    Help adding arc in ruby script
    10 Posts 5 Posters 2.2k Views 5 Watching
      ktkoh
      I am currently working on a mortise tool script based on the dado tool of Woodwrk.rb and it is working fine for square end mortise but I also want to add the capability of round mortise that is made with a router.
      This is the final section of the script that draws the mortise:
       po1=pt1.transform(backt) #Typical results (3.75,-0.5,0)
       po4=pt4.transform(backt) #Typical results (3.75,-0.25,0)
       po2=pt2.transform(backt) #Typical results (0.25,-0.5,0)
       po3=pt3.transform(backt) #Typical results (0.25,-0.25,0)
       codef=@entity.definition
       cface=codef.entities.add_face po1,po2,po3,po4
       h=-1*@@depth
       cface.pushpull h
       Sketchup.active_model.commit_operation
      What I need to do is add a curve (half circle) that connects p1 to p4 and p2 to p3
      From the SU I see that this is the type of code that is needed and I know the centerpoints
      radius but am not sure of the start and end vectors etc.
      # Create a circle perpendicular to the normal or Z axis
      vector = Geom;;Vector3d.new 0,0,1
      vector2 = Geom;;Vector3d.new 1,0,0
      vector3 = vector.normalize!
      model = Sketchup.active_model
      entities = model.active_entities
      arccurve = entities.add_arc centerpoint, vector2, vector3, 10, 15, 35
      UI.messagebox arccurve
      Your help would be appreciated
      Keith
        The start/end vectors are those from the centerpoint to the start/end points of the arc.
        You have those points, so vec_start=start_point-centerpoint and vec_end=end_point-centerpoint will give these vectors.
        You need to know which end is which so that the required part of the arc gets drawn...
          ktkoh
          TIG if I am reading your post correctly I define the vectors as shown?
          vec_start=po1-centerpoint
          vec_end=po4-centerpoint
          Second question will the following statement pick the face that includes the radius on the ends between point1 and point4?
          Thanks for your help
          Keith
            That won't pick a face. It will create a new one. But it will return the newly created face.
              tomot
              arcs are not easy! ....here are some code sippits from a a ruby of mine, I hope this helps!
                  x=0
                  y=0
                  z=0
                  pi = 3.141592653589793  # 180 degree angle = pi radians
                  vecz = Geom;;Vector3d.new(0, 0, 1)
                  vecy = Geom;;Vector3d.new(0, 1, 0)
                  vecx = Geom;;Vector3d.new(1, 0, 0)
              # the 4 quadrants of a circle; are
              #  pi, pi/2 | 0,pi/2
              # -pi/2,-pi | -pi/2,0
              # the following, is an example using an arc statement incorporating the above definitions
              # this arc is 90 degress, and lies in the 2nd quadrant
              model.entities.add_arc([x+@dist, y+@dist, z], vecx, vecz, @d/2, 0, pi/2, @s)
              [my plugins](http://thingsvirtual.blogspot.ca/)
              tomot
                It's often forgotten that you can specify angles in Ruby Sketchup in degrees directly, thus angle=180.degrees - no need to muddle on with PI and radians !
                  tomot:
                  No need to define pi yourself as a variable. (first of all it'd make more sense to defined it as a constant)
                  But you have it already define in the math module: Math::PI
                  And you don't have to calculate the radian values yourself. The Numeric class has .degrees and .radians to do that for you. http://code.google.com/apis/sketchup/docs/ourdoc/numeric.html
                  model.entities.add_arc([x+@dist, y+@dist, z], vecx, vecz, @d/2, 0, 90.degrees, @s)
                  (whoop! TIG beat me to it... Except the PI part.)
                  • artmusicstudioA Offline
                    artmusicstudio
                    hi,
                    is it also possible to draw a 3-point-arc in ruby? without defining a center?
                    i want to ad an arc along an edge, so the points would be (when edge is in y-direction):
                    arc_1 = 0,0,0
                    arc_2 = 0,y,0
                    arc_3 = x,y/2,0
                    is there a way?
                    thanx stan
                      @artmusicstudio said:
                      hi,
                      arc_1 = 0,0,0
                      arc_2 = 0,y,0
                      arc_3 = x,y/2,0
                      is there a way?
                      thanx stan
                      Yes of course, but it needs some trigonometry...
                      Find my 'Arc_By...' tools in the PluginsStore and see the RB inside the RBZ archive.
                      The RB include algorithms for making arcs in many ways...
                        artmusicstudio
                        hi tig, ok,
                        let's play with some formulas πŸ˜„
                        thanx stan
