    Woodworking ruby.
    44 Posts 11 Posters 15.8k Views 11 Watching
    • E Offline
      ebelg2000
      I agree, this is what I had in mind when I asked the question, but like you my 4th grade French doesnt cut it.
        menfin
        Hello,
        Thank you for your kind opinions
        For your information, I'd really like to translate it in English if you are interested.
        I cannot promise that it will be perfect but with time, some daily corrections and some comprehension...
        The next plug-in can also be used to do some milling commands.
        Best regards
          jhoutman
          Thanks for the effort if you can translate it. There seems to be a number of people working on some wood working tools. It would be nice to develop a sort of suite of tools. I do so love Sketchup for furniture work.
          Joel
            menfin
            Are there volunteers to test the plugin ?
            drilling_milling_04
            At the bottom of the page, before comments.
            menfin nazemrap
              dedmin
              I'm using metric units and the plugin doesn't recognize them - I typed 4 for diameter and got 50,8mm diameter hole!
                menfin
                There is now a metric version (I hope)
                  dedmin
                  You are very fast!! It is working fine now! Thanks a lot! SketchUP is becoming a swiss army knife!!
                    drilling_milling_04
                    menfin nazemrap
                    I'm trying it but not getting it to work the way I expect. I've installed drilling_milling_04 and I've tried to follow the video but if the diameter is less than 2, I don't get any holes. If the holes are through drilled, the plugin doesn't remove all of the faces on the opposite side. I thought it might be handy for things like shelf pin holes but 2" diameter holes are a bit large for shelf pins. Nice try, though.
                    If this is to be useful, it ought to accept fractional and decimal values and it ought to be able to drill small diameter holes.
                      dedmin
                      @dave r said:
                      drilling_milling_04
                      menfin nazemrap
                      I tried with the metric version and got 3mm diameter holes without a problem. If You give the same dept as the material thickness the holes are o'key, but if the depth of the hole is more than the thickness then there is remaining geometry.
                        I don't see why there needs to be a metric version and an imperial version. Others write plugins that get the model units. Why doesn't this plugin do that?
                        I did set the depth to the thickness of the "board" but only one of ten holes was punched through. At this point, the plugin isn't useful to me at all.
                          menfin
                          hello
                          ๐Ÿ˜ณ
                          I am sorry, for these inconveniences.
                          I am going to work again on it.
                          My ruby is also poor as my English...
                          • E Offline
                            ebelg2000
                            menfin, excellent work! I loaded the plugin and it seems to work well. The only question I have is it appears like I can only input integer values for the diameter and depth of the hole. How would I input for a 1/2" diameter hole?
                            Thanks again for your efforts!
                              jhoutman
                              One can make the lengths independent of the units. Internally Sketchup uses inches. I read the value into a string then convert to internal with string.to_l with seems to work for me. Europeans have not complained. This should take no matter what you units are set to, into internal inches.
                              Joel
                                menfin
                                Hello,
                                Thanks.
                                J have made a new attempt, by hoping to have respected your remarks.
                                if you want to try again.
                                Has to use with precaution.
                                At the bottom of the page, before comments, new video, new plugin
                                  jhoutman
                                  menfin,
                                  I just installed your new version of your drilling ruby. Works great!!
                                  Will save time in laying out those book shelves. I would like to figure out a way of getting a suite of commonly used wood working tools all in one place. The kind of tools that furniture makers would use on a daily basis.
                                  Thanks for the effort.
                                    menfin
                                    I am sorry.
                                    J ' have still found a problem.
                                    I shall post a rectification tomorrow.
                                      menfin
                                      Here is the last corrected version.
                                      I hope that it will be good.
                                      drilling_milling_04_02_en
                                        Menfin, thank you. From a quick test, this plugin does seem to be good now.
                                        Thanks again.
                                        • E Offline
                                          ebelg2000
                                          Menfin, I also checked out the plugin again, and tried several different scenarios, each seemed to work well. thanks again for your efforts.
                                            mics_54
                                            I cannot get this to work. I create a component board, edit, place construction lines, close, select, open the drilling and milling ruby, enter anything and it does nothing. The other wood working drilling works fine.
                                            Edit: figured it out! Thanks.
                                            • 1 / 3
