    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • fredo6F
      @jackson said:
      Just stumbled upon this amazing script- in common with Fredoscale, I'm stunned by its usefulness and intuitiveness- what an excellent UI. These two scripts (and Subsmooth & Divide) have completely transformed SU from orthogonal GE plaything into an organic surface modeller sufficient for most architects' needs. This is a simply stunning ruby, thank you, thank you, THANK YOU! Second donation on it's way as soon as pay day arrives! πŸ˜„
      Where did that "We're not worthy" smiley go to?
      Jackson,
      Thanks to you (and others) for your warm appreciation of the plugin. I am glad to see that it is useful in production work.
      If you see things missing or inacurate, do not hesitate. RoundCorner is a recent script, where I am able to make evolutions.
      • G
        Gruff
        Thank you Fredo. Sweet and complete. β˜€ (I won't beg for variable radius fillets... Yet. πŸ˜„ )
        It hanndles most of what I can throw at it cleanly.
        Huge boost for SU.
        ~Gruff
        Resistance is .... Character Forming. Grin
          Ruturaj
          Hi, πŸ˜‰
          I'm very happy..........
          Thanks you very much πŸ˜„
          Good job πŸ‘
          Thanks,
          RuturaJ
            arturmercurio
            Hi guys it my first time posting in this forum. I am having issues with RoundCorner 2.1. To start, i have added the plugin that is necessary for RoundCorner to work (LibFredo6). And until now i have not been able to find a link to download RoundCorner 2.1a. I am a mac user working with Sketchup 7.1. If someone can give me some direction i'd much appreciate it. The RoundCorner plugin looks good.
            Artur C
              At the bottom at the very first post in this thread. Make sure you go to the first page of this long thread.
              • fredo6F
                [Chinese version - 11 Nov 09 - 21:50 CET
                Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
                See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=171721#p171721).
                • utilerU
                  utiler
                  Fredo, is there a need for English users to update to this version?
                  Thanks for your tireless and generous work....!
                  Just Curious...
                  • fredo6F
                    Good question.
                    The answer is NO. The script is the same. The Chinese translation is contained in the separate .lang file (as for all other languages).
                    • H
                      humbucker
                      I'm new to this forum and wanted to test this nice plugin, I got a fresh install of Sketchup 7 normal, but no plugin menu show up in Window or in any other menu, I've unzipped the file right, any prob with version 7 ?
                      Many thanks!!
                      • F
                        Fong
                        Had no idea Sketch Up could do any of this! As I set here pouring through the 3DS Bible, SU might deserve another look
                        • H
                          herrstirlitz
                          thank you for new buttons!
                          i'm not sure if i've found bug or if i just little stupid to use the plugin, but somehow i can't get the sharp corner round. instead i've get rounding that is oval.
                          i hope you can help.
                          here is a picture of this. like you can see the corners to the right are great, but not the left one.
                            mambo.harts.u
                            wohooooo!! thanks frodo! made it working already!
                            • fredo6F
                              Unfrtunately, that's the rules of geometry. If your angle is not 90 degree, then you cannot get a circle arc, but an ellipse one.
                              • FletchF
                                Fletch
                                Hi Fredo,
                                several times it has happened to me now that if I have a complex selection during a bevel operation with RoundCorner2.1 and I use the orbit tool, then push the CTRL button in order to pan while orbiting, again, while I am in the middle of a complex operation with roundcorner, then SU will just POOF disappear...
                                I now make a habit of saving every time before using Roundcorner or Fredoscale...
                                just curious if anyone else has seen a similar issue... πŸ˜•
                                Fletch
                                • fredo6F
                                  @fletch said:
                                  Hi Fredo,
                                  Do you mean that you do an Orbiting while RoundCorner is computing the geometry(i.e. with the progress bar moving and the hourglass cursor)? If so, then you are going well beyond what is supported by the script and probably by Sketchup, and you may certainly get a bugsplat.
                                  My original intent was simply to avoid the white screen syndrom for long computations (especially if you switch back and forth to another application), but Sketchup may not like to have the view changed while the geometry is modified at the same time.
                                  Thanks to confirm.
                                  PS: it is anyway a very wise habit to save before doing anything complex, especially with scripts but also with native Sketchup operations.
                                  • FletchF
                                    Fletch
                                    no no no... I wouldn't try that, no. I'm just going around my building to select about 30 edges that need to be beveled... I get about 20 edges or more... and then need to rotate/pan to see the other ones... I can orbit/rotate the view just fine, but if I hit that CNTRL button + middle mouse button in order to pan the image... poof gone.
                                    no big deal, I agree whole-heartedly and try very hard to save before using most scripts that are 'advanced' like RoundCorner. I really like how you have a 'catch' in it where if it runs into something it can't do, it just stops and doesn't do anything so I can continue working without a crash... in those cases I select fewer lines to bevel at a time and it usually works great.
                                    I couldn't be any happier with FredoScale and RoundCorner... anyone using SketchUp without those tools is NOT using the same program I am using as far as I'm concerned... Fredoscale and RoundCorner saved my beep several times, just this week! πŸ˜†
                                    Fletch
                                      Rob D
                                      Hi Fredo
                                      I agree with Fletch!
                                      though I think I might be getting the same bug. While orbiting after selecting faces my screen went completely black and I had to alt+tab to get back to SketchUp. Is that similar to what you got too Fletch?
                                      • fredo6F
                                        I guess you mean you get a bugsplat.
                                        I am not able to reproduce this, even on complex models (I just fixed the small issue about the Shift (for pan) interfering with the modifier value for edge selection. This will go in a next upgrade.
                                        If you have a situation where you get the crash systematically, could you send it to me so that I have a closer look.
                                          DIEGO-RODRIGUEZ
                                          hi fredo.
                                          a query.
                                          it could add this feature?
                                          distinguish between concave and convex
                                          http://img710.imageshack.us/img710/4262/roundcornerso.jpg
                                          • fredo6F
                                            Diego,
                                            This is possible, but I need to build some UI around the functionality (RoundCorner actualy works with any symmetric profile).
                                            If you are in a hurry, edit the file RoundCorner_Algo.rb, line 71 and replace the 'C' by 'CR'.
                                               @profile_type = ['C', 6]
                                               @profile_type = ['CR', 6]
                                            • 74
                                            • 75
                                            • 8 / 75
