    Boolean subtraction of two circle
    13 Posts 4 Posters 707 Views 4 Watching
    • E Offline
      exvion
      I wrote
      model = Sketchup.active_model
      entities = model.entities
      edgearray0 = entities.add_circle point0, vector0, radius
      edgearray1 = entities.add_circle point1, vector1, radius
      How make boolean subtraction?
        Would it not be better to just draw two arcs?
        Instead of drawing geometry only to remove it again?
        • E Offline
          exvion
          I don't know how calculate parameters of second arc.
            If the circles are both the same radius, then the second arc's angle would be 360 degrees - angle of first arc
            So if the first arc is 260 degrees, the other would be 100 degrees.
            ...though, saying that... since Sketchup circles aren't true circles - the ends might not meet...
              Jim
              If you are ultimately adding faces to the circles, you can more easily track the created faces and delete the "other" one.
              • E Offline
                exvion
                I created two arc
                group = Sketchup.active_model.entities.add_group
                vector2 = Geom;;Vector3d.new 0,0,1
                group.entities.add_arc point0, vector2, vector, diametr/2, -150.degrees, 150.degrees
                point0.z=point0.z-diametr*(3**0.5)*0.5
                group.entities.add_arc point0, vector2, vector, diametr/2, -30.degrees, 30.degrees
                How create face and push it? I try. What is wrong?
                face=Sketchup.active_model.entities.add_face(group.entities)
                face.pushpull distance,true
                  You're getting errors?
                  A bit hard to guess what isn't working.
                  But if I where to guess: face=Sketchup.active_model.entities.add_face(group.entities)
                  Can you really create faces from entities located in a different context than the one you try to create in?
                    Thomthom ❗ Grumpy... 😠
                    To be kinder... it should be:
                    face=group.entities.add_face(group.entities.to_a)
                    or even
                    face=group.entities[0].find_faces
                    ❓ πŸ˜„
                    • E Offline
                      exvion
                      Yes, this line is not correct, but I don't now how create face limited by two arc.
                      If I explode group, than I can generate face.
                      • E Offline
                        exvion
                        TIG, thank. It is work.
                          I came across grumpy?
                            Well it certainly wasn't my intention to come across as a drunk teacher. πŸ˜„ But I see what you mean. I was just sweeping by the forum and didn't look much into it. (which is why I didn't test the add_face method and instead asked questions)
                            Thanks for pointing that out to me though. Sense of mood are too easily lost in written communication - which makes wording more important.
                            (Mange takk. πŸ˜„ )
                              The English phrase is you were 'terse' [avvisende]... or 'a little short' [litt kort]... just like your old school teacher might be when you ask a seemingly stupid question or you are doing something that is obviously not right [to him] AND he has a hangover etc etc πŸ˜†
