    How to apply attributes through code? and how do they work?
    21 Posts 4 Posters 2.3k Views 4 Watching
      meeta
      entity1 = entities[0] status = entity1.set_attribute "Dimensions", "Length", "#{@h} mm" status = entity1.set_attribute "Dimensions", "Width", "#{@b} mm" status = entity1.set_attribute "Dimensions", "Effective Length", "#{@d} mm"
      Hi I have an entity which is a beam. It has the dimensions @h, @b and @d. How Can I make it appear onto my group when I right-click and click show attributes.
      I don't have pro, but I use at the university. does having the free version have anything to do with why its not working?
      Meet A
      • Chris FullmerC
        "show attributes" is not listed on my right click menu. Is that something you want to make? Or is it a plugin that you have installed?
          I believe he has the Attribute Manager plugin installed: http://code.google.com/p/sketchupattributemanager/
          That adds such a context menu,
            Google's Attribs.rb loads Attributes into the context-menu BUT it simply reports /manipulates the attributes associated with the selected object.
            Please rephrase your question as it is unclear what you are trying to achieve.
            You have a beam that has length/height/width as attributes.
            It should be a component_instance/group ?
            What do you want to do with it by right-clicking ?
              meeta
              I am sorry about that, With so many plugins installed, I lost track of what is really sketchup and what is the plugin. Let me rephrase:::
              Say I create a box, with the help of a plugin and group it. I want to be able to see information about the group, by selecting 'Show attributes'. But I want the attributes to be made automatic. i.e. I want see, that it is a box, it has height h, width w, etc. How can I do this?
              Meet A
                You pretty much have it there in your first post. To add attributes to an entity you use .set_attribute.
                As your plugin creates the group with the box, you attach the data you want to that group.
                  meeta
                  Yes it all goes well without any errors to debug. But When I right-click and click 'Show Attributes' there is nothing there but this in the dialog box:::
                  %(#8080FF)[**Add Category...
                  You can create/delete categories of Attributes and add/edit and delete individual attributes within a category.
                  To get started, click on the Add Category... link above.
                  Tip: You can create standard categories by clicking here.
                  Add an attribute Delete Category Cancel Accept**]
                  Is there another way of access the attributes I applied? And say I save this box, will the attributes be saved too?
                  Meet A
                    I sounds like you haven't added the attributes to the correct entity then.
                    I take it the first post included parts of the code you used - question is: where does the entities[0] variable come from?
                      meeta
                      I think the different entities are stored in an array format right? I copied the exact thing from the Google API.
                      [url]
                      http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#set_attribute[/url]
                      Meet A
                        I really sound like you are attaching it to some random entity. Without seeing the rest of the code I can't tell you specifically what you're doing wrong - but I'm pretty sure that entities[0] does not refer to the group you want to add the attributes to.
                        I ask you again: where are you getting the entities variable from? What entities collection does it refer to?
                        When you create a group for your box. You're using the .add_group method somewhere. That method returns a reference to the group you created. This is the entity you need to attach the attribute data to.
                          meeta
                          here is the code i think its fine..
                          def draw_beam
                          		model = Sketchup.active_model
                          		entities = model.entities
                          		group = entities.add_group
                          		entities = group.entities
                          			pt = []
                          			pt[0] = [0, 0, 0]
                          			pt[1] = [@b, 0, 0]
                          			pt[2] = [@b, 0, @h]
                          			pt[3] = [0, 0, @h]
                          		c_section = entities.add_face pt
                          		@length = -@length if( c_section.normal.dot(Y_AXIS) < 0 )
                          		c_section.pushpull @length
                          	entity1 = entities[1]
                          Meet A
                            "Well, there you're problem!" 😉
                            You are assigning the attributes to a random entity inside your group.
                            Here: you have your group assigned the the variable group. This is the value you want to attach your attributes to.
                            p.s.
                            This will always create the group at the top level of the model. If the user opens a group or component when this method is run, the user might expect the group to be created in this context - but your code will not do that. model.active_entities always refer to the current context.
                              meeta
                              Ahh there is my mistake! I love finding mistakes..
                              I thought group is a method and not a variable!
                              Meet A
                                .add_group is a method. But it returns a variable - reference to the newly created group. http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_group
                                You created the variable group and assigned it to the return value of .add_group.
                                  meeta
                                  @beam = Sketchup.active_model.selection[0] bbox = @beam.bounds point1 = bbox.max point2 = bbox.min b = (point1[0] - point2[0]).abs.to_mm.to_i length = (point1[1] - point2[1]).abs.to_mm.to_i h = (point1[2] - point2[2]).abs.to_mm.to_i @beam.set_attribute "Beam Information", "1. Type of Concrete", "#{@cstrength}"
                                  Ok one problem now, I have selected active_model as either ComponentInstance or Group. When its a group I can apply the attributes with no problem! But when its a component I am not able to add the information. Is there a way I can add all this information to it? and Is there a way to apply the same attributes to all the ComponentInstances in the active_model?
                                  Meet A
                                    active_model IS the model NEVER anything else like a ComponentInstance or a Group.
                                    You must specify either the ComponentInstance or the Group, and then set_attributes for them.
                                    If you want to set_attributes for them, you must first specify them clearly...
                                    IF the first thing in a selection is a Group you can apply attributes to it.
                                    IF the first thing in a selection is a ComponentInstance you can apply attributes to it.
                                    [You can even get the instance.definition of it and set_attributes for that]
                                    I see no problems... except that you a not selecting the right type of thing to set_attributes to ?
                                    IF @beam = Sketchup.active_model.selection[0] IS the beam then it works... BUT is it the beam first thing in the selection ? You don't tell us enough to see what the @beam = Sketchup.active_model.selection[0] might be ! 😒
                                      apply the attibs to the definition.
                                        meeta
                                        what exactly is a component definition?
                                        Meet A
                                          meeta
                                          	if (Sketchup.active_model.selection[0].typename == "Group" or Sketchup.active_model.selection[0].typename == "ComponentDefinition")
                                          			menu.add_separator
                                          			menu.add_item("Beam Analyser") {
                                          	                b = Beam.new
                                          			b.bbox
                                          			b.prompts
                                          def bbox
                                          		bbox = @beam.bounds
                                          		point1 = bbox.max
                                          		point2 = bbox.min
                                          does this make it more clear? If I choose a group, there is not problem. But if I choose a componentinstance, The attributes are applied without any problems. Unfortunately its not being applied to @beam.
                                          Meet A
                                            Would it be that your use of or instead of || makes this lines not evaluate correctly?
                                            or has a lower precedence than ||
                                            http://www.techotopia.com/index.php/Ruby_Operator_Precedence
