    Vray spot lights?
    renderpluginsextensions
    32 Posts 7 Posters 7.7k Views 7 Watching
    • EarthMoverE
      EarthMover
      Great news! That was the one thing that was really in need of desperate fixing. Nothing is more productive than being able to perform myriads of 20 sec. test renders.
      Content Creator at Skapeup
      • soloS
        Brilliant, all the issues that most users of vfsu have been bitching about.
        I need to make a carboard sign 'will work for Vray' πŸ’š
        • O
          ozzidora
          do you know anything about the transparent material problem?
          thx
            thx
            ? what problem?
            • O
              ozzidora
              when you turn the transparency lower tahn 20%
              in SKP, vray renders it no more transparent and a lot darker. Also if you
              modify the transparency map in the Vray material editor.
              I've found it happans around 20% of transparency.
              i've got the 01.05.30 version of Vray
              • stefanqS
                stefanq
                Great news Thomas! πŸŽ‰
                  hm.. Got a screenshot?
                    hm... I'm guessing it's the backside of the faces you are seeing? You have applied the transparent material on one side? And use default on the backside.
                    VfSU renders the backside blue when the material is default. This is similar to what you should be seeing in SU as well. Using the default style in SU you should see the backfaces as blue.
                    Apply transparent material to both front and back.
                    • O
                      ozzidora
                      ok it works fine thank you!
                      but the rendered material in the material editor is still darker
                      (sse attached image).
                      How can I assign material to backfaces?
                      thanks again
                        I never trust the material editor's preview for anything. The UV mapping is far out of scale for what I'm making and the sphere is rarely a good object to preview my materials.
                        ❓ Now I'm confused. What worked if you did not apply the material to the backfaces?
                        • O
                          ozzidora
                          excuse me but I'm working on a big model of a '700 baroque
                          villa in Turin with a lot of colums and with garden ground up and down and it is possible I'm not understandable!
                          I agree: the material editor preview is not reliable.
                          what I mean is:
                          -the material editor preview is uncorrect (dark)
                          -the final render is ok (with trasparent material also to the backfaces)
                          -I'd like to know how to assign a material to backfaces in a simple way (the method I've tried seems tedious (I don't explain it because it is tedious)
                          -my english is not suitable for a BBC documentary about Vray...
                            You can use this plugin: http://forums.sketchucation.com/viewtopic.php?f=180&t=18992&p=155759
                            Use the Front-Face to Back-Face command. Anything you select will have their front face material transferred to backface. It digs into nested groups/components.
                              m48
                              some clue about the release date? 😍
                                Nope. It's done when it's done.
                                • majidM
                                  majid
                                  is this useful? (worthy to translate?)
                                  http://forums.sketchucation.com/download/file.php?id=38987
                                  we have a topic here : http://forums.sketchucation.com/viewtopic.php?f=320&t=21870&start=45
                                  • 2 / 2
