    A little Problem...
    59 Posts 15 Posters 3.3k Views 15 Watching
    • X Offline
      xrok1
      7.5/1.5=5
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        remus
        Well done people, its not a trick question: 2 is the correct answer as ecuadorian said (and the scales are the 1st type you posted jeff.)
        edit: doh, put 3 instead of 2. Corrected.
        • Alan FraserA Offline
          Alan Fraser
          I'd have said $10.50, Miguel. You said 7 rabbits and a half...that's 7 whole rabbits plus a half rabbit. Given, that in Ecuador, you apparently sell rabbits in the odd amount of 1.5 rabbits, you'd need to buy 7 portions of them to get 7 whole rabbits...then have a whole lot of half-rabbits left over.
          I always was something of a pedant. ๐Ÿ˜„
          3D Figures
            I agree with Eric - go and see a doctor, Remus. And when you've done so, also a psychiatrist (since who cares which ball weighs slightly more or less?)
            ๐Ÿ˜’
              remus
              Who cares! what do you mean who cares?! we're addressing fundamental problems in comparative ball analysis and scalar logic ๐Ÿ˜„
              • E Offline
                Ecuadorian
                ๐Ÿ˜†
                Another one:
                I have two jars full of a liquid amoebas eat. These amoebas multiply by 2 every three minutes. Jar A starts with two amoebas and after two hours it's full of them. Jar B starts with just one. How much time will it take it to fill?
                -Miguel Lescano
                  remus
                  2 hours 3 minutes, assuming the jars are the same size.
                  reasoning: after 3 minutes it will have multiplied, so you'll have 2 amoebas and be left with the same starting conditions you had in jar A.
                  • E Offline
                    Ecuadorian
                    ๐Ÿ‘
                    Anyone has another one?
                    -Miguel Lescano
                    • AnssiA Offline
                      Anssi
                      @remus said:
                      Well done people, its not a trick question: 3 is the correct answer as ecuadorian said (and the scales are the 1st type you posted jeff.)
                      No, Remus, two weighings is enough, when you start with the 3+3 method I think Jeff posted first:
                      First weighing: You select randomly 3+3 balls and weigh them. The next step depends on your result.
                      Second weighing: If the 6 balls were of equal weight you weigh the 2 balls left, the heavier is one of them. Otherwise, you choose randomly 2 balls out of the heavier set of 3 and weigh them. If they are equal, the heavy one is the one left out.
                      In real life, figuring this out would probably take more time than to weigh the balls in three steps ๐Ÿ˜„
                      Anssi
                        About the first problem with this and 12 same aspect objects (one is different weight)
                        http://www.goacom.com/images/scales.jpg
                        You must say what is the different object and if it's less or more weight than the current!
                        In how many minimum weigh-in can you made that? ๐Ÿ˜‰
                        Whithout see result on the Net of course! ๐Ÿ’š
                        • jeff hammondJ Offline
                          that would take 3 weighings
                          6 vs 6 then
                          3 vs 3 then
                          1 vs 1
                          [or 5vs5, 2 vs 2, 1 vs 1 leaving the possibility that you might find it in 2 tries if the 5 vs 5 results are the same]
                          could also do:
                          4vs4
                          2vs2
                          1vs1
                          which still needs 3 weighings
                            @xrok1 said:
                            7.5/1.5=5
                            while that is true, it's not the proper answer to the rabbit question.
                            a different way to think about that one is to first ignore the total amount of rabbits and figure out the cost first:
                            a rabbit and a half costs a dollar and a half therefore one rabbit costs one dollar.. so 7.5 rabbits costs $7.5
                            • daleD Offline
                              dale
                              OK now if you model and render the eight balls and seven rabbits, the price of the rabbits will go up,(because thats going to take a while, and time is money) and the weight of the balls will vary based on the visual weight they are allotted, now things are different! (oh render engine of your choice by the way ๐Ÿ˜„ )
                                @ Jeff
                                Number's 3 answer is good but explanation seems lack of precision and sybilline for external visitor ๐Ÿ˜„
                                What about object number 1,2,3,4,5,6,7,8,9,10,11,12? ๐Ÿ˜ฎ
                                Does is it less or more heavy or current? ๐Ÿ˜‰
                                  @ Jeff
                                  haha..
                                  i'm definitely not the best at explaining myself.. if i tried to explain using object numbers, it would get a lot more confusing i think ๐Ÿ˜„
                                  but here goes an example.. let's say the heavier object is #9
                                  place objects 1-6 on one side then objects 7-12 on the other.. 7-12 will weigh more so that eliminates objects 1-6
                                  place 7,8, & 9 on one side then 10, 11, & 12 on the other.. 7-9 will weigh more so that eliminates 10-12..
                                  place 7 on one side and 8 on the other... they weigh the same so that means 9 is the oddball.
                                  [EDIT] and then as Anssi said, in real life, you know you're going to test #9 against some of the other objects so the real world answer is at least 4 if not more ๐Ÿ˜„
                                    You can't say first 9 is heavy!
                                    ha
                                    well i did that for sake of explanation..
                                    regardless, i can figure out the answer in about 5 seconds but i could sit here all day long trying to explain how ๐Ÿ˜„
                                    it's a fault of mine..
                                      @ Jeff : yes but...no ๐Ÿ’š
                                      You must make first all combinaisons and then say for this combinaison 9 is heavy !
                                      So draw first all the tree !
                                      Here your proposition ๐Ÿ˜„
                                        ๐Ÿ˜„
                                        If i take you 11 oranges and one false your explanation don't work ๐Ÿ˜†
                                        Only with a 1/24 hasard ๐Ÿ˜†
                                          really? the way i see it, you can always find the the heavy one in 3 tries.. you mind showing the 1 out of 24 when it wouldn't work?
                                          further, using a different starting technique using 12 objects (5vs5), it's possible to find the oddball in 2 tries.. sometimes (17% chance of doing it 2)
                                          let's say the heavier object is #11..
                                          place 1,2,3,4,5 on one side and 6,7,8,9,10 on the other.. they weigh the same so that eliminates 1-10
                                          place #11 on one side and #12 on the other..
                                          11 weighs more so you've found it in 2 weighings.
                                            remus
                                            Annsi, sorry, typo. 2 is the right answer to the original question ๐Ÿ‘
                                            Ive got another one for you.
                                            http://upload.wikimedia.org/wikipedia/commons/0/07/Tower_of_Hanoi.jpeg
                                            (This problem is an extended case of the above problem.)
                                            The aim is to transfer all the discs from one pole to another without placing a larger disc on a smaller disc at any point.
                                            The rules for moving the discs:
                                            -you can only move 1 at a time,
                                            -a move consists of moving one disc from one pole to another without changing the position of any other discs;
                                            -a disc must always be placed on a larger disc or directly on the base.
                                            If i can move the discs at a rate of 10 a minute, how long would it take me to complete a puzzle with 64 discs?
                                            For additional cool points, can you prove your answer? and how does adding a 4th pillar effect the solution?
                                            • 2 / 3
