Woodworking ruby.
Hello,
Thank you for your kind opinions
For your information, I'd really like to translate it in English if you are interested.
I cannot promise that it will be perfect but with time, some daily corrections and some comprehension...
The next plug-in can also be used to do some milling commands.Best regards
Thanks for the effort if you can translate it. There seems to be a number of people working on some wood working tools. It would be nice to develop a sort of suite of tools. I do so love Sketchup for furniture work.
Joel -
Are there volunteers to test the plugin ?
drilling_milling_04
At the bottom of the page, before comments.menfin nazemrap
I'm using metric units and the plugin doesn't recognize them - I typed 4 for diameter and got 50,8mm diameter hole!
There is now a metric version (I hope)
You are very fast!! It is working fine now! Thanks a lot! SketchUP is becoming a swiss army knife!!
drilling_milling_04
I'm trying it but not getting it to work the way I expect. I've installed drilling_milling_04 and I've tried to follow the video but if the diameter is less than 2, I don't get any holes. If the holes are through drilled, the plugin doesn't remove all of the faces on the opposite side. I thought it might be handy for things like shelf pin holes but 2" diameter holes are a bit large for shelf pins. Nice try, though.
If this is to be useful, it ought to accept fractional and decimal values and it ought to be able to drill small diameter holes.
@dave r said:
drilling_milling_04
I tried with the metric version and got 3mm diameter holes without a problem. If You give the same dept as the material thickness the holes are o'key, but if the depth of the hole is more than the thickness then there is remaining geometry.
I don't see why there needs to be a metric version and an imperial version. Others write plugins that get the model units. Why doesn't this plugin do that?
I did set the depth to the thickness of the "board" but only one of ten holes was punched through. At this point, the plugin isn't useful to me at all.
hello
I am sorry, for these inconveniences.
I am going to work again on it.
My ruby is also poor as my English... -
menfin, excellent work! I loaded the plugin and it seems to work well. The only question I have is it appears like I can only input integer values for the diameter and depth of the hole. How would I input for a 1/2" diameter hole?
Thanks again for your efforts!
One can make the lengths independent of the units. Internally Sketchup uses inches. I read the value into a string then convert to internal with string.to_l with seems to work for me. Europeans have not complained. This should take no matter what you units are set to, into internal inches.
Joel -
Hello,
Thanks.
J have made a new attempt, by hoping to have respected your remarks.
if you want to try again.
Has to use with precaution.At the bottom of the page, before comments, new video, new plugin
menfin,
I just installed your new version of your drilling ruby. Works great!!
Will save time in laying out those book shelves. I would like to figure out a way of getting a suite of commonly used wood working tools all in one place. The kind of tools that furniture makers would use on a daily basis.
Thanks for the effort. -
I am sorry.
J ' have still found a problem.
I shall post a rectification tomorrow. -
Here is the last corrected version.
I hope that it will be good. -
Menfin, thank you. From a quick test, this plugin does seem to be good now.
Thanks again.
Menfin, I also checked out the plugin again, and tried several different scenarios, each seemed to work well. thanks again for your efforts.
I cannot get this to work. I create a component board, edit, place construction lines, close, select, open the drilling and milling ruby, enter anything and it does nothing. The other wood working drilling works fine.
Edit: figured it out! Thanks.
For the ones that does not know, I have found at the same place a very usefull ruby script called "Coupe Angulaire" that would stand for "Angle Cut"
