    1.5k Posts 471 Posters 3.3m Views 470 Watching
      arturmercurio
      Hi guys it my first time posting in this forum. I am having issues with RoundCorner 2.1. To start, i have added the plugin that is necessary for RoundCorner to work (LibFredo6). And until now i have not been able to find a link to download RoundCorner 2.1a. I am a mac user working with Sketchup 7.1. If someone can give me some direction i'd much appreciate it. The RoundCorner plugin looks good.
      Artur C
        At the bottom at the very first post in this thread. Make sure you go to the first page of this long thread.
        • fredo6F Offline
          [Chinese version - 11 Nov 09 - 21:50 CET
          Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
          See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=171721#p171721).
          • utilerU Offline
            utiler
            Fredo, is there a need for English users to update to this version?
            Thanks for your tireless and generous work....!
            Just Curious...
            • fredo6F Offline
              Good question.
              The answer is NO. The script is the same. The Chinese translation is contained in the separate .lang file (as for all other languages).
              • H Offline
                humbucker
                I'm new to this forum and wanted to test this nice plugin, I got a fresh install of Sketchup 7 normal, but no plugin menu show up in Window or in any other menu, I've unzipped the file right, any prob with version 7 ?
                Many thanks!!
                • F Offline
                  Fong
                  Had no idea Sketch Up could do any of this! As I set here pouring through the 3DS Bible, SU might deserve another look
                  • H Offline
                    herrstirlitz
                    thank you for new buttons!
                    i'm not sure if i've found bug or if i just little stupid to use the plugin, but somehow i can't get the sharp corner round. instead i've get rounding that is oval.
                    i hope you can help.
                    here is a picture of this. like you can see the corners to the right are great, but not the left one.
                      mambo.harts.u
                      wohooooo!! thanks frodo! made it working already!
                      • fredo6F Offline
                        Unfrtunately, that's the rules of geometry. If your angle is not 90 degree, then you cannot get a circle arc, but an ellipse one.
                        • F Offline
                          Fletch
                          Hi Fredo,
                          several times it has happened to me now that if I have a complex selection during a bevel operation with RoundCorner2.1 and I use the orbit tool, then push the CTRL button in order to pan while orbiting, again, while I am in the middle of a complex operation with roundcorner, then SU will just POOF disappear...
                          I now make a habit of saving every time before using Roundcorner or Fredoscale...
                          just curious if anyone else has seen a similar issue... πŸ˜•
                          Fletch
                          Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                          • fredo6F Offline
                            @fletch said:
                            Hi Fredo,
                            Do you mean that you do an Orbiting while RoundCorner is computing the geometry(i.e. with the progress bar moving and the hourglass cursor)? If so, then you are going well beyond what is supported by the script and probably by Sketchup, and you may certainly get a bugsplat.
                            My original intent was simply to avoid the white screen syndrom for long computations (especially if you switch back and forth to another application), but Sketchup may not like to have the view changed while the geometry is modified at the same time.
                            Thanks to confirm.
                            PS: it is anyway a very wise habit to save before doing anything complex, especially with scripts but also with native Sketchup operations.
                            • F Offline
                              Fletch
                              no no no... I wouldn't try that, no. I'm just going around my building to select about 30 edges that need to be beveled... I get about 20 edges or more... and then need to rotate/pan to see the other ones... I can orbit/rotate the view just fine, but if I hit that CNTRL button + middle mouse button in order to pan the image... poof gone.
                              no big deal, I agree whole-heartedly and try very hard to save before using most scripts that are 'advanced' like RoundCorner. I really like how you have a 'catch' in it where if it runs into something it can't do, it just stops and doesn't do anything so I can continue working without a crash... in those cases I select fewer lines to bevel at a time and it usually works great.
                              I couldn't be any happier with FredoScale and RoundCorner... anyone using SketchUp without those tools is NOT using the same program I am using as far as I'm concerned... Fredoscale and RoundCorner saved my beep several times, just this week! πŸ˜†
                              Fletch
                                Rob D
                                Hi Fredo
                                I agree with Fletch!
                                though I think I might be getting the same bug. While orbiting after selecting faces my screen went completely black and I had to alt+tab to get back to SketchUp. Is that similar to what you got too Fletch?
                                • fredo6F Offline
                                  I guess you mean you get a bugsplat.
                                  I am not able to reproduce this, even on complex models (I just fixed the small issue about the Shift (for pan) interfering with the modifier value for edge selection. This will go in a next upgrade.
                                  If you have a situation where you get the crash systematically, could you send it to me so that I have a closer look.
                                    DIEGO-RODRIGUEZ
                                    hi fredo.
                                    a query.
                                    it could add this feature?
                                    distinguish between concave and convex
                                    http://img710.imageshack.us/img710/4262/roundcornerso.jpg
                                    • fredo6F Offline
                                      Diego,
                                      This is possible, but I need to build some UI around the functionality (RoundCorner actualy works with any symmetric profile).
                                      If you are in a hurry, edit the file RoundCorner_Algo.rb, line 71 and replace the 'C' by 'CR'.
                                         @profile_type = ['C', 6]
                                         @profile_type = ['CR', 6]
                                        DIEGO-RODRIGUEZ
                                        Thanks Fredo
                                          mras26
                                          I've just instlled the libfredo... and Roundcorner, got the files in Plugin folder( the same like above)
                                          When i run the sketchup program, i cant go into this new plugin.
                                          I'm from Poland and using the polisch version of sketchup, its doesnt matter if i'm using polish version?
                                          Thanks for answering
                                          • CarrozzaC Offline
                                            Carrozza
                                            Help! In another thread someone pointed me to this plugin to round off the joint of two pipes. I'm getting weird results, tough...
                                            http://img706.imageshack.us/img706/7681/capture1.gif
                                            http://img706.imageshack.us/img706/8652/capture2.gif
                                            http://img706.imageshack.us/img706/3480/capture3.gif
                                            I guess I'm missing some basics, like using wrong number of sides or something else.
                                            Could someone help me, please?
                                            • 73
                                            • 74
                                            • 4 / 74
