    Vray spot lights?
    renderpluginsextensions
    32 Posts 7 Posters 7.2k Views 7 Watching
      Make a cone and place an omni inside. That's direct the light into one direction, and shape depending on the shape of the cone and position of the omni.
      • soloS Offline
        Makes sense, but will the cone not be visible?
          ah, yes. that is true. You can't make it invisible. πŸ˜•
          • soloS Offline
            Thanks for the help, It's always difficult to help someone when you either not at your PC or you do not have the app they need help with.
            Thomas, are you part of the Vray 2 beta team?
              Yup! And it's looking really really good.
              Sign up as a tester here if you like: http://software.asgvis.com/index.php?option=com_content&view=article&id=348&Itemid=417
                Check out the developer blog: http://asgvisdev.blogspot.com/
                Error 404 (Not Found)!!1
                (asgvisdev.blogspot.com)
                http://2.bp.blogspot.com/_vcfeejHrDuA/SvBTYyGYO9I/AAAAAAAAACk/EJNK1k1gGGk/s400/4SweetLightsRenderCropped.png
                  It's not VfSU 2 - though, it might as well be so, cause they've thrown in a bunch of new stuff anyhow. πŸ˜„
                  • soloS Offline
                    hmm, so this is the Max version?
                    • EarthMoverE Offline
                      EarthMover
                      Pete, I think he's saying these are going to be added as an update release for the current version of VfSU. Hopefully it's a free update.
                      Content Creator at Skapeup
                        No, it's a rewrite of V-Ray for Sketchup. It will make VfSU available on OSX.
                        Among other things that are improved: group/component materials is no longer an issue. Images can be rendered without being exploded.
                        And I've not even mentioned the list of new cool stuff. Think might have to make a post about this.
                        • soloS Offline
                          Ah, blond moment.
                          Sounds fantastic, if money was not so tight and Christmas so close I would be seriously considering getting Vray, I've been thinking about it for two years now.
                            @solo said:
                            Ah, blond moment.
                            Well, the next version still got quite a bit of work. And it'll be different beast than the current.
                              EarthMover
                              Thomas,
                              Any parsing improvements for the future?
                                @earthmover said:
                                Thomas,
                                Yes! Yes oh yes! breakthrough yesterday actually.
                                As I mentioned earlier, materials on groups/components are no longer an issue. They don't make VfSU spend an insane amount of time parsing. And they doesn't ruin the smoothing of surfaces either.
                                Groups no longer disappear either.
                                  EarthMover
                                  Great news! That was the one thing that was really in need of desperate fixing. Nothing is more productive than being able to perform myriads of 20 sec. test renders.
                                  • soloS Offline
                                    Brilliant, all the issues that most users of vfsu have been bitching about.
                                    I need to make a carboard sign 'will work for Vray' πŸ’š
                                    • O Offline
                                      ozzidora
                                      do you know anything about the transparent material problem?
                                      thx
                                        thx
                                        ? what problem?
                                        • O Offline
                                          ozzidora
                                          when you turn the transparency lower tahn 20%
                                          in SKP, vray renders it no more transparent and a lot darker. Also if you
                                          modify the transparency map in the Vray material editor.
                                          I've found it happans around 20% of transparency.
                                          i've got the 01.05.30 version of Vray
                                          • stefanqS Offline
                                            stefanq
                                            Great news Thomas! πŸŽ‰
