front_UVQ(position)
                  		uv_f << flattenUVQ(uvq)
                  		# Back
                  		uvq = uv_helper.get_back_UVQ(position)
                  		uv_b << flattenUVQ(uvq)
                    grp=ents.add_group
                    grp.entities.fill_from_mesh(mesh, true, 0) # (TT) Adds the mesh without soft/smooth edges. (and faster)
                      next unless e.class==Sketchup;;Face
                        if mat
                  		# (TT)
                  		# Position texture.
                  		pts = []
                  		(0..3).each { |i|
                  			pts << xyz[i]
                  			pts << uv_f[i]
                          e.position_material(mat,pts, true)
                        end#if
                        if bac
                  		# (TT)
                  		# Position texture.
                  		pts = []
                  		(0..3).each { |i|
                  			pts << xyz[i]
                  			pts << uv_b[i]
                          e.position_material(bac,pts, false)
                        end#if
                    face.erase!
                    grp.explode
                  end#if
                  end#def
                  # (TT)
                  # Get UV coordinates from UVQ matrix.
                  def flattenUVQ(uvq)
                  	return Geom;;Point3d.new(uvq.x / uvq.z, uvq.y / uvq.z, 1.0)
                    Thanks to CPhillips's inciteful ideas I have now made a 'joint' script called 'triangulateFaces.rb' which is attached. It uses CPhillips's triangulateFace(face) code [with a slight TIG addition for back_materials] and the TIG Plugin triangulateFaces(face_array)...
                    Originally 2009 (c) CPhillips* then (c) TIG** THEN (c) ThomThom ***
                    Script: triangulateFaces.rb
                    Code Usage: triangulateFace(face)*
                    Result: it triangulates a face... all Texture UVs are kept.
                    Plugin Usage: triangulateFaces(faces_array)**
                    Result: it triangulates faces in a selection...
                    v1.0
                    First Release: Def Code 'mesh' idea by CPhillips*,
                    retained back_materials added by TIG [failed] ###,
                    Plugin parts by TIG**. 20090729
                    v1.1
                    Rewritten entirely by TIG... THEN completely corrected by Thomthom (TT)!***
                    It now retains all Texture mapping successfully. 20091203
                    v1.2
                    Triangulated faces with 4 sides glitch fixed using intersection.
                    Get the latest version from here http://sketchucation.com/pluginstore?pln=triangulateFaces
                      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=175613#p175613
                      β˜€
                      Thanks to Thomtom's knowledge of uvs mapping etc it now successfully triangulates any face [even with holes like Swiss Cheese] and keeps the front AND back uv texture mapping as it was ! Thanks!
                        Hi TIG,
                        Would it be possible for the plugin to triangulate faces with a more "even" or "regular" triangles? After this topic, I thought maybe pre-triangulating the face on the ramp would spare some extra hand-work but it seems that the plugin triangulates the faces just exactly the same way native SU does when autofolding.
                        TriangulateFaces.skp
                          @gaieus said:
                          Hi TIG,
                          TriangulateFaces uses the built-in SUp mesh making methods, which presumably match the auto-fold ones, hence the similarity.
                          You might have noticed that my ExtendEdgesByRails script does produce a neat set of faces as that can't use the mesh methods directly but has to make up its own...
                          Using EEbyRails is a MUCH simpler way of making a curved ramp - I've attached an example...EEbyRailsSimpleRamp1.pngEEbyRailsSimpleRamp2.pngEEbyRailsSimpleRamp.skp
                            Thanks TIG for the examples - although my question was more a bit "academical" and theoretical - but at least I know why the two meshes are similar.
                            Certainly the other twoo tools are also great and would probably fit more to this particular need - that moving of the face was just so simple method - too bad autofold screws it up.
                              This triangulation would be a separate plugin. It's just too specific. But I've been thinking of this myself. I often find I want such partitioning. It seems that it's usually long strip of a face where two of the sides runs parallel-ish to each other. So you want an edge to go between each opposite vertex. I've had it on my list of things to do - just not got around to it yet.
                                alz
                                Yeah, I agree -- having a more uniform triangulation method is preferred. It makes things a lot easier developing models if it's more uniformed and less "meet all at one point".
                                With the current method, I have to spend time flip-flopping various divisions (and sometimes just recutting the face).
                                πŸ˜„
                                • W Offline
                                  Woz2007
                                  v1.1
                                  [attachment=0:kz9i3jbr]<!-- ia0 -->triangulateFaces.rb<!-- ia0 -->[/attachment:kz9i3jbr]
                                  Im using this & seeing the UV mapping failing...is this the latest version?!
                                    Got a sample of where it fails?
                                    • W Offline
                                      Woz2007
                                      If you look at the texture in the tringle before & after you will see that it is affected. When I export the model as a mesh the surface is indeed messed up.
                                      I hope the image is enough to work from?!
                                      Thnaks for looking into this. This script could save me a lot of hassle if working correctly πŸ˜„
                                      before & after shot
                                        hmm...? Are you using Sandbox tools to modify the geometry afterwards?
                                        • W Offline
                                          Woz2007
                                          Yes.
                                          Should I be using an alternative?!
                                            That is causing the UV to distort, not the triangulation.
                                            The flip function in sandbox doesn't preserve UV mapping when flipping.
                                            • 2 / 5
