    How do I find a text box?
    4 Posts 3 Posters 285 Views 3 Watching
      Jim57
      While trying to get a text box to stick to a section plane (a futile endeavor) I placed one somewhere in the drawing. Now I can't find it.
      When I import to Layout I can see it, it hovers constantly ono the left side of the view no matter how the image shifts. In Sketchup it's invisible.
      Any tricks for finding a text box so I can delete it? It's the only one.
      Thanks,
      JIm
      • Rich O BrienR Online
        Did you accidentally hide it?
        If so just click Edit>Unhide>All it should show.....
        Or
        Is it on a layer that has it's visiblity turn off?
        If so enable that layer in the Layer Dialog Box.
          Jim57
          Thanks for the suggestions, rclub 24.
          I tried turning on hidden objects but nothing showed up.
          I also tried the Model Information/Text/Select All Leader Text but nothing showed up there either.
          Any other suggestions?
          Jim
          • Jean LemireJ Offline
            Jean Lemire
            Hi Jim, hi folks.
            Try this procedure:
            1 - Make sure that everything is visible. Show all layers and unhide all.
            2 - Orbit, pan and zoom to get all of your model inside the model window.
            3 - Select all (CTRL-A). This will select all the model and, normally, the invisible text object.
            4 - Press and hold the SHIFT key down to allows adding/subtracting from the selection.
            5 - Do a window select of all the model. This will unselect the model but shall keep that elusive text object as selected.
            6 - Press the Delete key.
            If you have the Model info --> Statistic window open while doing this, you shall see if the number of text objetcs decrease by one.
            Alternatively, you may try to select the model, hopefully without the elusive text object, copy it and paste it in another empty file opened into another instance of SU. If it works, delete the old file and rename the new one.
            Just ideas.
