    Section Slice Export
    7 Posts 3 Posters 747 Views 3 Watching
      SYD_UK
      Is it possible to export the background view from a section slice together with the actual section cut objects?
      • GaieusG
        Section slice is just what it says - a group of 2D geometry which you can export as dxg/dxf with SU Pro.
        You could use Zorro2 and SectionCutFace plugins together to be able to export the section slice as well as what's "behind" - note however that Zorro2 will ultimately delete what's (only visually) cut away with the section plane.
        Sigh... TIG
          Wouldn't that be an Image ?
          If you mean 'Slice' the Model at the Section Cut Plane and Erase what's not seen and then Export the rest then Ecuadorian has a Tutorial on that... http://forums.sketchucation.com/viewtopic.php?p=184604#p184604 this uses my SectionCutFace Tool and Zorro followed by some old-fashioned Erasing etc...
          To make a 2D flat Export is not so easy if it's not an Image ?
            Csaba - Sorry to be so quick! [Sajnálom, hogy ilyen gyorsan!] 😉
            • GaieusG
              Never mind, TIG - you are invaluable here! 👍
              And that we both came to the same solution at the same time is reassuring.
                In England we have a saying - "Great minds think, alike - Fools never differ..." 😉 🤣
                  SYD_UK
                  Thanks guys - ZORO2 is just the ticket!!
                  Kind Regards
                  Syd
